sd_flash_write only once
I'm attaching a function where I use the sd function :
    void edit_speed_ID(uint8_t speed)
uint32_t value;//, err_code;
value=5  * speed;
while(sd_flash_write(address,(uint32_t *) & value,1)==NRF_ERROR_BUSY);
nrf_delay_ms(1000);
pattern_ID_3();
the problem is that, when I call this function for the first time, it works fine & if I try to call this function its call is done correctly but the sd_flash_write doesn't overwrite the written value for the first time even I don't change the address passed to the sd_flash_write
  • I use this code:
    static pstorage_handle_t m_p_example_id;
    static pstorage_ntf_cb_t example_cb_handler;
      uint16_t dummy_block = 0;
    uint16_t dummy_size  = 4;
    uint16_t dummy_offset = 0;
    pstorage_handle_t p_block_id;
    static void example_pstorage_init()
    uint32_t err_code;
    pstorage_module_param_t p_example_param;
    // Setup pstorage with 10blocks of 16byte in each.
    p_example_param.block_size  = 0x04; // recommended to be >= 4 byte
    p_example_param.block_count = 10;
    p_example_param.cb          = example_cb_handler;
    err_code = pstorage_init();
    err_code = pstorage_register (&p_example_param, &m_p_example_id);
    			// Initialize
    			//flash_init();
    			leds_init();
    			timers_init();
    			gpiote_init();
    			ble_stack_init();
    			scheduler_init();
    			gap_params_init();
    			services_init();
    			advertising_init();
    			conn_params_init();
    			sensor_simulator_init();
    			sec_params_init();
    					example_pstorage_init();
    			// Start execution
    			advertising_start();
    			LPCOMP_init();
    			// Enter main loop
    			for (;;)
    					app_sched_execute();
    					power_manage();
    	//	uint8_t * value;
    		uint32_t err_code;
    	//	*value =speed;
    		err_code = pstorage_block_identifier_get(&m_p_example_id, dummy_block, &p_block_id);
    		err_code = pstorage_store(&p_block_id,&speed, dummy_size, dummy_offset);
    it caused me not to see the bluetooth device & I'm unable to communicate with it
  • Your answer is here in the documentation You probably want to use update. And update is like a store and clear, but better. I found the info in " Specifics and limitations of the SDK implementation"
  • I forgot the problem isn't in the max number of applications, it equals to 20
  • :) max applications is either 2 or 3 for my projects (one for device manager, and the others for my needs)
    One mistake you are making is that uint8_t speed is a stack variable and is not present when the flash is to be written. pstorage_store returns immediately -- I found using static variables works just fine. Others may want to implement a locked buffer or use some buffer pool service. I recommend you make speed a static/global variable to start with and change _store to _update. At first glance everything looks right to me. If you still have problems tomorrow I may show sample code.
