[Regression ncs v1.8.0] nRF9160-DK , Modem_shell demo , HARD FAULT after connecting over ppp
I was testing modem_shell demo in terms of using ppp. I'm using nrf9160dk board.
I found issue present in ncs v1.7.1 https://devzone.nordicsemi.com/f/nordic-q-a/80776/nrf9160-dk-modem_shell-demo-ppp-unable-to-access-the-internet
When I'm using  v1.7.1 with applied changes from PR as advised, I'm able to connect with ppp client (from linux I'm executing: sudo pppd -detach /dev/ttyACM0 115200 noauth nocrtscts local ) without any issues
When I'm using ncs v1.8.0 which seems to have fix for this issue merged in (I verified that changes are present in cs/zephyr/subsys/net/ip/packet_socket.c), the problem with hard fault is still present.
    Everything looks to be up and running, there's no errors or "bad" warnings, other than ipv6 not being supported.
    However, the RSRP shows that your signal strength is quite bad. Are you able to move to an area in your building where the signal strength is a bit better and retry the ping procedure from the PC side?
    You mention whitelisting, do you have another sim card you can try that has no restrictions in terms of DNS/ip-range?
    Håkon
    I moved from my office to my home and made tests once again.
    I was able to execute ping with success, but the way to achieve this seems strange for me. Below are the steps that I made
    1. Device has connected
    *** Booting Zephyr OS build v2.7.0-ncs1  ***
    MOSH version:       v1.8.0
    MOSH build id:      custom
    MOSH build variant: dev
    Initializing modemlib...
    mosh:~$ Initialized modemlib
    Network registration status: searching
    Currently active system mode: LTE-M
    LTE cell changed: ID: 61677067, Tracking area: 54011
    RRC mode: Connected
    PDN event: PDP context 0 activated
    Network registration status: Connected - roaming
    PSM parameter update: TAU: 10800, Active time: -1 seconds
    Default PDN is active: starting PPP automatically.
    modem data socket 4 created for modem data
    PPP Zephyr data socket 5 created
    Modem config for system mode: LTE-M
    Modem config for LTE preference: No preference, automatically selected by the modem
    Modem FW version:      mfw_nrf9160_1.2.3
    Operator full name:   "Orange"
    Operator short name:  "Orange"
    Operator PLMN:        "26003"
    Current cell id:       61677067 (0x03AD1E0B)
    Current phy cell id:   336
    Current band:          20
    Current TAC:           54011 (0xD2FB)
    Current rsrp:          66: -75dBm
    Current snr:           43: 19dB
    Mobile network time and date: 22/01/05,17:46:04+04
    PDP context info 1:
      CID:                0
      PDN ID:             0
      PDP context active: yes
      PDP type:           IP
      APN:                cellular.firmwave.gdsp
      IPv4 MTU:           1500
      IPv4 address:       x.y.z.zz
      IPv6 address:       ::
      IPv4 DNS address:   a.b.c.cc, a.b.c.cc
      IPv6 DNS address:   ::, ::
    PPP carrier ON
    RRC mode: Idle
    Dial up (IPv4) connection up
    RRC mode: Connected
    From my PC:
    ➜  ~ sudo pppd -detach /dev/ttyACM0 115200 noauth nocrtscts local noccp debug
    using channel 5
    Using interface ppp0
    Connect: ppp0 <--> /dev/ttyACM0
    sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x14e69c84> <pcomp> <accomp>]
    rcvd [LCP ConfRej id=0x1 <asyncmap 0x0> <magic 0x14e69c84> <pcomp> <accomp>]
    sent [LCP ConfReq id=0x2]
    rcvd [LCP ConfAck id=0x2]
    rcvd [LCP ConfReq id=0x1 <mru 1500>]
    sent [LCP ConfAck id=0x1 <mru 1500>]
    sent [LCP EchoReq id=0x0 magic=0x0]
    sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0>]
    rcvd [IPCP ConfReq id=0x1 <addr x.y.z.zz> <ms-dns1 a.b.c.cc> <ms-dns2 a.b.c.cc>]
    sent [IPCP ConfRej id=0x1 <ms-dns1 a.b.c.cc> <ms-dns2 a.b.c.cc>]
    rcvd [IPV6CP ConfReq id=0x1 <addr fe80::0000:5eff:fe00:5381>]
    Unsupported protocol 'IPv6 Control Protocol' (0x8057) received
    sent [LCP ProtRej id=0x3 80 57 01 01 00 0e 01 0a 00 00 5e ff fe 00 53 81]
    rcvd [LCP EchoRep id=0x0 magic=0x0]
    rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>]
    sent [IPCP ConfReq id=0x2 <addr 0.0.0.0>]
    rcvd [IPCP ConfReq id=0x2 <addr x.y.z.zz>]
    sent [IPCP ConfAck id=0x2 <addr x.y.z.zz>]
    rcvd [LCP CodeRej id=0x3 c0 21 08 03 00 14 80 57 01 01 00 0e 01 0a 00 00 5e ff]
    LCP: Rcvd Code-Reject for code 192, id 33
    rcvd [IPCP ConfNak id=0x2 <addr x.y.z.zz>]
    sent [IPCP ConfReq id=0x3 <addr x.y.z.zz>]
    rcvd [IPCP ConfAck id=0x3 <addr x.y.z.zz>]
    local  IP address x.y.z.zz
    remote IP address x.y.z.zz
    Script /etc/ppp/ip-up started (pid 8511)
    Script /etc/ppp/ip-up finished (pid 8511), status = 0x0
    sent [LCP ProtRej id=0x4 80 57 01 01 00 0e 01 0a 00 00 5e ff fe 00 53 81]
    rcvd [LCP CodeRej id=0x4 c0 21 08 04 00 14 80 57 01 01 00 0e 01 0a 00 00 5e ff]
    sent [LCP ProtRej id=0x5 80 57 01 01 00 0e 01 0a 00 00 5e ff fe 00 53 81]
    rcvd [LCP CodeRej id=0x5 c0 21 08 05 00 14 80 57 01 01 00 0e 01 0a 00 00 5e ff]
    2. I made ping to time.google.com without success:
    ~ ping -I ppp0 time.google.com
    PING  (216.239.35.4) from x.y.z.zz ppp0: 56(84) bytes of data.
