On the nRF5340 P0.00 and P0.01 are used for the 32.768 kHz crystal by default and are not available as GPIO on the connectors.
how to remap this pins to gpio?
Ensure you have something like this to stop the pins being configured to use a crystal instead of i/o; this list is for the SDK, there should be something akin to this in nRFConnect:
#define CLOCK_CONFIG_LF_SRC 0 #define NRF_SDH_CLOCK_LF_SRC 0 #define NRF_SDH_CLOCK_LF_RC_CTIV 16 #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2 #define NRF_SDH_CLOCK_LF_ACCURACY 1 // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
This might also help, though this is for the nRF52832
// 32kHz Osc pins can be used as GPIOs or 32kHz Oscillator, special case
if ( (PinId == PIN_XL2) && (NRF_CLOCK->LFCLKSRC & 0x000001) ) return "RTC-OSC-OUT";
if ( (PinId == PIN_XL1) && (NRF_CLOCK->LFCLKSRC & 0x000001) ) return "RTC-OSC-IN";Hi,
thanks, but it do not work
Priyanka said:Are you using a custom board or the nRF5340DK?
Also, pins P0.00 and P0.01 are used for 32kHz crystal and the P1.00 and P1.01 are digital I/O pins which can be used as GPIO pins.
As for P1.02, what do you wish to use it for?
Could you answer these?
-Priyanka
Hi
I use CONFIG_NFCT_PINS_AS_GPIOS=y in prj.conf
I am sorry but I am confused about your query here.
1. Kindly tell me which pins you wish to use among these -> P0.00, P0.01, P0.02, P1.00, P1.01, P1.02
2. The code CONFIG_NFCT_PINS_AS_GPIOS is used to help change an NFC pin to a normal GPIO and on the nRF5340 DK, the P0.02 and P0.03 are used for this and you should follow these instructions too.
Priyanka
