Button config for wake up from deep sleep (not waking up 'sometimes')
So, I have a working BLE project on the nRF52840 Dongle and I developed and debugged everything on the DevKit, using Zephyr/nRF Connect for VS Code. From there, I attempted to set up a separate thread that times-out after x seconds of advertising (if no connection is established) and turns off the device, as in the "system_off" sample:
pm_power_state_force((struct pm_state_info){PM_STATE_SOFT_OFF, 0, 0});
I also configured one of the DevKit's buttons to wake up / turn on the device (as in the "system_off" sample):
#include <hal/nrf_gpio.h>
/* Configure to generate PORT event (wakeup) on button 1 press. */
nrf_gpio_cfg_input(DT_GPIO_PIN(DT_NODELABEL(button0), gpios),
		   NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_sense_set(DT_GPIO_PIN(DT_NODELABEL(button0), gpios),
		   NRF_GPIO_PIN_SENSE_LOW);
When I flashed and tested the functionality on the DevKit it worked perfectly fine, however, when I flashed and tried on the Dongle, pressing the button would not wake up the device. I figured out it might have to do with the library used for some reason, hal/nrf_gpio library does not seem to work on the Dongle ?? I managed to solve the problem configuring the button with the following code (regular drivers/gpio library):
#include <drivers/gpio.h>
#define WAKEUP_BTN_ALIAS sw0
#define SW_NODE DT_ALIAS(WAKEUP_BTN_ALIAS)
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW_NODE, gpios, {0});
// Configure to generate PORT event (wakeup) on button press.
gpio_pin_configure_dt(&button, GPIO_INPUT);
gpio_pin_interrupt_configure_dt(&button, GPIO_INT_LOW_0);
This way it does work on both the DevKit AND the Dongle, however, I realized after a couple of days that the button was not waking up the device. I thought the battery was dead or that maybe I had a faulty connection. I troubleshooted without any success, only after disconnecting and reconnecting the battery, the device then turns on normally, and after timing-out (turning off), and pressing the button, the device wakes up normally.
I have now been using the device / testing my project for the past 2 weeks and have encountered this issue at least 6 times already (on Dongle), for no apparent reason, the press of the button will not wake up the device, and I'd have to open my project enclosure, disconnect and reconnect the battery to start using it again. This problem also happened twice on the DevKit.
I really have no idea how to troubleshoot this, since the device is in deep sleep mode if I understand correctly, although the GPIO module stays on... The only reason I can think of is that maybe I am missing some power management or gpio configuration. The weird thing is that 99% of the time, time-out/turn-off and wake-up button work fine. I did add these lines on the prj.conf file.
CONFIG_GPIO=y
# Power Management Config
CONFIG_PM=y
CONFIG_PM_DEVICE=y
I would really like to try configuring the button using the hal/nrf_gpio library and using the cfg_sense_set() function, but, as mentioned, the same code properly compiles and works on the DevKit, I am able to also flash it on the Dongle but the button does not work. Am I missing something Dongle-specific in order to be able to use the system_off sample on it?
Thank you in advance.
Alex Fernandez.
  • Hi Alex,
    Thanks for letting me know and keeping us updated.
  • Hello again,
    I've been testing my prototype for quite some time now and I haven't encountered this problem anymore where pressing the button 'sometimes' does not wake up the device.
    Although I would like to better understand the cause of the problem, configuring the button through the nrf_gpio library instead of the generic gpio one seems to solve the issue, although also for some reason the devicetree by default does not point to the right pin and the above code needs to also be added to the .overlay file.
    Thank you for your help!
    Kind regards.
  • Hi Alex and Einar,
    Thanks to both of you for this solution. By hardcoding pin 38, I as able to get the dongle to wake up on button press.
    nrf_gpio_cfg_input(38, NRF_GPIO_PIN_PULLUP); // Button 1 is P1.06 which is 38
    nrf_gpio_cfg_sense_set(38, NRF_GPIO_PIN_SENSE_LOW);
    However, if I use Alex's more flexible approach of adding this to the overlay, button0 (sw0) no longer worked for me. The DTS file for the dongle specifies button0 at pin 6, so why specifying it as pin 38 works remains a mystery to me.
    That being said, I solved it by building on Alex's solution and defining a separate power button in the nrf52840 Dongle overlay.
        aliases {
            powerbutton0 = &power0;
        buttons {
            compatible = "gpio-keys";
            power0: power_0 {
                gpios = <&gpio1 38 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
                label = "Power switch 0";
    #define POWER0_NODE DT_ALIAS(powerbutton0)
    static const struct gpio_dt_spec power0 = GPIO_DT_SPEC_GET_OR(POWER0_NODE, gpios, {0});
    nrf_gpio_cfg_input(power0.pin, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_sense_set(power0.pin, NRF_GPIO_PIN_SENSE_LOW);
    In the overlay for the nrf52840 DK I just pointed the powerbutton0 alias at button3, which is the button I wanted to use.
    Thanks for the original solution. Saved me a load of time.
    Best,
    Steve
  • Hi Alex,
    Setting this constraint prevents the power management module from entering system off automatically, as it could otherwise do for very long delays (the PM state id decided based on the number of tics to the next scheduled event).
