Data Queues crashing Zephyr code
  1. Hello,
    I am writing a code that has 2 threads. One puts data in a queue and the other gets the data from the queue. The problem is after I get the data from the queue and it's printed, the device gives an error and reboots. I think the problem might be in my definition of the queue, since I have a different queue that works normally. Here is how I define it:
    in queues.h
    struct data_time{
    uint64_t time1;
    uint64_t time2;
    uint64_t time3;
    uint64_t time4;
    K_MSGQ_DEFINE(data_timeq, sizeof(struct data_time), 4, 1);
    In main:
    struct sensor_q_adrrs{
    struct k_msgq* msgq_data_pointer;
    struct k_msgq* msgq_time_pointer;
    struct sensor_q_adrrs sensor_q = {
    .msgq_data_pointer = &data_senq,
    .msgq_time_pointer = &data_timeq,
    In the other files that I use so it's connected to the main:
    struct k_msgq* time_q1;
    void register_msgq_addres2(struct k_msgq* ptr_from_main_data, struct k_msgq* ptr_from_main_time){
             printk("\n gets to register_msgq_addres1");
             data_q1 = ptr_from_main_data; time_q1 = ptr_from_main_time;
    I would really appreciate it if any tips can be given on what I do wrong with the definition.
    The error I get when the code reboots is:
    Faulting instruction address (r15/pc): 0x00000000
  • I tried it but unfortunately, the program crashes again.
    Unfortunately we will be a bit low on staff due to Holidays. Not sure if we will be able to come back to you before the first week of January, Sorry for the inconvenience.
    What makes you think that the crashes comes from the message queue, and not something else, such as you JSON handling?
    I have been looking over your code, and there are some questions that comes to mind:
    1.
    oid aws_put_to_dataq_timeq(uint8_t put_data, uint64_t put_time){
        if (data_q == NULL){
            printk("Eda msgq is null! Did you forget to call register_msgq_address?");
            return;
        if (time_q == NULL){
            return;
        k_msgq_put(data_q, &put_data, K_NO_WAIT);
        k_msgq_put(time_q, &put_time, K_NO_WAIT);
    In this code, you put a uint64_t into the message queue, not a data_time struct. Given that the data_time struct only holds a uint64_t, this should work, but it is still bad design.
    2.
     if (root_obj == NULL){
        cJSON_Delete(root_obj);
        err = -ENOMEM;
        return err;
    Here, you are freeing a NULL pointer. The cJSON library should handle it, so that the call to cJSON_Delete becomes a no-op, but again it points to a bad implementation.
    3. 64-bit support in stdio.h and string.h is usually not included by default in libc in NCS. Which libc implementation are you using, and have you enabled 64-bit support?
    Didrik
  • Hello Didrik,
    1. I used it the same way for uint8_t but I didn't have any problems with it so I tought the problem is not from the cJSON.
    2. This was part of the AWS_IOT sample code so I left it like that.
    3. I used the stdlib.h library.
    I first tried the code passing the uint64_t value directly to the aws_put_to_dataq_timeq() function without a queue and with cJSON and then it didn't had any problems. That is why I think that the problem comes from the queues, because when I implement it then it occurs.
    Also I did my own function for queues and again I am using cJSON and I don't have an error with this.
