Is it safe to use USB dp/dm pins for SWD interface?
We are building a new version of a small device with the new nRF52832. Its only external connection is a micro USB plug that we use for charging - we do not need it as USB data interface. But would like to (mis-)use the two data pins for Serial Wire Debug (SWCLK/SWDIO) for flashing, debugging, and RTT. As long as charging is done with our standard charger, everything is fine, because we do not connect the USB data lines.
Is it safe, if the device is connected/charged via a USB host, e.g. a PC, or is it possible that an USB host causes mal-functioning of the nRF52832, i.e. stops/crashes the application code?
EDIT: Assume that signals are clipped to protect the SWD-pins electrically from over-voltage.
Has anyone experience with a similar setting?
