Issues with setting up i2c for custom project in nrf connect SDK (VScode)
I am trying to do my own i2c read/write from a sensor, and I followed the twim example available with the SDK.
When I build the project, I get errors wherever I have I2C related macros:
\ncs\v1.7.0\zephyr\include\devicetree.h:177:36: error: 'DT_N_NODELABEL_i2c_addr_REG_IDX_0_VAL_ADDRESS' was not declared in this scope
  177 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
\ncs\v1.7.0\zephyr\include\devicetree.h:2542:24: note: in definition of macro 'DT_CAT'
 2542 | #define DT_CAT(a1, a2) a1 ## a2
\ncs\v1.7.0\zephyr\include\devicetree.h:1355:30: note: in expansion of macro 'DT_REG_ADDR_BY_IDX'
 1355 | #define DT_REG_ADDR(node_id) DT_REG_ADDR_BY_IDX(node_id, 0)
And so on. Essentially whenever I use these macro definitions in code it also spits out an error.
I made sure to define the device overlay and setup the i2c similar to the tutorial. The address of my sensor is 0x32:
&i2c1 {										/* a */
	compatible = "nordic,nrf-twim";			/* b */
	status = "okay";						/* c */
	clock-frequency = <100000>;				/* d */
	twis_device1:nRF52840@32 {				/* e */
		// device compatible				/* f */
		label = "zmod addr 0x32";			/* g */
       	reg = <0x32>;						/* h */
I also made sure to enable i2c in proj.conf:
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
  • Solved it!
    Somewhere else in the code, I had used the i2c_write() function, and I passed the address of the device which I had defined in overlay. However, I did not use the node name, and used the actual address instead. This caused the issue:
    i2c_write(nrfx_twis_dev1, &reg_addr, sizeof(reg_addr), DT_REG_ADDR(DT_NODELABEL(some_address)))
    although some_address was the same address I had defined in the overlay, I should have used the node name. The correct code is the following:
    i2c_write(nrfx_twis_dev1, &reg_addr, sizeof(reg_addr), DT_REG_ADDR(DT_NODELABEL(twis_device1)))
    Where twis_device1 is defined in the overlay.
