nRF52840 SDK16 - SAADC + RTC + PPI (power optimized solution)
Hi everyone,
There is an open ticket that I need support with because the responsible engineer will be out of the office until the new year.
In a nutshell:
I design a low-power application and I want to sample 8 pressure sensors that are connected to a MUX. I want to sample with a rate of 100Hz the group of eight sensors. That means every 10ms I need to sample all of the 8 sensors as fast as possible (given of course the hardware delays such as the MUX's switching speed and ADC conversion and acquisition time). So far, the optimized approach is to use:
RTC because uses the low-frequency clock
PPI because sampling does not require CPU intervention. However, PPI channels require that the HFCLK is always kept running (so I still thinking about it)
My purpose to go through the MUX's truth table using PPI as well (but in a future step)
Now let's say that I set an RTC CC to 10ms to trigger the SAMPLE task using the COMPARE event. Then, I have to keep sapling until the 8th sensor. I came across with two possible solutions using PPI:
1. To set up a second RTC CC let's say to 50us, to trigger the sample task using the compare event until to sample all the sensors
2. To enable the DONE interrupt, to set up a second PPI channel and trigger the SAMPLE task with the DONE event (I tried to do this but still it hasn't work) until the 8th sensor
Here Karl says that I can achieve the same functionality with just one PPI channel. I do not understand how can I do it with one channel or I didn't explain correctly to Karl what I want to achieve.
Given the aforementioned, what is the most power-optimized approach?
Thanks
Nick
  • No, you should not need two app timers. Just a single one where you do the following:
    1. Enable the SAADC
    2. Sample all sensors back to back
    3. Disable SAADC
    Note that the above would take a bit of time to complete, so you should either ensure that the interrupt priority of the app_timer is lower than other interrupts (by setting APP_TIMER_CONFIG_IRQ_PRIORITY in sdk_config.h accordingly), or defer the actual processing to the main loop (either manually or using the app_scheduler).
    1. Enable the SAADC
    3. Disable SAADC
    Something like that (I used RTC for now instead of app timer)?
    Definitions
    #define RTC_FREQUENCY 32                               // Determines the RTC frequency and prescaler
    #define SAADC_SAMPLE_INTERVAL_MS 1000                  // Interval in milliseconds at which RTC times out and triggers SAADC sample task (
    #define SAADC_SAMPLES_IN_BUFFER 1                      // Number of SAADC samples in RAM before returning a SAADC event. For low power SAADC set this constant to 1. Otherwise the EasyDMA will be enabled for an extended time which consumes high current.
    #define SAADC_OVERSAMPLE NRF_SAADC_OVERSAMPLE_DISABLED // Oversampling setting for the SAADC. Setting oversample to 4x This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times. Enable BURST mode to make the SAADC sample 4 times when triggering SAMPLE task once.
    #define SAADC_BURST_MODE 0                             // Set to 1 to enable BURST mode, otherwise set to 0.
    #define SENSORS 8
    const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(2); /**< Declaring an instance of nrf_drv_rtc for RTC2. */
    static uint32_t rtc_ticks = RTC_US_TO_TICKS(SAADC_SAMPLE_INTERVAL_MS * 1000, RTC_FREQUENCY);
    static nrf_saadc_value_t m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static uint32_t m_adc_evt_counter = 0;
    RTC handler
    static void rtc_handler(nrf_drv_rtc_int_type_t int_type) {
      uint32_t err_code;
      if (int_type == NRF_DRV_RTC_INT_COMPARE0) {
        nrf_drv_saadc_sample(); // Trigger the SAADC SAMPLE task
        err_code = nrf_drv_rtc_cc_set(&rtc, 0, rtc_ticks, true); // Set RTC compare value and enable the interrupt
        nrf_drv_rtc_counter_clear(&rtc); // Clear the RTC counter to start count from zero
    ADC handler
    void saadc_callback(nrf_drv_saadc_evt_t const *p_event) {
      ret_code_t err_code;
      if (p_event->type == NRF_DRV_SAADC_EVT_DONE) // Capture offset calibration complete event
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER); // Set buffer so the SAADC can write to it again.