    ^C
    ---  ping statistics ---
    10 packets transmitted, 0 received, 100% packet loss, time 9224ms
    3. From modem shell I executed ping cmd:
    mosh:~$ ping
    Usage: ping [optional options] -d destination
    mandatory options:
      -d, --destination, [str] Name or IP address
    optional options:
      -t, --timeout, [int]     Ping timeout in milliseconds
      -c, --count, [int]       The number of times to send the ping request
      -i, --interval, [int]    Interval between successive packet transmissions
                               in milliseconds
      -l, --length, [int]      Payload length to be sent
      -I, --cid, [int]         Use this option to bind pinging to specific CID.
                               See link cmd for interfaces
      -6, --ipv6,              Force IPv6 usage with the dual stack interfaces
      -r, --rai                Set RAI options for ping socket. In order to use RAI,
                               it must be enabled with 'link rai' command.
      -h, --help,              Shows this help information
    RRC mode: Idle
    RRC mode: Connected
    RRC mode: Idle
    and then once again I made pink from my P
    ➜  ~ ping -I ppp0 time.google.com
    From 198.18.210.132 (198.18.210.132) icmp_seq=0 Destination Host Unreachable
    ^C
    8 packets transmitted, 0 received, +8 errors, 100% packet loss, time 7011ms
    4. I executed from modem shell ping time.google.com
    mosh:~$ ping -d time.google.com
    Initiating ping to: time.google.com
    RRC mode: Connected
    after that step I was able to ping from PC with success
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=1 ttl=253 time=257 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=2 ttl=253 time=871 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=3 ttl=253 time=183 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=4 ttl=253 time=302 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=5 ttl=253 time=139 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=6 ttl=253 time=1121 ms
    64 bytes from time2.google.com (216.239.35.4): icmp_seq=7 ttl=253 time=158 ms
    ^C
    7 packets transmitted, 7 received, 0% packet loss, time 6025ms
    Are modem shell ping cmd and ppp correlated somehow or am I doing something wrong?
    Adam
  • Hi Adam,
    While the ppp connection is up, pinging from the shell isn't supported.
    That being said, it's strange that this made the PC side ping work.
    Is this behavior consistent on your end? If you reset the board, re-enable the ppp connection on the PC side, and do a "ping -I ppp0 time.google.com", does it still reply with destination unreachable?
    Håkon
    sorry for late response. I've made tests.
    1. Ping from shell is not working for me.
    RRC mode: Connected
    getaddrinfo(dest) error: -11
    Cannot resolve remote host
    mosh:~$ ping -d 216.239.35.0
    Initiating ping to: 216.239.35.0
    Source IP addr: x.y.z.zz
    Destination IP addr: 216.239.35.0
    send() failed: (-22)
    Ping statistics for 216.239.35.0:
        Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
    Pinging DONE
    I made resets and sent cmd again without succes.
    2. Reset of the board doesn't help for ping from PC. In both cases to get ping from PC working I need to execute ping cmd from mosh shell
    When I issue cmd ping -I ppp0 216.239.35.0 it hangs after printing
    PING 216.239.35.0 (216.239.35.0) from 100.67.125.106 ppp0: 56(84) bytes of data.
    till I issue ping on mosh shell. After executing this cmd it (PC shell) starts printing
    64 bytes from 216.239.35.0: icmp_seq=17 ttl=253 time=169 ms
    64 bytes from 216.239.35.0: icmp_seq=18 ttl=253 time=167 ms
    64 bytes from 216.239.35.0: icmp_seq=19 ttl=253 time=227 ms
    Adam
  • Hi Adam,
    Thank you for the detailed log and description.
    I tried to recreate this on my end, but I am unfortunately not able to do so. I will still report this back to the modem_shell team, so that they are aware of this.
    I have been talking to the team, and they mentioned that some instabilities have been observed while using the usb-uart bridge on the nRF DK, so they recommended that one uses a dedicated usb/uart bridge for this. However, the behavior that you're seeing seems to be related towards network rather than communication issues, so not likely going to help your specific scenario.
    Håkon
