Custom NRF52810 board not advertising and hanging on nrf_sdh_enable_request()
Hello all,
I have recently developed a custom board that uses an nrf52810. It also contains an accelerometer as well as some hardware for regulating the voltage and charging a battery. The issue I am having is that the device is unable to advertise. I have been searching around the internet for days however have been unable to find a solution to my problem. I am using sdk17.1.0 and softdevice s112 v7.2.0. I have been trying to use the ble_blinky_pca10040e example to help me start learning to develop for this board. My board does not contain a LF clock and therefore I set it to use the RC in the sdk_config. I have also set the ram and flash sizes appropriately. I have made numerous other modifications to the sdk_config however nothing appears to work. I at first used rtt viewer to see the logs from the device while it ran and it would sometimes throw errors while attempting to set BLE_CONN_CFG_GAP, BLE_GAP_CFG_ROLE_COUNT, etc, sometimes with a fatal error thrown as well. I started using SES to debug the application. When the program is loaded onto the device it runs until it hits ble_stack_init and then either halts on the register at 00000A60, or (more often) gets stuck on the line SVCALL(SD_SOFTDEVICE_ENABLE, uint32_t, sd_softdevice_enable(nrf_clock_lf_cfg_t const * p_clock_lf_cfg, nrf_fault_handler_t fault_handler));. The errors commented above the call make me think that it has something to do with the LF clock config however if I check the configuration it is correct. (set to RC, accuracy to 1, RC_CTIV 16, RC_TEMP_CTIV to 2), and I can also see the correct values in the variable when debugging. The device is able to run examples that do not involve BLE (like the blinky example) without issue. This is my first time taking on a project this large and I will admit at this point I am feeling rather lost. Any assistance is greatly appreciated. I am also happy to upload any code or hardware files should anyone require them.
Thank you!
  • Hi Mitchell,
    Jared is on vacation so I will take over the case.
    Do you still have the issue ?
    I would suggest to try testing on another board just in case you have a corrupted chip/board.
    Please be aware that it's not possible to break and step into the code when the softdevice is active. The softdevice uses the Timer to manage timing and when you break the timing will be messed up. You can step the code as long as it doesn't call any softdevice API.
    You can also test the board functionality by testing with the radio example or the proprietary_rf examples. These doesn't require the softdevice and can test the board radio and crystal.
