When I build CLI sample in nRF_Connect_SDK, I don't get any USB port for CLI.
I believe the sample is in default mode built for UART.
How to build this for USB, so that I can run my CLI on USB port for nrf52840_dongle.
I have removed my existing build folder and rebuild the application with the command "west build -b nrf52840dongle_nrf52840 -d build_nrf52840dongle_nrf52840 -- -DOVERLAY_CONFIG=overlay-usb.conf -DDTC_OVERLAY_FILE=usb.overlay"
It got successfully built.
➜ cli git:(cfedfdfa0) ✗ west build -b nrf52840dongle_nrf52840 -d build_nrf52840dongle_nrf52840 -- -DOVERLAY_CONFIG=overlay-usb.conf -DDTC_OVERLAY_FILE=usb.overlay
Including boilerplate (Zephyr base): /opt/nordic/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake
-- Application: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli
-- Using NCS Toolchain 1.8.0 for building. (/opt/nordic/ncs/v1.8.0/toolchain/cmake)
-- Zephyr version: 2.7.0 (/opt/nordic/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1
-- Found Python3: /opt/nordic/ncs/v1.8.0/toolchain/bin/python3 (found suitable exact version "3.9.6") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52840dongle_nrf52840
-- Cache files will be written to: /Users/bhumika/Library/Caches/zephyr
-- Found dtc: /opt/nordic/ncs/v1.8.0/toolchain/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/nordic/ncs/v1.8.0/toolchain)
-- Found BOARD.dts: /opt/nordic/ncs/v1.8.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
-- Found devicetree overlay: usb.overlay
-- Generated zephyr.dts: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/dts.cmake
warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
Parsing /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/Kconfig
Loaded configuration '/opt/nordic/ncs/v1.8.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
Merged configuration '/opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/prj.conf'
Merged configuration '/opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/overlay-usb.conf'
Configuration saved to '/opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: /opt/nordic/ncs/v1.8.0/toolchain/bin/arm-none-eabi-gcc
-- OpenThread Source Directory: /opt/nordic/ncs/v1.8.0/modules/lib/openthread
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Package Name: OPENTHREAD
-- Setting default package version: 69eb7030c
-- Package Version: 69eb7030c
CMake Warning at /opt/nordic/ncs/v1.8.0/zephyr/CMakeLists.txt:1662 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840
[1/794] Preparing syscall dependency handling
[38/794] Generating include/generated/driver-validation.h
/opt/nordic/ncs/v1.8.0/zephyr/scripts/gen_kobject_list.py:66: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
if LooseVersion(elftools.__version__) < LooseVersion('0.24'):
[39/794] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[137/794] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli.cpp.obj
[167/794] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/opt/nordic/ncs/v1.8.0/mbedtls/library/pkparse.c.obj
[170/794] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/opt/nordic/ncs/v1.8.0/mbedtls/library/platform_util.c.obj
[216/794] cd /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52...LE="nrf-config.h"" -P /opt/nordic/ncs/v1.8.0/modules/lib/openthread/etc/cmake/print.cmak
OPENTHREAD_CONFIG_ASSERT_ENABLE=1
OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0
OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0
OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1
OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1
OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0
OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0
OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1
OPENTHREAD_CONFIG_COAP_API_ENABLE=1
OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1
OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1
OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0
OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1
OPENTHREAD_CONFIG_DIAG_ENABLE=1
OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_ECDSA_ENABLE=1
OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1
OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1
OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1
OPENTHREAD_CONFIG_JOINER_ENABLE=1
OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1
OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1
OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1
OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1
OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1
OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1
OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1
OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0
PACKAGE_NAME=OPENTHREAD
OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1
OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
BUILD_VERSION=v2.7.0-ncs1
__LINUX_ERRNO_EXTENSIONS__
USE_PARTITION_MANAGER=0
__PROGRAM_START
NRF52840_XXAA
NRF_802154_ECB_PRIORITY=0
NRF_802154_SWI_PRIORITY=1
NRF_802154_ENCRYPTION_ENABLED=0
NRF_802154_SECURITY_WRITER_ENABLED=0
NRF_802154_IE_WRITER_ENABLED=0
NRF_802154_USE_RAW_API=1
NRF_802154_PENDING_SHORT_ADDRESSES=16
NRF_802154_PENDING_EXTENDED_ADDRESSES=16
NRF_802154_RX_BUFFERS=16
NRF_802154_CCA_CORR_LIMIT_DEFAULT=2
NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45
NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45
NRF_802154_CSMA_CA_ENABLED=1
NRF_802154_TX_STARTED_NOTIFY_ENABLED=1
NRF_802154_ACK_TIMEOUT_ENABLED=1
NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED
NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0
PSA_CRYPTO_SECURE
MBEDTLS_CONFIG_FILE=nrf-config.h
[367/794] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_local.cpp.obj
[686/794] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[687/794] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[787/794] Linking CXX executable zephyr/zephyr_prebuilt.elf
[790/794] Generating dev_handles.c
/opt/nordic/ncs/v1.8.0/zephyr/scripts/gen_handles.py:46: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
[793/794] Linking CXX executable zephyr/zephyr.elf
[794/794] Linking CXX executable zephyr/zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 505212 B 1020 KB 48.37%
SRAM: 108112 B 256 KB 41.24%
IDT_LIST: 0 GB 2 KB 0.00%
Yes, to flash the nrf52840_dongle I am using a tag connector and nrf52840dk_board as programmer.
I erased my existing nrf52840 dongle with "nrfjprog -e", and reflashed it using "west flash"
The following command appeared on flash:
➜ build_nrf52840dongle_nrf52840 git:(cfedfdfa0) ✗ west flash
-- west flash: rebuilding
[1/1] cd /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/...LE="nrf-config.h"" -P /opt/nordic/ncs/v1.8.0/modules/lib/openthread/etc/cmake/print.cmak
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
__PROGRAM_START
NRF52840_XXAA
PSA_CRYPTO_SECURE
-- west flash: using runner nrfjprog
Using board 683437999
-- runners.nrfjprog: Flashing file: /opt/nordic/ncs/v1.8.0/nrf/samples/openthread/cli/build_nrf52840dongle_nrf52840/zephyr/zephyr.hex
Parsing image file.
Verified OK.
Enabling pin reset.
Applying pin reset.
still, I don't get any /dev/tty* port for my nrf52840 dongle.
Are you able to test with another computer to see if that one is able to see your dongle?
Do you know whether the program was flashed successfully or not? Can you try flashing the Blinky sample and see if the LED starts to blink as expected?
Marte
