Softdevice / Whitelist Issues
We are attempting to deploy a system consisting of one nRF52840 devkit running the multi-NUS example app, and over a dozen custom boards based on the nRF52832. It all works fine at my facility, which is very much RF-quiet. When attempting to bring up the system at the customer site, we appear to be getting the custom units captured by other BLE central devices. Attempting to track those down, but only partially successful. The custom board is using the 112 softdevice. What is the difference between 112 and 132? I have a vague recollection that with 132 we could be connected by multiple devices whereas 112 was restricted to a single connection at a time. If that is the case, I want to try to change to the 132 device. Surely there is a straightforward way within SES to do that?
I am also looking for a way to have our device only allow connections from our central device. I remember seeing something like that, though I really don't want to go the full Bonding route (but may have to).
Suggestions very welcome! The customer is in a bit of a panic because we're setting up for a big demonstration to customer's customer this Friday.
Steve Hendrix
  • Hi Steve,
    I see now that you have references to Zephyr (so nRF Connect SDK), but earlier in this thread you have made references to SoftDevice and nRF5 SDK Code. Do you use the nRF5 SDK for the peripherals and the nRF Connect SDK for the central? That in itself is no problem, I just want to get a better understanding. With "Multi NUS", are you referring to this project from this blog post? Is this your central?
    SteveHx said:
    I have discovered that the 52840 multi-NUS randomly throws an error and reboots:
    ASSERTION FAIL [conn] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/gatt.c:4437
                           invalid parameters
    Which nRF Connect SDK version are you using? based on the assert line number I am guessing 1.6.x, so I will assume that for now.
    The assert in zephyr/subsys/bluetooth/host/gatt.c:4437 is checking that the first parameter (struct bt_conn *conn) is not NULL, so as you get this assert it means you passed NULL / 0 to the call to bt_gatt_subscribe() for some reason. You need to review and/or debug your application to se how this can happen.
    There is clearly a bug you see here, but there could also be other issues. As you use as may as 15-20 peripheral connected to a single central, that means it must handle and find time to a lot of concurrent connections (in addition to scanning). Which connection parameters do you use? That is essential here with so many devices. You typically need long connection intervals and short event lengths to get this working. You probably also want a long supervision timeout.
    SteveHx said:
    We also need a way, either by modifying the source code, or thru the USB link, to cause multi-NUS to periodically rescan for units that may have been missed.
    Looking at the multi NUS code from the blog, I see that it generally always scans except for during service discovery, so you should not need to explicitly start it. If you want to, you can add code for that, but there is no code in the example I am looking at that lets you control this from USB or UART, so you must add that (and decide how you want it to work).
    Einar
  • I'm now back from my trip to the customer site and getting caught up on emails. It appears the problem was repeated collisions due to the amount of traffic and update interval. I fixed it for the upcoming demo by extending the update interval and randomizing it so any two units don't repeatedly collide with one another. Thank you very much for all the help, and the reminder that I need to download and learn about the new nRF Connect SDK.
    You can find some examples which I did on the whitelist at central and peripheral role.
    Both examples are not using bonding.  Just the MAC address on whitelist table.
    Peripheral Role
    jimmywongiot.com/.../
    Central Role
    Jimmy
