NRF5340 network core DFU with external flash
HI,
I'm trying to configure the MCUboot / Netboot with an external QSPI flash. I can do it for the APP core with MCUboot, however I get lost how it work with the NET core / Netboot. I can do this with storing update in internal flash but not external flash.
Looking into the "bootloader\mcuboot\boot\bootuil\src\loader.c", I found something strange, in this function:
static int
boot_validated_swap_type(struct boot_loader_state *state,
                         struct boot_status *bs)
    int swap_type;
    fih_int fih_rc = FIH_FAILURE;
    bool upgrade_valid = false;
#if defined(PM_S1_ADDRESS) || defined(CONFIG_SOC_NRF5340_CPUAPP)
    const struct flash_area *secondary_fa =
        BOOT_IMG_AREA(state, BOOT_SECONDARY_SLOT);
    struct image_header *hdr = (struct image_header *)secondary_fa->fa_off;
    uint32_t vtable_addr = 0;
    uint32_t *vtable = 0;
    uint32_t reset_addr = 0;
    /* Patch needed for NCS. Since image 0 (the app) and image 1 (the other
     * B1 slot S0 or S1) share the same secondary slot, we need to check
     * whether the update candidate in the secondary slot is intended for
     * image 0 or image 1 primary by looking at the address of the reset
     * vector. Note that there are good reasons for not using img_num from
     * the swap info.
    if (hdr->ih_magic == IMAGE_MAGIC) {
        vtable_addr = (uint32_t)hdr + hdr->ih_hdr_size;
        vtable = (uint32_t *)(vtable_addr);
        reset_addr = vtable[1];
#ifdef PM_S1_ADDRESS
        const struct flash_area *primary_fa;
        int rc = flash_area_open(flash_area_id_from_multi_image_slot(
                    BOOT_CURR_IMG(state),
                    BOOT_PRIMARY_SLOT),
                &primary_fa);
        if (rc != 0) {
            return BOOT_SWAP_TYPE_FAIL;
        /* Get start and end of primary slot for current image */
        if (reset_addr < primary_fa->fa_off ||
                reset_addr > (primary_fa->fa_off + primary_fa->fa_size)) {
            /* The image in the secondary slot is not intended for this image
            return BOOT_SWAP_TYPE_NONE;
#endif /* PM_S1_ADDRESS */
It try to get the image's "ih_magic" and "reset_addr" from "hdr" which eventually go to "state.imsg[0][1].area" (to determine if the update image is for APP or NET). When storing the update in internal flash, this is correctly pointed. But after I change it to external storage, this area points to the external storage's physical address, just like this: (I store the update in MX25R64, address 0x00)
So this function just get the ih_magic from the INTERNAL FLASH by using my external flash address (0x00), of course it will never get the "reset_addr" correctly, and always think my update image is APP core.
Is there anything I missed? Or any fix for this function?
