Thread node defaults to child, unable to change into router node
Hello there,
I've set up 1.RaspberryPi with an otbr docker container.
Thanks to Sigurd I have set up 2.nRF21540DK running CoProcessor firmware built with nRF Connect SDK 1.7.1
Device 3.ot-cli-ftd, I have connected this device to the thread network and it always joins as a Child. I would like to change it into a router, but I am unable to change the state into router using "state router"
The firmware for device 3.ot-cli-ftd is running on a bmd-341(nRF52840) built with the ot-nrf528xx repository(commit 856c280bed73ba8846ded933ab4cf758e9af2dae).
Output of commands run on device 3.ot-cli-ftd:
> thread stop
Done
> dataset init new
Done
> dataset panid 0x1234
Done
> dataset channel 15
Done
> dataset networkkey 00112233445566778899aabbccddeeff
Done
> dataset networkname OpenThreadDemo
Done
> dataset commit active
Done
> ifconfig up
Done
> thread start
Done
> state
detached
Done
> state
child
Done
> scan
| J | Network Name     | Extended PAN     | PAN  | MAC Address      | Ch | dBm | LQI |
| 0 | OpenThreadDemo   | 12a6e0c91b69d217 | 1234 | 9edd723f5b2e6928 | 15 | -79 |  60 |
Done
> version
OPENTHREAD/thread-reference-20200818-1453-g7a1c843ff; NRF52840; Jan 18 2022 15:24:00
Done
> version api
183
Done
Also when I scan on device 3.ot-cli-ftd the rssi from the 2.nRF21540DK is very low(-79dBm). When I scan from 2.nRF21540DK the RSSI of device 3.ot-cli-ftd seems normal(-47dBm).
Output of commands run on device 2.nRF21540DK:
root@44002931789c:/app# ot-ctl
> state
leader
Done
> neighbor table
| Role | RLOC16 | Age | Avg RSSI | Last RSSI |R|D|N| Extended MAC     |
|   C  | 0x4801 |  85 |      -49 |       -49 |1|1|1| 9ec763b364ebdab9 |
Done
> extpanid
12a6e0c91b69d217
Done
> scan
> | 0 | OpenThreadDemo   | c10610524d6090c8 | 1234 | 9ec763b364ebdab9 | 15 | -47 | 188 |
Done
childip
Done
> version
OPENTHREAD/a193a6f; POSIX; Sep  2 2021 10:19:05
Done
> version api
158
Done
  • Wow, indeed. I can confirm that manually setting the channel/panid/networkkey does allow the state to be changed into router. How strange that it wont change to router when using the dataset.
    I will try to test the range between 2.nRF21540DK and 3.ot-cli-ftd to test if the signal strength is actually low or not.
    Within 1m range everything works fine, but when I put the device ~2m apart it was out of range.
  • For the Range issue:
    Which version of the nRF Connect SDK are you using?
    Could you test the range between two bmd-341?
    Could you test the range between two nRF21540DK?
    This way you can find if the issue is with the bmd-341 or nRF21540DK?
    Sigurd Hellesvik
  • Which version of the nRF Connect SDK are you using?
    For the nRF21540DK I build with nRF Connect SDK 1.7.1
    The CoProcessor project for 1.8.0 builds but does not run for the nRF21540.
    I am unable to run firmware built with the nRF Connect SDK for the BMD-341. I don't get RTT log output, the program is stuck in some address and does not hit the breakpoint in main. I've tried nRF Connect SDK 1.7.1 and 1.8.0 and a few different examples.
    I only have one nRF21540DK. I have 5 boards with bmd-341 modules. I have tested the range between BMD-341 devices running the ot-cli-ftd firmware, and the range seems just fine.
  • Which version of the nRF21540DK are you using?
    Which revision of the nRF21540 is on this DK? (The small text on top of the chip itself)
    I assume you have not changed the sample, right?
    Could you send the function you use for building the coprocessor sample for the nRF21540DK?
