Controlling Servers using unicast address
Hi everyone, I am looking into controlling servers using light_lightness server in 17.0.2
As far as I know, you can control the the publishing from client side by changing publishing address to the specific unicast address.  Since I want to control quite a number of servers, having too many elements in the NRF mesh app is not possible due to composition data size restrictions. Hence, using unicast address to control individual servers will be an alternative.
What I would like to know is that if its possible to send commands via J-link to control specific servers using their unicast address instead? The process of changing unicast address on nrf mesh app can be quite troublesome as you would have to keep changing it.
I am aware that you can subscribe the servers into an element so you can control them all at once. But is it possible to control them individually despite being in the same group? For instance, using unicast address on J-link as a command and not changing unicast address on the nrf mesh app. If its possible, how should I go about achieving this?
Thanks for your help in advance!
  • Hello Kyle!
    kyle goldsteins said:
    Anything above 44 and the node is unable to be provisioned. I have found out that the composition data should not exceed the access_message_length_max which is 380
    Yes, now it seems that we are on the same page. I thought you were dealing with a 44th node, but all of these elements are in fact on the same node that you are struggling with provisioning?
    Due to the max transport PDU size of 350 octets, the node is limited by the composition data size restrictions. This has little to do with the provisioner and the app itself though.
    Out of this possible 380, 10 bytes are taken by some meta data. Then, each element consumes 4 bytes and 2 octets per SIG model and 4 octets per Vendor model. If you have 1 element with just SIG models, it gives you a maximum of 183 models. As you are left with 44 elements I assume you have 2 models per element.
    Is it possible to properly increase this number so that I could have more elements?
    No, that would go against the Mesh spec. The list of elements and their models is sent as Composition Page 0, and this has to be a single message.
    What do you mean by using virtual addresses? Can the virtual address be used to control the lights on the terminal?
    Sorry, I meant group addresses. Though there are unicast addresses, virtual addresses and group addresses. Each node has a unicast address, the virtual addresses use a UUID to I identify a node (independent of configuration in network), and the group addresses are configurable to include several elements. If you wanted to include several elements in one address then a group address might be what you are looking for.
    What I hope to achieve is that the 2 servers can be controlled individually even though they are subscribed in the same element. I know that the easier way would be to place these 2 servers in separate models under separate elements.
    This issue is referred to as "model overlap". According to the spec: "An element is not allowed to contain multiple instances of models that use the same message in the same way (for example, receive an “On” message)". To fix it put the other model in another element. There is no other way that is according to the spec.
    To summarize everything, you should get more nodes in your network to handle all your models and elements. Though could you expand a bit on why would need all these elements?
    Elfving
  • Hi Elfving!
    Yes that is correct!
    I have checked on the nRF mesh app. Currently, there is only one model per element called 'Light Lightness Client'.
    This is because I am looking at controlling the servers individually from the client node. Group addresses isn't what I am looking for as that would mean one command would be sent to all the servers.. Hence, it would be most ideal if I was able to have more elements so that I can control more servers individually.
    I have managed to increase the number of elements to 60 in my previous reply, please take a look at it and let me know how to solve the ' sending composition data get' issue if its possible
    Kyle
  • Hey Kyle,
    You should already be able to do that as long as all the models are different/ handle different messages. So the questions is why you would need this many models of the same kind on the same node?
    A typical situation where this is considered, is if you are making a lamp with multiple physical bulbs/LEDs. Then you might want as many elements as physical bulbs, since you want to control them independently. Needing more than 44 of them however is a bit surprising.
    Elfving
  • Hi Elfving,
    What I plan on doing is implement a lighting system on a small scale building (about 100 lights) using the client/server system.
    Yes, I want to be able to control these lights individually so the number of elements would be the same as the number of physical light bulbs. In this case, that would mean 100 physical light bulbs for my system.
    Kyle
  • Hello Kyle,
    Sounds great!
    In that case I assume the 100 lights would be somewhat spread out physically, and be different nodes. You might even only need one element per node, and maybe two servers. That would be far less than what the composition data size restrictions are limiting you to (the restrictions only count for one node). Additionally the light servers would all be on different elements, so they are controllable individually (each node has its own elements).
    Does that sound like a plan, or do you need all the lights to be on the same node?
    Elfving
