9160/NCS: GPS accuracy value, how to interpret, and inconsistency
I'm experimenting the GPS on nrf9160 by using the ncs/samples/nrf9160/gps project. I set the GPS mode to be continuous mode. The 9160DK board is placed in a relative open area.
The initial result is encouraging. I let it run for 60s after getting the first fix. I can see the accuracy reported by GPS goes down quickly. Usually after 10~15s, the accuracy is around or below 3m and stay consistent thereafter. I understand the accuracy is a range with probability. So there's chance the true location is outside the radius as indicated by the accuracy. But if I get consistent accuracy reading that stays below 3m that probably indicates higher accuracy and/or higher confidence. Then I plot the coordinates (60 seconds) and calculated the distance from them to the average of this group of positions. It turns out that majority (>90%) of them fall in the 3m radius to the average. So that's very good result.
Now here's the inconsistent part that I don;t understand. If I stop the gps (through the api: nrf_modem_gnss_stop()) and then start over again, I'll get another set of 60s GPS data. Everything looks just like the first set: reported accuracy drops down to 3m or less quickly and the coordinates mostly fall into the radius. Except the average of the coordinates (hence the whole cluster of positions) are at a point quite some distance from the first test. It could be 6~8 meters away, or even more sometime.
I attached the data and the plot. The blue dots are from test1. Each dot is from the 1 second fix data. The size of the dot is proportional to the accuracy value of that fix. So the largest dot is the first fix. Then it get smaller and smaller. And eventually it all stays in a relatively small area. The dark blue dot (1A) is the average of all blue dots. Same situation for the yellow dots which is from the second test. The dark yellow dot(2A) is the average of all yellow dots. (the X is latitude, Y is longitude)
So my questions is, if you look at either blue or yellow individually, it all looks pretty good. If you keep the GPS in continuous mode you'll get more and more dost around the cluster and thinking that's roughly where the true position would be. But if you run a separate test, it will generate a different cluster and as we can see here from 1A to 2A it's about 6.2 meter. So how should I understand this? Why they are different? Did I miss something here?
(I uses formula here to calculate distance: https://www.movable-type.co.uk/scripts/latlong.html )
A further questions is, if I need to track position to the accuracy as data sheet specified (ie 3meter), it seems I can only keep the GPS running in continuous mode? But even so I'm not sure if the position I get is accurate or not.
Thanks!
 9160 - GPS-accuracy-static-continuous-psm0.csv
    Sorry, the response from the team was not sent for some reason.
    In customer's use case when device is moving and GNSS is running on continuous tracking mode, changing dynamic mode could improve accuracy.
    See here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/nrf_modem/doc/gnss_interface.html#changing-the-dynamics-mode
    Dynamic mode can be one of these: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/nrf_modem/doc/api.html#dynamics-modes
    Regarding antenna, 9160DK onboard antenna is rather good, but using good quality active antenna could improve accuracy. Also it often enables placing the antenna on better location in challenging environment, example higher.
    bluebeam said:
    I did not intentionally stop the GPS but I think the cellular radio will block GPS when it needs to transfer data. So there's a few seconds gap for GPS data. It's probably equivalent to a hot start.
    The GPS can not run when LTE radio is active. As described in the GPS receiver chapter of the nR9160 Product Specification:
    Operation is time multiplexed with LTE modem, and it is possible to use the GPS and QZSS receiver to obtain position either while the LTE is in RRC Idle mode or power saving mode (PSM), or when the LTE modem is completely deactivated.
    bluebeam said:
    What I can see is it seems the accuracy is a lot worse than when there's only GPS turned o
    Are you comparing with AGPS?
    bluebeam said:
    On the other hand I'm continuing more tests with the cellular radio enabled. I basically took the agps sample project and put the GPS in continuous mode, and run GPS for 1 minute and then send the data over LTE to the NRF cloud portal.
    What I can see is it seems the accuracy is a lot worse than when there's only GPS turned on. Is this something expected? Does the cellular radio affect the GPS operation in anyway (other than a small gap in time)? In the agps sample code, I see the PSM mode is requested. I did not enable GPS's PSM mode. Other conditions for testing are the same as before.
    Our modem responds with the following:
    In that case LTE will interfere with GNSS operation. If PSM is not enabled, the modem needs to periodically listen to pagings from the network. Unless eDRX is used, the paging cycle is usually 1.28 seconds.
    If both LTE and GNSS are enabled at the same time, it's recommended to use eDRX or/and PSM. eDRX can be used to increase the paging cycle much longer. And when in PSM, modem doesn't need to listen to pagings at all. It should be noted, though, that the device can only be reached by the network when it's listening to pagings. So, the suitable configuration depends on the use case (and what the network supports).
  • Thanks, enabling PSM and eDRX does help. Now the accuracy is as good as before when I ran GPS only.
    Now I'm looking at these PSM and eDRX parameters. I wonder if there's any guidance as to how to properly set them and what they mean. Or should I always let the cell network decide that? I print out some logs and looking at the PSM active time which is set at 180s which is way too long for my case. I need to send data every 60s. So that seem indicate that the device will never be in PSM mode. I attempt to set the value to something smaller like 10s or 20s. But I still get the 180s. Does that mean the network won;t allow me to change it? Is there example to for how to set PSM and eDRX parameters?
    part of my logs when start to connect to LTE network:
    *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    I: APP thread running
    I: modem init
    D: lte_lc_init
    I: AT+CGMR: 0, mfw_nrf9160_1.3.1
    , 0
    %XMODEMSLEEP: 4
    D: lte_lc_psm_param_set
    D: lte_lc_psm_req
    D: lte_lc_edrx_req
    D: lte_lc_connect
    %XMODEMSLEEP: 4
    D: LTE_LC_EVT_MODEM_SLEEP_ENTER
    %XMODEMSLEEP: 4,0
    D: LTE_LC_EVT_MODEM_SLEEP_EXIT
    +CEREG: 2,"910F","066E4D0F",7
    D: LTE_LC_EVT_NW_REG_STATUS
    D: LTE_LC_EVT_CELL_UPDATE: id=107891983 tac=37135
    D: LTE_LC_EVT_LTE_MODE_UPDATE
    +CSCON: 1
    D: LTE_LC_EVT_RRC_UPDATE
    +CEREG: 1,"910F","066E4D0F",7,,,"00100011","00011111"
    I: modem init done
    I: cloud init
    D: LTE_LC_EVT_PSM_UPDATE: tau=18600 act_time=180(s)
    +CEDRXP: 4,"1001","1001","0001"
    D: LTE_LC_EVT_EDRX_UPDATE: mode=7 edrx=163.839996(s) ptw=2.560000(s)
    Happy to hear that this provides the accuracy.
    Yes, that's correct the PSM is controlled by the network. From the document 3GPP 27.007 Ch. 7.38.
    The set command controls the setting of the UEs power saving mode (PSM) parameters. The command controls
    whether the UE wants to apply PSM or not, as well as the requested extended periodic RAU value and the requested GPRS READY timer value in GERAN/UTRAN, the requested extended periodic TAU value in E-UTRAN and the requested Active Time value. See the unsolicited result codes provided by commands +CGREG for the Active Time value, the extended periodic RAU value and the GPRS READY timer value that are allocated to the UE by the network in GERAN/UTRAN and +CEREG for the Active Time value and the extended periodic TAU value that are allocated to the UE by the network in E-UTRAN.
    More information can be found in our AT Command Reference Guide for AT+CPSMS.
    Øyvind