    Sigurd Hellesvik
    PCA10112 0.7.1 2020.4
    Just added "CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y" to the sample
    I build using VSCode:
    west build --build-dir d:\IoT\coprocessor171\build d:\IoT\coprocessor171 --pristine --board nrf21540dk_nrf52840 -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="d:/IoT/coprocessor171" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DDTC_OVERLAY_FILE:STRING="d:/IoT/coprocessor171/boards/nrf21540dk_nrf52840.overlay" -DCONF_FILE:STRING="d:/IoT/coprocessor171/prj.conf" -DOVERLAY_CONFIG:STRING="d:/IoT/coprocessor171/overlay-usb.conf;d:/IoT/coprocessor171/overlay-rcp.conf;d:/IoT/coprocessor171/overlay-logging.conf"
    Pristine build log:
    > Executing task: nRF Connect: Build coprocessor171/build (active) <
    Building coprocessor171
    Including boilerplate (Zephyr base): D:/IoT/nRFConnectSDK/v1.7.1/zephyr/cmake/app/boilerplate.cmake
    -- Application: D:/IoT/coprocessor171
    -- Zephyr version: 2.6.99 (D:/IoT/nRFConnectSDK/v1.7.1/zephyr), build: v2.6.99-ncs1-1
    -- Found Python3: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
    -- Board: nrf21540dk_nrf52840
    -- Cache files will be written to: D:/IoT/nRFConnectSDK/v1.7.1/zephyr/.cache
    -- Found dtc: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (d:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt)
    -- Found BOARD.dts: D:/IoT/nRFConnectSDK/v1.7.1/zephyr/boards/arm/nrf21540dk_nrf52840/nrf21540dk_nrf52840.dts
    -- Found devicetree overlay: d:/IoT/coprocessor171/boards/nrf21540dk_nrf52840.overlay
    -- Generated zephyr.dts: D:/IoT/coprocessor171/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/IoT/coprocessor171/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/IoT/coprocessor171/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: D:/IoT/coprocessor171/build/zephyr/dts.cmake
    Parsing D:/IoT/coprocessor171/Kconfig
    Loaded configuration 'D:/IoT/nRFConnectSDK/v1.7.1/zephyr/boards/arm/nrf21540dk_nrf52840/nrf21540dk_nrf52840_defconfig'
    Merged configuration 'd:/IoT/coprocessor171/prj.conf'
    Merged configuration '../common/overlay-ot-defaults.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-usb.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-rcp.conf'
    Merged configuration 'd:/IoT/coprocessor171/overlay-logging.conf'
    Merged configuration 'D:/IoT/coprocessor171/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'D:/IoT/coprocessor171/build/zephyr/.config'
    Kconfig header saved to 'D:/IoT/coprocessor171/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: D:/IoT/nRFConnectSDK/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- OpenThread Source Directory: D:/IoT/nRFConnectSDK/v1.7.1/modules/lib/openthread
    -- Check if the system is big endian
    -- Searching 16 bit integer
    -- Looking for sys/types.h
    -- Looking for sys/types.h - found
    -- Looking for stdint.h
    -- Looking for stdint.h - found
    -- Looking for stddef.h
    -- Looking for stddef.h - found
    -- Check size of unsigned short
    -- Check size of unsigned short - done
    -- Searching 16 bit integer - Using unsigned short
    -- Check if the system is big endian - little endian
    -- Package Name: OPENTHREAD
    -- Setting default package version: v1.7.0
    -- Package Version: v1.7.0
    CMake Warning (dev) at D:\IoT\nRFConnectSDK\v1.7.1\nrfxlib\nrf_security\cmake\extensions.cmake:652:
      Syntax Warning in cmake code at column 32
      Argument not separated from preceding token by whitespace.
      D:\IoT\nRFConnectSDK\v1.7.1\nrfxlib\nrf_security\CMakeLists.txt:185 (include)
    This warning is for project developers.  Use -Wno-dev to suppress it.
    CMake Warning at D:\IoT\nRFConnectSDK\v1.7.1\zephyr\CMakeLists.txt:1612 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/IoT/coprocessor171/build
    [1/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/aesni.c.obj
    [2/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/arc4.c.obj
    [3/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/camellia.c.obj
    [4/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/blowfish.c.obj
    [5/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/aria.c.obj
    [6/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/debug.c.obj
    [7/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/error.c.obj
    [8/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/des.c.obj
    [9/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/base64.c.obj
    [10/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/cipher_wrap.c.obj
    [11/398] Generating objects/cc3xx.mon
    [12/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/asn1write.c.obj
    [13/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/asn1parse.c.obj
    [14/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ctr_drbg.c.obj
    [15/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/gcm.c.obj
    [16/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/cipher.c.obj
    [17/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/havege.c.obj
    [18/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/entropy_poll.c.obj
    [19/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/entropy.c.obj
    [20/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/hkdf.c.obj
    [21/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md4.c.obj
    [22/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cache.c.obj
    [23/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md2.c.obj
    [24/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/net_sockets.c.obj
    [25/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md.c.obj
    [26/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_csr.c.obj
    [27/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/hmac_drbg.c.obj
    [28/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/nist_kw.c.obj
    [29/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs12.c.obj
    [30/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform.c.obj
    [31/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/oid.c.obj
    [32/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/padlock.c.obj
    [33/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ripemd160.c.obj
    [34/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/md5.c.obj
    [35/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pk.c.obj
    [36/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs5.c.obj
    [37/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto.c.obj
    [38/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform_util.c.obj
    [39/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pk_wrap.c.obj
    [40/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/platform.c.obj
    [41/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/xtea.c.obj
    [42/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/version_features.c.obj
    [43/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkwrite.c.obj
    [44/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/timing.c.obj