        NRF_LOG_INFO("ADC event number: %d\r\n", (int)m_adc_evt_counter); // Print the event number on UART
        for (int i = 0; i < p_event->data.done.size; i++) {
          NRF_LOG_INFO("SAADC result: %d\r\n", p_event->data.done.p_buffer[i]); // Print the SAADC result on UART
        m_adc_evt_counter++;
        if ((m_adc_evt_counter % SENSORS) != 0) { // Sample all the sensors
          //add code to switch the MUX
    The RTC IRQ priority is set to 6. Should it be 7? I do not have experience with differing processing. Is this something essential that I should include?
    Something like that, but not exactly like here.
    I really recommend you use the app_timer instead, as that implements some features for you which you need. And prevents you from ending up in a few pitfalls, which you have done here. Looking at your RTC handler, you first call nrf_drv_saadc_sample(), and after that has completed you configure the RTC for the next compare event. But a bit of time has elapsed here, so you will have more ticks than you had planned in between here.
    The interrupt priorities does not matter much in itself, but matters relative to others in the system, so this is application specific. How important is this timing compared to other events in the system, and can other events handle being blocked for too long? If you can live with a bit of jitter in the sampling interval, then using a low priority (like 7) makes sense, or perhaps even moving it to the main loop (no interrupt at all).
  • Hi Einar, sorry for the late reply.
    Well, it seems that the best approach is using the app timer, however I learned a lot of things by experimenting with alternative solutions. In my case, the sampling interval is not super critical, but the power consumption is (and the PPI increases the power consumption significantly).
    Now my task is to read the IMU (I2C protocol) and 8 analog pressure sensors (connected on a MUX) with a frequency of 100Hz and send the payload through BLE. I want to start sampling when the user enables the notifications
    So I start an app timer when the notifications are enabled
    static void on_cus_evt(ble_cus_t *p_cus_service,
      ble_cus_evt_t *p_evt, int gatt_handler) {
      if (gatt_handler == CCCD_HANDLE) {
        switch (p_evt->evt_type) {
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
          NRF_LOG_INFO("Notification Enabled");
          notification = ENABLE;
          err_code = app_timer_start(m_notification_timer_id, samplingRate, NULL);
    When the timer expires (every 10ms), it calls the read_sensor() where I want initially read the IMU, then the pressure sensors, and then transmit the data.
    void read_sensors(void *p_context) {
      UNUSED_PARAMETER(p_context);
      // Read the IMU
      IMU_read(&sampling);
      // Read the pressure sensors
      for (uint8_t i = 0; i < NO_SENSORS - 1; i++) {
        pressure_sensors_read(&sampling);
      sampling.index = 0;
      // Increment the packet counter
      packet_increment(&sampling);
      logger(&sampling);
      // Buffer that payload
      my_sensors_buffer(&sampling);
      // if the buffer is not empty Tx data
      if (!nrf_queue_is_empty(&m_sensor_data_queue)) {
        data_tx(&sampling);
    However when I run the for loop to read all the sensors, I read just the first sensor and not the other seven
    To read the pressure sensors I used an additional app timer and I set the SAADC_INERVAL to 50us just to read the sensors fast
    void pressure_sensors_read(struct s_sampling *sampling) {
      err_code = app_timer_start(m_SAADC_timer_id, SAADC_INTERVAL, NULL);
    void saadc_sample() {
      err_code = app_timer_stop(m_SAADC_timer_id);
      err_code = nrf_drv_saadc_sample(); // na - trigger sampling
    By the way this is my saadc callback function
      if (p_event->type == NRF_DRV_SAADC_EVT_DONE) {
        err_code = nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); // convert two's complement to a proper value.
        NRF_LOG_INFO("FF[%d]: %d", sampling.index, p_event->data.done.p_buffer[0]);
        sampling.flexi_force[sampling.index++] = p_event->data.done.p_buffer[0];
        selectMuxPin(sampling.index); // na - change MUX channel to read the next sensor
    The NRF_LOG_INFO("FF[%d]:.... prints just once
    So, how could I read the pressure sensors before transmitting payload? Any example?
    Thanks!
  • Apart from timing and power consumption, what analogue mux are you using? It is not too difficult to make external sample/hold circuits for each analogue pressure sensor to effectively give synchronous ADC sampling if you are able to modify the hardware. A single sample pin would then capture all 8 values simultaneously which would be read out with less importance on SAADC sampling speed as the serial box-car waveform
