"Couldn't find Zephyr root" both SEGGER and VsCode
Hello all,
Lost my VM that had a working installation and just setting everything back up.
After installing SDK 1.8.0 and all of the extensions for VsCode. Now both SEGGER and VSCode cannoot find the Zephry root and I cannot find it on disk?
This was not a problem in the past, any ideas?
Thanks
Edit: Another problem... like all of the examples are missing?? searched for serial_lte_modem and it comes up with nothing. Even just searching serial, or application comes up with nothing useful?
Edit2: I installed the most recent 3 releases and none have a zephyr folder anymore?!?!?
  • From your root application folder in a bash, can you successfully perform a:
    west flash --erase
    Mr.Newlove said:
    Yea, pretty non-specific. What I have been doing is creating a folder in the same project called "Boards" and then creating a new board called "basic_serial_modem_ns" using the board wizard. I can record a video of this whole process tomorrow if that helps?
    Yes, that would be great. I have tested to create a custom board based on the nRF9160 non-secure myself with the wizard in VS Code. I stored it in my_root_application\boards and it seems to work fine, so no ”The system cannot find the file specified” here. I get build errors for sure, but they are expected without any modifications of the board files itself.
    That might not help you too much at this point, but at least it seems to look like that this approach should work.
    Mr.Newlove said:
    Another issue I ran into today is I can't seem to get the GPS to actually report a location, but I was waiting until our fully assembled boards to show up since the one I am working with I hand-assembled and I have had nothing but issues because its really hard to get a perfect solder job by hand with the 9160 chip
    Regarding this issue I would like to ask you to create a new case when relevant, as this might go a little bit too far off topic.
    Markus
    user@DESKTOP-END89DQ MINGW64 /c/ncs/MyApps/serial_lte_modem_uart0_gps
    $ west flash --erase
    -- west flash: rebuilding
    [0/21] Performing build step for 'spm_subimage'
    ninja: no work to do.
    [1/5] Performing build step for 'mcuboot_subimage'
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: mass erase requested
    Using board 960031669
    -- runners.nrfjprog: Flashing file: C:\ncs\MyApps\serial_lte_modem_uart0_gps\build\zephyr\merged.hex
    Parsing image file.
    Verified OK.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 960031669 flashed successfully.
    And the nrf9160 is not talking, but if I flash using the Programmer v2.1.1 desktop app from the SDK it works fine?
    Here is the log from that:
    10:15:49.270	Recovering Application core
    10:15:52.814	Recovering Application core completed
    10:15:52.816	Device recovery completed
    10:15:52.816	Writing procedure starts for Application core
    10:15:52.960	Writing HEX to Application core
    10:15:53.297	Uploading image through JLink: 0%
    10:15:56.303	Uploading image through JLink: 100%
    10:15:56.497	Writing HEX to Application core completed
    10:15:56.497	Writing procedure ends for Application core
    10:15:56.499	Resetting device
    10:15:57.121	Resetting device completed
    10:15:57.124	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
    10:15:57.124	JLink OB firmware version J-Link OB-K22-NordicSemi compiled Jul 2 2021 10:44:28
    10:15:57.124	Device family NRF91
    10:15:57.125	Device version NRF9160_xxAA_REV2
    10:15:57.125	Board version PCA10090
    10:15:57.126	Modem detected
    10:15:57.126	Loading readback protection status for Application core
    10:15:57.552	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
    10:15:57.997	Parse memory regions for Application core
    10:15:57.999	Device is loaded and ready for further operation
    5270.merged.hex
    If it is helpful, this is the compiled and working hex file
    I will get this recorded sometime today, bit preoccupied atm.
    Yea, I am pretty sure its my fault anyway.
  • Hello Kyle,
    Well this is strange. But I’m not able to get the attached file to run on my DK neither. Could you try the following in a bash with your nRF9160 DK?
    cd ncs/nrf/applications/serial_lte_modem/
    west build -b nrf9160dk_nrf9160_ns -p
    west flash --erase
    Does this work?
    Markus
  • Well this is strange. But I’m not able to get the attached file to run on my DK neither. Could you try the following in a bash with your nRF9160 DK?
    Odd, as I said it works fine if I use the standalone loader. Keep in mind I am using different Rx/Tx pins so it wont talk on the standard DK
    Odd thing, went to test this again after updating the SDK and I am getting different errors now to do with the kconf, but I think those are all solvable. Think its because I didn't actually configure the serial port pins for the new board so it doesn't know what to do.
    Does this work?
    Peculiar, yes that works, but not from within VSCode using the SDK tools
    From bash:
    Parsing image file.
    Verified OK.
    Applying pin reset.
    From VSCode:
    Executing task: nRF Connect: Flash serial_lte_modem_uart0_gps/build (active) <
    Flashing build to undefined
    west flash -d c:\ncs\MyApps\serial_lte_modem_uart0_gps\build --skip-rebuild -r nrfjprog --snr 960031669 --erase
    Parsing image file.
    Verified OK.
    Applying pin reset.
    Edit: I have no idea why, but now it works, I didnt change anything, maybe updating the SDK the other day fixed it?
