nRF52840 Dongle not detected by laptop after Power Profile Programming
I connected my nRF52840 dongle to the laptop, it was detected with a red LED glowing on and off. Later I installed the nRF Connect software and installed the Power Profile tool. When I located my device in the Power Profiler Window. it asked for me to program, I clicked on YES and after that the red LED is gone.
Now when I plug in the nRF52840 dongle again, I cannot see the device light Red LED glowing and also it is not detected by the laptop as well in the device manager. I am using Windows 10 - 64 bit operating system.
I also tried pressing the reset button but still the nRF52840 device is not detected by laptop and LED is also not glowing. Can someone please help me in resolving this issue.
I have another controller and want to start with a button press LED on and off code.
Your help will be highly appreciated.
  • You need to press the sideways button in that case. There is not really much more to say
  • Do you have any idea of bootloader. I am able to go in the bootloader option for the dead dongle, by pressing the reset button before plugging in. Now what do i need to do next. Because when I unplug and plug it again in the normal way(like not keep presingthe reset button whilke inserting) the RED LED is not glowing.
    What do you mean? The dongle is not powered when it is not plugged in, so that does not help. You need to push the button while it is plugged in (just press and release it).
    Next you program it. What do you want to do with it? If you for instance want to use it with nRF Connect for Desktop Bluetooth, then simply open it and it will ask if you want to program the dongle, and then select "Yes". If you want to program it with something else, you can use the programmer app. Remember that if the dongle is not detected that indicates you need to push the reset button, as explained earlier in this thread.
    You only need to push the button when you need to program it and the firmware that currently runs on it does not have the DFU trigger library. This should not be something you need to do very often.
  • The way to use that dongle is,
    First plug it in, and then press the reset button, then the red light will glow.
    If you plug this out and back in at this stage, the dongle will return to the previous program. So the red light will not glow.
    when you see red light glowing, that's when you have to program. Always.
    Also note that there are many programs for dongles that cannot be detected by the OS when plugging in. So just because you cannot detect the dongle, it doesn't mean that you lost the dongle. It just means that the dongle is running a program when plugged in. If you want to reprogram it, just press the reset button and program it again.
