ERROR: The file specified is not a valid hex file, has data outside valid areas
Hello, when i try to flash my card, (nrf52840) in visual studio code i have those errors
ERROR: or does not have data in valid areas.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 52: nrfjprog --program 'c:\Users\l.marcos\Documents\nordictests\peripheral_uart\build_1\zephyr\zephyr.hex' --sectoranduicrerase -f NRF52 --snr 683372301
Thank you in advance for the help
best regards
  • > Executing task: nRF Connect: Build peripheral_uart/build (active) <
    Building peripheral_uart
    west build --build-dir c:\ncs\projects\peripheral_uart\build c:\ncs\projects\peripheral_uart
    [0/1] Re-running CMake...
    Including boilerplate (Zephyr base (cached)): C:/ncs/projects/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/ncs/projects/peripheral_uart
    -- Zephyr version: 2.6.99 (C:/ncs/projects/zephyr), build: v2.6.99-ncs1-1
    -- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
    -- Board: nrf52840dk_nrf52840
    -- Cache files will be written to: C:/ncs/projects/zephyr/.cache
    -- Found dtc: C:/ncs/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (c:/ncs/v1.7.1/toolchain/opt)
    -- Found BOARD.dts: C:/ncs/projects/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
    -- Generated zephyr.dts: C:/ncs/projects/peripheral_uart/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/ncs/projects/peripheral_uart/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/ncs/projects/peripheral_uart/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/ncs/projects/peripheral_uart/build/zephyr/dts.cmake
    Parsing C:/ncs/projects/peripheral_uart/Kconfig
    Loaded configuration 'C:/ncs/projects/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
    Merged configuration 'C:/ncs/projects/peripheral_uart/prj.conf'
    No change to configuration in 'C:/ncs/projects/peripheral_uart/build/zephyr/.config'
    No change to Kconfig header in 'C:/ncs/projects/peripheral_uart/build/zephyr/include/generated/autoconf.h'
    CMake Warning at C:\ncs\projects\zephyr\CMakeLists.txt:1612 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/projects/peripheral_uart/build
    [1/173] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [2/173] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [3/173] Generating include/generated/offsets.h
    [4/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [5/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [6/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [7/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [8/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [9/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [10/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [11/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [12/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [13/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [14/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [15/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [16/173] Building C object CMakeFiles/app.dir/src/main.c.obj
    [17/173] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [18/173] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [19/173] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [20/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [21/173] Linking C static library app\libapp.a
    [22/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [23/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [24/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [25/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_rtt.c.obj
    [26/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [27/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
    [28/173] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [29/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [30/173] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [31/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [32/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [33/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [34/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
    [35/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [36/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [37/173] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [38/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [39/173] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [40/173] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [41/173] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [42/173] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [43/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [44/173] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [45/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [46/173] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [47/173] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [48/173] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [49/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [50/173] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [51/173] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [52/173] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [53/173] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [54/173] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [55/173] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [56/173] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [57/173] Linking C static library zephyr\lib\posix\liblib__posix.a
    [58/173] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [59/173] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [60/173] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [61/173] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
    [62/173] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
    [63/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
    [64/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [65/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [66/173] Linking C static library zephyr\subsys\bluetooth\common\libsubsys__bluetooth__common.a
    [67/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_ecc.c.obj
    [68/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
    [69/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [70/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [71/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/keys.c.obj
    [72/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [73/173] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [74/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [75/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [76/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [77/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [78/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [79/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [80/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [81/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
    [82/173] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
    [83/173] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
    [84/173] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
    [85/173] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
    [86/173] Generating linker_zephyr_prebuilt.cmd
    [87/173] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [88/173] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [89/173] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [90/173] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
    [91/173] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/projects/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [92/173] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/projects/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [93/173] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/projects/nrf/subsys/bluetooth/services/nus.c.obj
    [94/173] Linking C static library zephyr\arch\common\libisr_tables.a
    [95/173] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [96/173] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [97/173] Linking C static library zephyr\arch\common\libarch__common.a
    [98/173] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [99/173] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
    [100/173] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [101/173] Linking C static library zephyr\libzephyr.a
    [102/173] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [103/173] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [104/173] Linking C static library zephyr\subsys\bluetooth\host\libsubsys__bluetooth__host.a
    [105/173] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [106/173] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/ncs/projects/nrf/drivers/entropy/entropy_cc310.c.obj
    [107/173] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [108/173] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [109/173] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
    [110/173] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [111/173] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [112/173] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [113/173] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [114/173] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [115/173] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
    [116/173] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [117/173] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [118/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [119/173] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
    [120/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [121/173] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [122/173] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [123/173] Linking C static library modules\nrf\lib\dk_buttons_and_leds\lib..__nrf__lib__dk_buttons_and_leds.a
    [124/173] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [125/173] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [126/173] Linking C static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
    [127/173] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [128/173] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [129/173] Linking C static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
    [130/173] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [131/173] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [132/173] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__controller.a
    [133/173] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [134/173] Linking C static library modules\nrf\drivers\mpsl\flash_sync\lib..__nrf__drivers__mpsl__flash_sync.a
    [135/173] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/projects/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [136/173] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/projects/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [137/173] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/projects/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
    [138/173] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [139/173] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/projects/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [140/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [141/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [142/173] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/projects/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [143/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [144/173] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [145/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [146/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [147/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [148/173] Linking C static library modules\segger\libmodules__segger.a
    [149/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [150/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [151/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [152/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [153/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [154/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [155/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [156/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [157/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [158/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [159/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [160/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [161/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [162/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [163/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [164/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [165/173] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [166/173] Linking C static library zephyr\kernel\libkernel.a
    [167/173] Linking C executable zephyr\zephyr_prebuilt.elf
    [168/173] Generating linker.cmd
    [169/173] Generating isr_tables.c, isrList.bin
    [170/173] Generating dev_handles.c
    [171/173] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [172/173] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [173/173] Linking C executable zephyr\zephyr.elf
    Memory region Used Size Region Size %age Used
    FLASH: 206908 B 1 MB 19.73%
    SRAM: 38945 B 256 KB 14.86%
    IDT_LIST: 0 GB 2 KB 0.00%
    Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer.
    ninja: no work to do.
    > Executing task: nRF Connect: Flash peripheral_uart/build (active) <
    Flashing build to undefined
    west flash -d c:\ncs\projects\peripheral_uart\build --skip-rebuild -r nrfjprog --snr 683372301
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: Flashing file: c:\ncs\projects\peripheral_uart\build\zephyr\zephyr.hex
    Parsing image file.
    FATAL ERROR: command exited with status 52: nrfjprog --program 'c:\ncs\projects\peripheral_uart\build\zephyr\zephyr.hex' --sectoranduicrerase -f NRF52 --snr 683372301
    Arrêt du processus de terminal. Code de sortie : 52.
  • Are you able to build the project successfully when you do not have the BLE BC805 module connected to the DK?
    -Priyanka
  • yes... i just did what you say and i can send any type of program..
  • the problem is that my module ( bc805) is the most important part of the project because i want to use this to integrate in my future product. thank you again in advance for your help ...
