sparkfun NRF9160 thing plus Serial LTE Modem Help
I have the sparkfun NRF9160 thing plus, and using the NRF Connect SDK v1.8.0 in visual studio code I can load programs like Blinky and hello world and everything works great. When I try to upload the Serial LTE Modem Example, I will not build. I get the following error:
c:\Users\David\Desktop\LTETHREE\SERmodem\src\slm_at_host.c:248:14: note: in expansion of macro 'DT_NODELABEL'
248 | DT_PROP(DT_NODELABEL(uart0), rts_pin),
c:\Users\David\Desktop\LTETHREE\SERmodem\build\zephyr\include\generated\devicetree_unfixed.h:5386:38: error: 'DT_N_S_soc_S_peripheral_40000000_S_uart_8000_P_cts_pin' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_uart_8000_P_tx_pin'?
5386 | #define DT_N_NODELABEL_uart0 DT_N_S_soc_S_peripheral_40000000_S_uart_8000
C:\Users\David\ncs\v1.8.0\zephyr\include\devicetree.h:2641:24: note: in definition of macro 'DT_CAT'
2641 | #define DT_CAT(a1, a2) a1 ## a2
c:\Users\David\Desktop\LTETHREE\SERmodem\src\slm_at_host.c:249:6: note: in expansion of macro 'DT_PROP'
249 | DT_PROP(DT_NODELABEL(uart0), cts_pin));
C:\Users\David\ncs\v1.8.0\zephyr\include\devicetree.h:2641:24: note: in expansion of macro 'DT_N_NODELABEL_uart0'
C:\Users\David\ncs\v1.8.0\zephyr\include\devicetree.h:177:29: note: in expansion of macro 'DT_CAT'
177 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
c:\Users\David\Desktop\LTETHREE\SERmodem\src\slm_at_host.c:249:14: note: in expansion of macro 'DT_NODELABEL'
[113/319] Linking C static library modules\segger\libmodules__segger.a
FATAL ERROR: command exited with status 1: 'c:\Users\David\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'c:\Users\David\Desktop\LTETHREE\SERmodem\build'
The terminal process terminated with exit code: 1.
I'm assuming I need to change something in a configuration file, is that correct?
Thanks in advance!
  • The documentation for version 1.7.1 in the MQTT AT commands doesn't list the data type as an argument when publishing. Here is the example:
    AT#XMQTTPUB="nrf91/slm/mqtt/topic0","Test message with QoS 0",0,0
    After successfully uploading 1.7.1, I tried to publish data, but without the data type argument the modem would get stuck in a publish mode.
    When I tried the documentation from 1.6.1, I saw a data type mentioned and tried to publish data starting with this example:
    AT#XMQTTPUB="nrf91/slm/mqtt/topic0",1,"Test message with QoS 0",0,0
    At this point everything works as expected!
