throughput output
I have the following ouput using the throughput example:
[local] sent 660264 bytes (644 KB) in 4540 ms at 1190912 bps (145 kBps)
[peer] received 660264 bytes (644 KB) in 2706 GATT writes at 1135105 bps (138 kBps)
Altered output format a bit to give me the same for local and peer.
But I was wondering why there is a significant difference between transfer by local and reception by peer. Shouldn't this be about the same and not 7 kBps difference? What is transferred is received on the other end, so the same throughput, right?
    Martijn Jonkers said:
    another question: I notice the overall throughput goes down when I set a connection interval of 6 units. Is there a connection overhead for the connection interval? It looks like as if more data is transferred, even between data packets.
    With DLE, you want a larger connection interval, as this feature basically streams data within the same connection interval. You can see this from the table in the link you sent as well, that throughput is better with larger connection interval.
    I noticed it too, as you say, 'delta' is incorrect the first time with my implementation. But delta is only used for calculating 'met_data->write_rate' and that value is overwritten each time data comes in. So the final write_rate should be as expected. right?
    If we're talking about "peer" print, this depends on the timing between receiving the "len == 1" scenario vs. when the data comes in.
    Because the clock_cycles is set on first reception with my implementation, this skips the 500ms delay on the master and 4 sec connection interval. So, the data rate is measured from first packet to last, without any connection interval delays. correct?
    I did notice in the original implementation the timing is started on the peer when the metrics are reset. But the central adds a 500ms delay after resetting the metrics to let any ble procedures complete. This 500ms is also added to the time it takes to receive data. But on the master this 500ms is skipped, beecause the start time is determined after the delay. This would always result in a lower reception rate compared to tranmission rate, right? reception time is always 500ms longer than transfer time.
    For the "[local]" print, that is correct. On the peer side, it will by default, add that time between the events, due to the timing anchor.
    If you revert your changes, are you able to get the correct timing on the [local] side?
    Håkon
  • With DLE, you want a larger connection interval, as this feature basically streams data within the same connection interval. You can see this from the table in the link you sent as well, that throughput is better with larger connection interval.
    Okay, learned something new here. I thought the connection interval is only relevant in between actual data transmissions to maintain the connection when northing is communicated.
    I have '[local]' on the peer and master. I assume the '[local]' on the peer is the same as the '[peer]' output on the master?
    I reverted my changes. From what I understand, I will not get a correct timing on the peer. This is due to the 500ms delay introduced in the master. The peer has no knowledge of this delay after metrics reset. Is this a correct observation?
    Yes, you are correct.
    Yes. There's also the timing towards your connection interval, meaning; where you start pushing data in your application, compared to when the actual connection interval starts.
    Håkon
  • void transfer_complete(struct bt_conn *conn, void *user_data)
    	k_sem_give(&throughput_sem);
    int test_run(const struct shell *shell,
    	     const struct bt_le_conn_param *conn_param,
    	     const struct bt_conn_le_phy_param *phy,
    	     const struct bt_conn_le_data_len_param *data_len)
    	int err;
    	uint64_t stamp;
    	int64_t delta;
    	uint32_t data = 0;
    	uint32_t prog = 0;
    	uint32_t delay_ms;
    	/* a dummy data buffer */
    	static char dummy[256];
    	if (!default_conn) {
    		shell_error(shell, "Device is disconnected %s",
    			    "Connect to the peer device before running test");
    		return -EFAULT;
    	if (!test_ready) {
    		shell_error(shell, "Device is not ready."
    			"Please wait for the service discovery and MTU exchange end");
    		return 0;
    	shell_fprintf(SHELL, SHELL_VT100_COLOR_WHITE, "\n==== Starting throughput test ====\n");
    	err = connection_configuration_set(shell, conn_param, phy, data_len);
    	if (err) {
    		return err;
    	/* send dummy data to wait for connection event */
    	err = bt_gatt_write_without_response_cb(throughput.conn,
    			throughput.char_handle, dummy, 1, false, transfer_complete, NULL);
    	if (err) {
    		shell_error(shell, "transfer failed");
    		return err;
    	} else {
    		k_sem_take(&throughput_sem, THROUGHPUT_CONFIG_TIMEOUT);
    	/* we get here just after connection event */
    	/* determine time until next connection event */
    	delay_ms = (uint32_t)(conn_param->interval_max * 1.25);
    	/* Wait for bext connection event. subtract 2 to continue just before the event */
    	k_sleep(K_MSEC(delay_ms-2));
    	/* reset peer metrics */
    	err = bt_throughput_write(&throughput, dummy, 1);
    	if (err) {
    		shell_error(shell, "Reset peer metrics failed.");
    		return err;
    	/* get cycle stamp */
    	stamp = k_uptime_ticks();
    	/* transfer a bunch of bytes */
    	while (prog < IMG_SIZE) {
    		err = bt_throughput_write(&throughput, dummy, 244);
    		if (err) {
    			shell_error(shell, "GATT write failed (err %d)", err);
    		/* print progress graphics */
    		printk("%c", img[(prog % IMG_SIZE) / IMG_X][(prog % IMG_SIZE) % IMG_X]);
    		data += 244;
    		prog++;
    	// send 1 packet extra and wait for this to complete transfer
    	// do not send 1 byte, because that will reset metrics on peer.
