SPIM3 not work standalone.
nRF52804 SPIM3 not work.
(SCLK/MOSI not output)
However, if I debug it using jlink, it works.
My environment is
nRF52840-DK(PCA10056/v1.0.0)
nRF52 SDK 17.0.2
My program is
	/* SCK */
	nrf_gpio_pin_clear(SPIM_CLK_PIN);
	nrf_gpio_cfg(SPIM_CLK_PIN,
						NRF_GPIO_PIN_DIR_OUTPUT,
						NRF_GPIO_PIN_INPUT_CONNECT,
						NRF_GPIO_PIN_NOPULL,
						NRF_GPIO_PIN_S0S1,
						NRF_GPIO_PIN_NOSENSE);
	/* MOSI */
	nrf_gpio_pin_clear(SPIM_MOSI_PIN);
	nrf_gpio_cfg_output(SPIM_MOSI_PIN);
	/* MISO */
	nrf_gpio_cfg_input(SPIM_MISO_PIN, (nrf_gpio_pin_pull_t)NRFX_SPIM_MISO_PULL_CFG);
	/* SS */
	nrf_gpio_pin_set(SPIM_SS_PIN);
	nrf_gpio_cfg_output(SPIM_SS_PIN);
    NRFX_IRQ_DISABLE(TARGET_SPIM_IRQ);
	SpimReg.ENABLE = SPIM_ENABLE_ENABLE_Enabled << SPIM_ENABLE_ENABLE_Pos;
	SpimReg.TASKS_STOP = 1;
	SpimReg.PSEL.SCK = SPIM_CLK_PIN;
	SpimReg.PSEL.MOSI = SPIM_MOSI_PIN;
	SpimReg.PSEL.MISO = SPIM_MISO_PIN;
	SpimReg.FREQUENCY = SPIM_FREQUENCY_FREQUENCY_K125;
	SpimReg.RXD.PTR = uint32_t(m_recv_buff),
	SpimReg.RXD.MAXCNT = 2;
	SpimReg.RXD.LIST = 0;
	SpimReg.TXD.PTR = uint32_t(m_send_buff),
	SpimReg.TXD.MAXCNT = 2;
	SpimReg.TXD.LIST = 0;
	SpimReg.CONFIG = 0; /* active-high / Leading / MsbFirst */
	SpimReg.ORC = 0x00;
	SpimReg.EVENTS_END = 0;
	SpimReg.TASKS_START = 1;
	while ( SpimReg.EVENTS_END == 0);
EVENT_END is done.(Maybe the process is finished )
But SCLK and MOSI not output.
  • PROJECT_NAME     := ble_app_hrs_freertos_pca10056_s140
    TARGETS          := nrf52840_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../../..
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52840_xxaa.out: \
      LINKER_SCRIPT  := ble_app_hrs_freertos_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52840.S \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_uart.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer_freertos.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/crc16/crc16.c \
      $(SDK_ROOT)/components/libraries/fds/fds.c \
      $(SDK_ROOT)/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/atomic_flags/nrf_atflags.c \
      $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
      $(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/sensorsim/sensorsim.c \
      $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52840.c \
      $(SDK_ROOT)/external/freertos/source/croutine.c \
      $(SDK_ROOT)/external/freertos/source/event_groups.c \
      $(SDK_ROOT)/external/freertos/source/portable/MemMang/heap_1.c \
      $(SDK_ROOT)/external/freertos/source/list.c \
      $(SDK_ROOT)/external/freertos/portable/GCC/nrf52/port.c \
      $(SDK_ROOT)/external/freertos/portable/CMSIS/nrf52/port_cmsis.c \
      $(SDK_ROOT)/external/freertos/portable/CMSIS/nrf52/port_cmsis_systick.c \
      $(SDK_ROOT)/external/freertos/source/queue.c \
      $(SDK_ROOT)/external/freertos/source/stream_buffer.c \
      $(SDK_ROOT)/external/freertos/source/tasks.c \
      $(SDK_ROOT)/external/freertos/source/timers.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
      $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \
      $(PROJ_DIR)/main.c \
      $(PROJ_DIR)/spim.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/ble/peer_manager/auth_status_tracker.c \
      $(SDK_ROOT)/components/ble/common/ble_advdata.c \
      $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatt_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatts_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/id_manager.c \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr/nrf_ble_qwr.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_data_storage.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_database.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_id.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_manager_handler.c \
      $(SDK_ROOT)/components/ble/peer_manager/pm_buffer.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_dispatcher.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_manager.c \
      $(SDK_ROOT)/external/utf_converter/utf.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas/ble_bas.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis/ble_dis.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs/ble_hrs.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_freertos.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_spim.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(PROJ_DIR)/config \
      $(SDK_ROOT)/components/nfc/ndef/generic/message \
      $(SDK_ROOT)/components/nfc/t2t_lib \
      $(SDK_ROOT)/components/nfc/t4t_parser/hl_detection_procedure \
      $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
      $(SDK_ROOT)/components/nfc/platform \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
