ADVERTISE ISSUE IN DEBUG
    i am working on nRF52832. everything is working fine . only problem is advertise does not start in debug mode.
  • Hello Brandon,
    Brandon_sbz said:
    Thank you for your reply!
    No problem at all, I am happy to help!
    Brandon_sbz said:
    My nRF52832 is advertising properly (I can see it with the nRF Connect mobile app or with a sniffer), but as soon as I enter in debug mode, I no longer see any advertisements.
    I'm sure no reset was triggered because I'm logging a variable which is continuously incremented so my SW seems to be running correctly.
    The new board has the internal LDO setup while the other boards have the DC/DC regulator setup. I also added an RF connector on the transmission line just before the matching network components. Those are the only changes I made.
    Thank you for the clarifications here, it is very helpful.
    We might need to take a look at the changes you made to the circuitry here, in which case you should open a separate private ticket so that you can share the schematics confidentially (unless you are fine with sharing them publicly in this ticket). Would this be fine with you?
    I suspect that the change to the hardware has not been successful, so that the radio is no longer able to transmit as it is supposed to, because of it.
    Karl
  • Actually, could you also confirm if the new board ever has been able to communicate properly with another board / the sniffer?
    Reading your initial comment again I get the understanding that the new board advertises properly when it is not in debug mode, is this correct?
    Karl