    			throughput.char_handle, dummy, 244, false, transfer_complete, NULL);
    	if (err) {
    		return err;
    	} else {
    	data += 244;
    	// determine time it took to transfer IMG_SIZE * 244 bytes
    	delta = k_uptime_ticks() - stamp;
    	delta = k_ticks_to_ms_near32(delta);
    	shell_fprintf(SHELL, SHELL_VT100_COLOR_WHITE, "Done\n");
    	shell_fprintf(SHELL, SHELL_VT100_COLOR_YELLOW, "[local] sent %u bytes (%u KB) in %lld ms at %llu bps (%llu kbps)\n",
    	       data, data / 1024, delta, ((uint64_t)data * 8 / delta) * 1024, ((uint64_t)data * 8 / delta));
    	/* read back char from peer */
    	err = bt_throughput_read(&throughput);
    	if (err) {
    		shell_error(shell, "GATT read failed (err %d)", err);
    		return err;
    	/* Make sure that all BLE procedures are finished. */
    	k_sleep(K_MSEC(500));
    	// print average throughput
    	uint64_t average_throughput = ((((uint64_t)data * 8 / delta) * 1024) + peer_metrics.write_rate) / 2;
    	shell_fprintf(SHELL, SHELL_VT100_COLOR_YELLOW, "[throughput] average %llu bps (%llu kbps)\n", average_throughput , average_throughput/1024);
    	instruction_print();
    	return 0;
    Thank you for confirming. I edited the example so it will give me a more representative output. What I did was the following:
    - send a packet and wait for it to be actually transferred
    - wait until the next connection event
    - reset timing metrics on slave and master
    - transfer a lot of data
    - wait for last packet to be actually transferred
    - stop timing
    - print results
    This gives me the following results: alll tests are with 251 data length. and the average is the average between slave and master.
    phy 2M, 40 unit conn interval (50 ms), expected 1327 kbps
    [local] sent 660508 bytes (645 KB) in 3981 ms at 1358848 bps (1327 kbps)
    [peer] received 660508 bytes (645 KB) in 2707 GATT writes at 1327976 bps (1296 kbps)
    [throughput] average 1343412 bps (1311 kbps)
    phy 1M, 40 unit conn interval (50 ms), expected 702 kbps
    [local] sent 660508 bytes (645 KB) in 7124 ms at 758784 bps (741 kbps)
    [peer] received 660508 bytes (645 KB) in 2707 GATT writes at 741947 bps (724 kbps)
    [throughput] average 750365 bps (732 kbps)
    phy 2M, 320 units conn interval (400 ms), expected 1376 kbps
    [local] sent 660508 bytes (645 KB) in 3788 ms at 1427456 bps (1394 kbps)
    [peer] received 660508 bytes (645 KB) in 2707 GATT writes at 1395546 bps (1362 kbps)
    [throughput] average 1411501 bps (1378 kbps)
    phy 1M, 320 units conn interval (400 ms), expected 771 kbps
    [local] sent 660508 bytes (645 KB) in 6727 ms at 803840 bps (785 kbps)
    [peer] received 660508 bytes (645 KB) in 2707 GATT writes at 785690 bps (767 kbps)
    [throughput] average 794765 bps (776 kbps)
    These results almost match with what I expect and are very consistent. Can you maybe verify my method is correct?
    I am using the original throughput service implementation from the nrf connect sdk.
    You are definitely on the right track here. Adding a callback function to signalize the last packet on-air will provide a more accurate timing anchor.
    As you are waiting for the callback on the 1 byte starting payload, you can technically take away the k_sleep delay, and it seems that you're sending this command twice?
    Håkon