      $(SDK_ROOT)/components/libraries/pwm \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
      $(SDK_ROOT)/components/libraries/usbd/class/msc \
      $(SDK_ROOT)/components/libraries/usbd/class/hid \
      $(SDK_ROOT)/modules/nrfx/hal \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser \
      $(SDK_ROOT)/components/libraries/log \
      $(SDK_ROOT)/components/ble/ble_services/ble_gls \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/nfc/ndef/text \
      $(SDK_ROOT)/components/libraries/mutex \
      $(SDK_ROOT)/components/libraries/gpiote \
      $(SDK_ROOT)/components/libraries/bootloader/ble_dfu \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/common \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/nfc/ndef/generic/record \
      $(SDK_ROOT)/components/nfc/t4t_parser/cc_file \
      $(SDK_ROOT)/components/ble/ble_advertising \
      $(SDK_ROOT)/external/utf_converter \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
      $(SDK_ROOT)/modules/nrfx/drivers/include \
      $(SDK_ROOT)/components/libraries/experimental_task_manager \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
      $(SDK_ROOT)/components/softdevice/s140/headers/nrf52 \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/le_oob_rec \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/libraries/pwr_mgmt \
      $(SDK_ROOT)/external/freertos/portable/GCC/nrf52 \
      $(SDK_ROOT)/components/ble/ble_dtm \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_lls \
      $(SDK_ROOT)/components/libraries/hardfault/nrf52 \
      $(SDK_ROOT)/components/libraries/bsp \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ac_rec \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas \
      $(SDK_ROOT)/components/libraries/mpu \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
      $(SDK_ROOT)/components/libraries/slip \
      $(SDK_ROOT)/components/libraries/delay \
      $(SDK_ROOT)/components/libraries/csense_drv \
      $(SDK_ROOT)/components/libraries/memobj \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
      $(SDK_ROOT)/components/libraries/low_power_pwm \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser \
      $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/libraries/svc \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/components/libraries/cli \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
      $(SDK_ROOT)/components/ble/ble_services/ble_hts \
      $(SDK_ROOT)/components/libraries/crc16 \
      $(SDK_ROOT)/components/nfc/t4t_parser/apdu \
      $(SDK_ROOT)/external/freertos/config \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/external/freertos/portable/CMSIS/nrf52 \
      ../config \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc \
      $(SDK_ROOT)/components/libraries/csense \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/ecc \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
      $(SDK_ROOT)/components/libraries/hci \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/components/softdevice/s140/headers \
      $(SDK_ROOT)/integration/nrfx \
      $(SDK_ROOT)/components/nfc/t4t_parser/tlv \
      $(SDK_ROOT)/components/libraries/sortlist \
      $(SDK_ROOT)/components/libraries/spi_mngr \
      $(SDK_ROOT)/components/libraries/led_softblink \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser \
      $(SDK_ROOT)/components/libraries/sdcard \
      $(SDK_ROOT)/components/nfc/ndef/parser/record \
      $(SDK_ROOT)/modules/nrfx/mdk \
      $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus \
      $(SDK_ROOT)/components/libraries/twi_mngr \
      $(SDK_ROOT)/components/ble/ble_services/ble_hids \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_oob_advdata \
      $(SDK_ROOT)/components/nfc/t2t_parser \
      $(SDK_ROOT)/external/freertos/source/include \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_msg \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/libraries/sensorsim \
      $(SDK_ROOT)/components/nfc/t4t_lib \
      $(SDK_ROOT)/components/ble/peer_manager \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/components/libraries/ringbuf \
      $(SDK_ROOT)/components/ble/ble_services/ble_tps \
      $(SDK_ROOT)/components/nfc/ndef/parser/message \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis \
      $(SDK_ROOT)/components/nfc/ndef/uri \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr \
      $(SDK_ROOT)/components/libraries/gfx \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/modules/nrfx \
      $(SDK_ROOT)/components/libraries/twi_sensor \
      $(SDK_ROOT)/integration/nrfx/legacy \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ep_oob_rec \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_lib \
