Get data from BLE and write to flash memory using pstorage
I am having trouble to use flash to store data.
First, I write function and scan beacon, get information from this beacon and save to flash
I use a timer for saving data to flash but it is not work, I always get the error code = 0x00000010. It means "invalid flag". How can I solve this problem?
Thanks and regard
  • The link you mentioned is not working, seems like google drive link which is not public
  • void pstorage_sys_event_handler (uint32_t p_evt);
    bool rdy_for_next;
    static void beacon_scanner_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    static ble_beacon_scanner_init_t beacon_scanner_init;
    void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
        uint32_t checkErr = error_code;
        NVIC_SystemReset();
    static void sys_evt_dispatch(uint32_t sys_evt)
        pstorage_sys_event_handler(sys_evt);
        uint32_t err_code;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
        // Enable BLE stack
        ble_enable_params_t ble_enable_params;
        memset(&ble_enable_params, 0, sizeof(ble_enable_params));
        ble_enable_params.gatts_enable_params.service_changed =   IS_SRVC_CHANGED_CHARACT_PRESENT;
        err_code = sd_ble_enable(&ble_enable_params);
    	  // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    static void example_cb_handler(pstorage_handle_t  * handle,
    															 uint8_t              op_code,
                                   uint32_t             result,
                                   uint8_t            * p_data,
                                   uint32_t             data_len)
    		if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; }  //If we are waiting for this callback, clear the wait flag.
    		switch(op_code)
    			case PSTORAGE_LOAD_OP_CODE:
    			case PSTORAGE_STORE_OP_CODE:
    				 if (result == NRF_SUCCESS)
    						 rdy_for_next = true;
    			case PSTORAGE_UPDATE_OP_CODE:
    			case PSTORAGE_CLEAR_OP_CODE:
    			case PSTORAGE_ERROR_OP_CODE:
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    uint8_t  bufferCheck[16];
    static uint8_t  temp;
    uint8_t  dest_data_1[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
    static pstorage_handle_t        master_handle;
    static pstorage_handle_t				block_0_handle;
    static pstorage_module_param_t  param;
    static void beacon_evt_handler(ble_scan_beacon_evt_t * p_evt)
    	 int i,j = 0;
    	 for(i = 0; i < 16; i++)
    	   bufferCheck[i] =  p_evt->rcv_adv_packet.adv_data.uuid.uuid128[i];
    	 uint32_t   retval;
    		retval = pstorage_register(&param, &master_handle);
    		APP_ERROR_CHECK(retval);
       //Get block identifiers
    		retval = pstorage_block_identifier_get(&master_handle, temp, &block_0_handle);
    		retval = pstorage_clear(&block_0_handle, 16);
    		pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
    		pstorage_wait_flag = 1;
    		retval = pstorage_store(&block_0_handle, bufferCheck, 16, 0);
            while(pstorage_wait_flag) { power_manage(); }              //Sleep until store operation is finished.
    		nrf_delay_ms(100);
    		retval = pstorage_load(dest_data_1, &block_0_handle, 16, 0);				 //Read from flash, only one block is allowed for each pstorage_load command
    		nrf_delay_ms(100);
    	  temp++;
        ble_stack_init();
    	  scheduler_init();
    	  uint32_t  retval;
    		retval = pstorage_init();
    		param.block_size  = 16;
    		param.block_count = 100;
    		param.cb          = example_cb_handler;
    	  beacon_scanner_init.evt_handler   = beacon_evt_handler;
        beacon_scanner_init.error_handler = beacon_scanner_error_handler;
        app_beacon_scanner_init(&beacon_scanner_init);
        app_beacon_scanner_start();
        for (;;)
    			  power_manage();
  • @Aryan This is my code, as I say, it can not return pstorage callback function, and pstorage_wait_handle can not = 0
  • are you trying to use pstorage with timeslot API? hmm, thats new. I am not sure if that works !!! This basically means that your application is requsting another flash write timeslot inside a timeslot. What do you get when you call pstorage_access_status_get?
  • I need to see your whole main.c can you please attach it here. Are you checking for errors there, like case NRF_EVT_FLASH_OPERATION_ERROR?
