Close ANT HRM channel and save to SDcard ?
Dear Members,
How can I stop ANT HRM channel temporarily, and save the heart rate value on to SDcard ?
My code at static void page0_data_log(ant_hrm_page0_data_t const * p_page_data),
err_code = sd_ant_channel_close(HRM_CHANNEL_NUM);
        log_hrm(p_page_data->computed_heart_rate); //log HRM value 8Dec21 Rixtronix LAB
        //open the channel
        err_code=sd_ant_channel_open(HRM_CHANNEL_NUM);
Please revise me ?
Thanks
  • You write system reset, the only way the chip will reset is if power is removed, pin reset is pressed or NVIC_SystemReset() is called. I believe the case here is that NVIC_SystemReset() is called, and likely from the app_error_fault_handler(), you should build with DEBUG to find the exact cause.
    Kenneth
  • Ok, I will try build and use DEBUG, anyway,
    I never got these breakpoints  :
    When it's connected on ANT HRM, it keeps running never stop on that breakpoint ?
    Any ideas ?
    Thanks
  • Hi Kenneth,
    When I put DEBUG,
    I got this :
    nfo> app: Err_code libuarte_init libuarte1 0
    rror> app: SOFTDEVICE: ASSERTION FAILED
    What's the cause of "SOFTDEVICE: ASSERTION FAILED" ?
    How can we trace it ?
    Thanks
  • there are two ant_evt_handler I can see,
    one in main.c and the other one is in ant_state_indicator
    in main :
    static void ant_evt_handler(ant_evt_t * p_ant_evt, void * p_context)
    switch (p_ant_evt->event)
    case EVENT_RX_FAIL_GO_TO_SEARCH:
    /* Reset speed and cadence values */
    memset(&m_speed_calc_data, 0, sizeof(m_speed_calc_data));
    memset(&m_cadence_calc_data, 0, sizeof(m_cadence_calc_data));
    // No implementation needed
    in ant_state_indicator.c
    ret_code_t err_code = NRF_SUCCESS;
    if (m_channel != p_ant_evt->channel)
    return;
    switch (m_channel_type)
    case CHANNEL_TYPE_SLAVE:
    /* fall through */
    case CHANNEL_TYPE_SLAVE_RX_ONLY:
    case EVENT_RX:
    NRF_LOG_INFO("EVENT_RX...\r\n");
    nrf_pwr_mgmt_feed(); //Function for indicating activity.
    case EVENT_RX_FAIL:
    NRF_LOG_INFO("EVENT_RX_FAIL...\r\n");
    NRF_LOG_INFO("RIXTRONIX EVENT_RX_FAIL...\r\n");
    err_code = bsp_indication_set(BSP_INDICATE_RCV_ERROR);
    NRF_LOG_INFO("EVENT_RX_FAIL_GO_TO_SEARCH...\r\n");
    NRF_LOG_INFO("RIXTRONIX EVENT_RX_FAIL_GO_TO_SEARCH...\r\n");
    err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
    case EVENT_CHANNEL_CLOSED:
    NRF_LOG_INFO("EVENT_CHANNEL_CLOSED...\r\n");
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF); //default
    //nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_CONTINUE);
    case EVENT_RX_SEARCH_TIMEOUT:
    //Rixtronix LAB
    //8 Sept 2021,
    //on search timeout, and idle, make device on if there is a signal from sensor ?
    NRF_LOG_INFO("EVENT_RX_SEARCH_TIMEOUT...\r\n");
    err_code = bsp_indication_set(BSP_INDICATE_IDLE);//default
    //err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
    nrf_pwr_mgmt_feed(); //Function for indicating activity. default
    in softdevice_setup function at main/**@brief BLE + ANT stack initialization.
    * @details Initializes the SoftDevice and the stack event interrupt.
    static void softdevice_setup(void)
    ret_code_t err_code = nrf_sdh_enable_request();
    NRF_LOG_INFO("softdevice_setup\r\n");
    ASSERT(nrf_sdh_is_enabled());
    #ifdef BLE_STACK_SUPPORT_REQD
    ble_stack_init();
    err_code = nrf_sdh_ant_enable();
    // Register a handler for ANT events.
    NRF_SDH_ANT_OBSERVER(m_ant_observer, APP_ANT_OBSERVER_PRIO, ant_evt_handler, NULL);
    ant_evt_handler the one in main.c is being used,
    does this naming ant_evt_handler cause the crash ?
    Thanks
  • I got this error
    <error> app: ERROR 0 [NRF_SUCCESS] at ..\..\..\..\..\..\..\..\components\librari
    \libuarte\nrf_libuarte_async.c:230
     at: 0x000462F7
    on main loop
    at GPS_process function
