sample net_sockets_can does not start correctly
Hi I try to build the sample
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.7.1/zephyr/samples/net/sockets/can/README.html
but i get this this error.
*** Booting Zephyr OS build v2.6.99-ncs1-1 ***
Flash regions Domain Permissions
00 01 0x00000 0x10000 Secure rwxl
02 31 0x10000 0x100000 Non-Secure rwxl
Non-secure callable region 0 placed in flash region 1 with size 32.
SRAM region Domain Permissions
00 07 0x00000 0x10000 Secure rwxl
08 31 0x10000 0x40000 Non-Secure rwxl
Peripheral Domain Status
00 NRF_P0 Non-Secure OK
01 NRF_CLOCK Non-Secure OK
02 NRF_RTC0 Non-Secure OK
03 NRF_RTC1 Non-Secure OK
04 NRF_NVMC Non-Secure OK
05 NRF_UARTE1 Non-Secure OK
06 NRF_UARTE2 Secure SKIP
07 NRF_TWIM2 Non-Secure OK
08 NRF_SPIM3 Non-Secure OK
09 NRF_TIMER0 Non-Secure OK
10 NRF_TIMER1 Non-Secure OK
11 NRF_TIMER2 Non-Secure OK
12 NRF_SAADC Non-Secure OK
13 NRF_PWM0 Non-Secure OK
14 NRF_PWM1 Non-Secure OK
15 NRF_PWM2 Non-Secure OK
16 NRF_PWM3 Non-Secure OK
17 NRF_WDT Non-Secure OK
18 NRF_IPC Non-Secure OK
19 NRF_VMC Non-Secure OK
20 NRF_FPU Non-Secure OK
21 NRF_EGU1 Non-Secure OK
22 NRF_EGU2 Non-Secure OK
23 NRF_DPPIC Non-Secure OK
24 NRF_REGULATORS Non-Secure OK
25 NRF_PDM Non-Secure OK
26 NRF_I2S Non-Secure OK
27 NRF_GPIOTE1 Non-Secure OK
SPM: NS image at 0x10000
SPM: NS MSP at 0x200182b8
SPM: NS reset vector at 0x17071
SPM: prepare to jump to Non-Secure image.
[00:00:00.201,782] <dbg> mcp2515_can.socket_can_init: Init socket CAN device 0x2 a680 (SOCKET_CAN_1) for dev 0x2a6b0 (CAN_1)
[00:00:00.217,376] <dbg> net_core.net_init: (main): Priority 90
[00:00:00.225,982] <dbg> net_core.l3_init: (main): Network L3 init done
[00:00:00.235,290] <dbg> mcp2515_can.socket_can_iface_init: Init CAN interface 0 x200149f8 dev 0x2a680
uart:~$ *** Booting Zephyr OS build v2.6.99-ncs1-1 ***
[00:00:00.252,014] <inf> net_socket_can_sample: sleeping for 2 seconds
[00:00:02.261,352] <err> net_socket_can_sample: Cannot create 1st CAN socket (-106)
[00:00:02.271,972] <err> net_socket_can_sample: Cannot start CAN application (-106)
uart:~$
  • net_sockets_can.zip
    Hi Torbjörn, Please see enclosed file as a copy of my folder.
    Hopefully you can reproduce the error .
    Please note that i have made the modification as sugested by your college as in the pic bellow.
  • Any feedback on this topic?
    I m currently integrating MCP2515 on the nrf9160 and dealing with the same issue.
    However, I did not get the compiler error. Just stayed with the same -106 error after making the suggested changes on nrf91_socket.c and sockets CMakeList.txt
  • Hi
    Neither the developer nor myself was able to reproduce the build error you got earlier.
    Maybe there is something I missed, but what was the difference between this test, and the test where you got the build error?
    Best regards
    Torbjørn
  • Hi Torbjörn
    The last comment was not from me . It was form someone else (with user name rfc) that also is following this topic with intrest as he has the same issue. :-)  / Tomas
  • I hereby confirm, I am not T.B-D but I am having a similar issue.
    I was able to compile the code and use the CAN socket, but am still having issues with the CAN transmission. I wanted to do some checks to our HW before posting any conclusion to discard any HW problem.
    On the meanwhile and since you replied, I was able to partially solve the issue by directly rejecting the AF_CAN socket family in the nrf91_socket_is_supported() so that other registered socket handlers can be checked. Note that for this to happen you have to apply the fix above mentioned to the zephyr\subsys\net\lib\sockets\CMakeLists.txt.
    I attached my nrf91_socket_is_supported(). Not the best solution and I wouldn't keep it as definitive fix, but it was enough for my current needs. I would appreciate if you could post a definitive fix for this issue for the next SDK version.
    Also had to make the CMakesList.txt update you suggested before.
    static bool nrf91_socket_is_supported(int family, int type, int proto)
    	if (offload_disabled) {
    		return false;
    	if (tls_offload_disabled && proto_is_secure(proto)) {
    		return false;
        if (family == AF_CAN) { //TBD fix for general case instead of CAN only
            return false;
    	return true;
