MAC Address BLE scan filter not working
Hello all,
Currently I am developing a code in which a central (nRF52840) scans and reads adverisement packets from 2 beacons (no connection required). I decided to use an adress filter to limit the amount of advertisement data received; however, it seems that it is not working because:
1. I´m getting TONS of advertisement packets that don´t look similar to what I´m expecting.
2. The event NRF_BLE_SCAN_EVT_FILTER_MATCH is never triggered.
Below I´ll show you some key points of the code:
Declarition of the target MAC address (AC:23:3F:A9:EF:E2)
static bool is_connect_per_addr = true;            /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
    /* Possible values for addr_type:
       BLE_GAP_ADDR_TYPE_PUBLIC,
       BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
    //.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
    .addr      = {0xE2, 0xEF, 0xA9, 0x3F, 0x23, 0xAC}
    //.addr      = {0x41, 0x8C, 0xFE, 0x05, 0x1C, 0x00}
Filters settings
static void scan_init(void)
    ret_code_t          err_code;
    nrf_ble_scan_init_t init_scan;
    //static char const test_periph_addr[] = {0xEA, 0xEF, 0xA9, 0x3F, 0x23, 0xAC};
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param     = &m_scan_param;
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    ble_uuid_t uuid =
        .uuid = TARGET_UUID,
        .type = BLE_UUID_TYPE_VENDOR_BEGIN,
    err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &uuid);
    if (strlen(m_target_periph_name) != 0)
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
    if (is_connect_per_addr)
                                          SCAN_ADDR_FILTER,
                                          m_target_periph_addr.addr);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
ADV_REPORT EVENT
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
            NRF_LOG_INFO("Advertisement report");
            //on_adv_report(&p_gap_evt->params.adv_report);
            //if( p_gap_evt->params.adv_report.direct_addr.addr == m_target_periph_addr.addr)
            //    NRF_LOG_INFO("Found");
            uint8_t data_length = p_gap_evt->params.adv_report.data.len;
            NRF_LOG_INFO("Data length: %d", data_length);
            uint8_t i;
            for (i=0; i<=data_length; i++)
                uint8_t data = p_gap_evt->params.adv_report.data.p_data[i];
                NRF_LOG_INFO("0x%02X", data);
Thank you so much in advance
  •  My filters are started normally and successfully, I just can't get a match with the address, through your example code it worked, but with my code it doesn't work, and in the filters part both codes are identical!
    I already have a ticket but I don't get any answers...please help me!
    I can successfully filter and get connection with all other filters but the address filter, I will open another ticket, mention you, and I will privately send my code to you. thanks.