      $(SDK_ROOT)/components/libraries/crypto \
      $(SDK_ROOT)/components/ble/ble_racp \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/nfc/ndef/launchapp \
      $(SDK_ROOT)/components/libraries/atomic_flags \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/hs_rec \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ac_rec_parser \
      $(SDK_ROOT)/components/libraries/stack_guard \
      $(SDK_ROOT)/components/libraries/log/src \
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    OPT = -O0 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBOARD_PCA10056
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DFREERTOS
    CFLAGS += -DNRF52840_XXAA
    CFLAGS += -DNRF_SD_BLE_API_VERSION=7
    CFLAGS += -DS140
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DBOARD_PCA10056
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DFREERTOS
    ASMFLAGS += -DNRF52840_XXAA
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=7
    ASMFLAGS += -DS140
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52840_xxaa: CFLAGS += -D__HEAP_SIZE=1024
    nrf52840_xxaa: CFLAGS += -D__STACK_SIZE=2048
    nrf52840_xxaa: ASMFLAGS += -D__HEAP_SIZE=1024
    nrf52840_xxaa: ASMFLAGS += -D__STACK_SIZE=2048
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52840_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52840_xxaa
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    # Flash the program
    flash: default
    	@echo Flashing: $(OUTPUT_DIRECTORY)/nrf52840_xxaa.hex
    	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52840_xxaa.hex --sectorerase
    	nrfjprog -f nrf52 --reset
    # Flash softdevice
    flash_softdevice:
    	@echo Flashing: s140_nrf52_7.2.0_softdevice.hex
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    /* Linker script to configure memory regions. */
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
      FLASH (rx) : ORIGIN = 0x27000, LENGTH = 0xd9000
      RAM (rwx) :  ORIGIN = 0x20005978, LENGTH = 0x3a688
    SECTIONS
    SECTIONS
      . = ALIGN(4);
      .mem_section_dummy_ram :
      .cli_sorted_cmd_ptrs :
        PROVIDE(__start_cli_sorted_cmd_ptrs = .);
        KEEP(*(.cli_sorted_cmd_ptrs))
        PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
      } > RAM
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
      .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(SORT(.log_dynamic_data*)))
        PROVIDE(__stop_log_dynamic_data = .);
      } > RAM
      .log_filter_data :
        PROVIDE(__start_log_filter_data = .);
        KEEP(*(SORT(.log_filter_data*)))
        PROVIDE(__stop_log_filter_data = .);
      } > RAM
    } INSERT AFTER .data;
    SECTIONS
      .mem_section_dummy_rom :
      .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
      } > FLASH
      .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
      } > FLASH
      .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
      } > FLASH
      .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
      } > FLASH
      .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
      } > FLASH
        .nrf_queue :
        PROVIDE(__start_nrf_queue = .);
        KEEP(*(.nrf_queue))
        PROVIDE(__stop_nrf_queue = .);
      } > FLASH
        .nrf_balloc :
        PROVIDE(__start_nrf_balloc = .);
        KEEP(*(.nrf_balloc))
        PROVIDE(__stop_nrf_balloc = .);
      } > FLASH
        .cli_command :
        PROVIDE(__start_cli_command = .);
        KEEP(*(.cli_command))
        PROVIDE(__stop_cli_command = .);
      } > FLASH
      .crypto_data :
        PROVIDE(__start_crypto_data = .);
        KEEP(*(SORT(.crypto_data*)))
        PROVIDE(__stop_crypto_data = .);
      } > FLASH
      .pwr_mgmt_data :
        PROVIDE(__start_pwr_mgmt_data = .);
        KEEP(*(SORT(.pwr_mgmt_data*)))
        PROVIDE(__stop_pwr_mgmt_data = .);
      } > FLASH
      .log_const_data :
        PROVIDE(__start_log_const_data = .);
        KEEP(*(SORT(.log_const_data*)))
        PROVIDE(__stop_log_const_data = .);
      } > FLASH
      .log_backends :
        PROVIDE(__start_log_backends = .);
        KEEP(*(SORT(.log_backends*)))
        PROVIDE(__stop_log_backends = .);
      } > FLASH
    } INSERT AFTER .text
    INCLUDE "nrf_common.ld"
    Makefile and ldscript.
    Where should I modify it?
  • Is this problem resolved? I have the same issue with a custom board with nrf52840. After programming it via SWD it works, but after the first reset SPI3 no longer works. Other peripherals are working so the MCU is not stuck in hardfault. SPI2 also works appropriately, only SPI3 has this issue.
  • No.
    Maybe nordic-semi will leave this issue alone.
    As a countermeasure, SPIM3 works by enabling UARTE temporarily.
