nRF52840 Zephyr dual QSPI Cypress S25hS512 flash Problem
We are using nrf52840 for custom design and we have replaced the mx25r6435f qspi flash with Cypress S25hS512 qspi flash. We configured the flash as below in the dts file.
SDK: ncs v1.7.1
&qspi {
	status = "okay";
	sck-pin = <19>;
	io-pins = <20>, <21>;     //, <22>, <23>;
	csn-pins = <17>;
	s25hs512: s25hs512tf@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
        quad-enable-requirements = "NONE";
		writeoc = "pp";						//"pp4io";
		readoc = "fastread";				//"read4io";
		sck-frequency = <8000000>;
		label = "S25HS512";
		jedec-id = [34 2B 1A];
		size = <512000000>;
If I configure the writeoc and readoc as pp4io and read4io I get data mismatch error. If I configure the flash as pp and fastread I am getting JEDEC QSPI-NOR SPI flash testing
SPI flash driver S25HS512 was not found!
What could be the issue? Need your help, its urgent.
  • Hey Tushar! Sorry about the delay,
    Tushar_V said:
    You tested it on mx25r6435f or on Cypress flash chip?
    Neither, I just checked if I got the same error adding your own dts additions on an overlay-file.
    Tushar_V said:
    Can you share your dts configuration?
    Look here.
    spi_flash.zip
    And add the configurations you mentioned to the overlay file.
    &qspi {
    	status = "okay";
    	sck-pin = <19>;
    	csn-pins = <17>;
    		reg = <0>;
    		label = "S25HS512";
    		size = <512000000>;
    Let me know if that doesn't work.
    Elfving