    [45/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_storage.c.obj
    [46/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_ecp.c.obj
    [47/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/version.c.obj
    [48/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/bignum.c.obj
    [49/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_slot_management.c.obj
    [50/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/certs.c.obj
    [51/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkparse.c.obj
    [52/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_rsa.c.obj
    [53/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_client.c.obj
    [54/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/pkcs11.c.obj
    [55/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509write_csr.c.obj
    [56/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_create.c.obj
    [57/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_crl.c.obj
    [58/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
    [59/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_ticket.c.obj
    [60/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/psa_crypto_driver_wrappers.c.obj
    [61/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509.c.obj
    [62/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cookie.c.obj
    [63/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/replacements/ssl_ciphersuites.c.obj
    [64/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ecjpake.c.obj
    [65/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_srv.c.obj
    [66/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_cli.c.obj
    [67/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/x509_crt.c.obj
    [68/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [69/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_tls.c.obj
    [70/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedx509.a
    [71/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/D_/IoT/nRFConnectSDK/v1.7.1/mbedtls/library/ssl_msg.c.obj
    [72/398] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedtls.a
    [73/398] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [74/398] cmd.exe /C "cd /D D:\IoT\coprocessor171\build\modules\openthread\build && D:\IoT\nRFConnectSDK\v1.7.1\toolchain\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_2;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;BUILD_VERSION=v2.6.99-ncs1-1;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=0;__PROGRAM_START;NRF52840_XXAA;NRF_802154_ECB_PRIORITY=0;NRF_802154_SWI_PRIORITY=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_CSMA_CA_ENABLED=1;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;PSA_CRYPTO_SECURE;MBEDTLS_CONFIG_FILE="nrf-config.h"" -P D:/IoT/nRFConnectSDK/v1.7.1/modules/lib/openthread/etc/cmake/print.cmake"
    PACKAGE_NAME=OPENTHREAD
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=2
    __PROGRAM_START
    NRF52840_XXAA
    PSA_CRYPTO_SECURE
    MBEDTLS_CONFIG_FILE=nrf-config.h
    [75/398] Generating include/generated/driver-validation.h
    [76/398] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [77/398] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [78/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/utils/lookup_table.cpp.obj
    [79/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/error_api.cpp.obj
    [80/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/error.cpp.obj
    [81/398] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [82/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/random_noncrypto_api.cpp.obj
    [83/398] Building CXX object modules/openthread/build/src/lib/hdlc/CMakeFiles/openthread-hdlc.dir/hdlc.cpp.obj
    [84/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/logging_api.cpp.obj
    [85/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio.cpp.obj
    [86/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio_callbacks.cpp.obj
    [87/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/sub_mac_callbacks.cpp.obj
    [88/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/diags_api.cpp.obj
    [89/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/tasklet_api.cpp.obj
    [90/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/instance_api.cpp.obj
    [91/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/thread/link_quality.cpp.obj
    [92/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/utils/parse_cmdline.cpp.obj
    [93/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/radio/radio_platform.cpp.obj
    [94/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/tasklet.cpp.obj
    [95/398] Linking CXX static library modules\openthread\build\src\lib\hdlc\libopenthread-hdlc.a
    [96/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/api/link_raw_api.cpp.obj
    [97/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/string.cpp.obj
    [98/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/crypto/aes_ecb.cpp.obj
    [99/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/random_manager.cpp.obj
    [100/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/instance.cpp.obj
    [101/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/mac_types.cpp.obj
    [102/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_encoder.cpp.obj
    [103/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/logging.cpp.obj
    [104/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/crypto/aes_ccm.cpp.obj
    [105/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/common/timer.cpp.obj
    [106/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/link_raw.cpp.obj
    [107/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_buffer.cpp.obj
    [108/398] Building CXX object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel_decoder.cpp.obj
    [109/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/diags/factory_diags.cpp.obj
    [110/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/changed_props_set.cpp.obj
    [111/398] Building C object modules/openthread/build/src/lib/spinel/CMakeFiles/openthread-spinel-rcp.dir/spinel.c.obj
    [112/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base_dispatcher.cpp.obj
    [113/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_spi.cpp.obj
    [114/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/sub_mac.cpp.obj
    [115/398] Linking CXX static library modules\openthread\build\src\lib\spinel\libopenthread-spinel-rcp.a
    [116/398] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-radio.dir/mac/mac_frame.cpp.obj
    [117/398] Linking CXX static library modules\openthread\build\src\core\libopenthread-radio.a
    [118/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base_radio.cpp.obj
    [119/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_hdlc.cpp.obj
    [120/398] Building CXX object modules/openthread/build/src/ncp/CMakeFiles/openthread-rcp.dir/ncp_base.cpp.obj
    [121/398] Linking CXX static library modules\openthread\build\src\ncp\libopenthread-rcp.a
    [122/398] Generating include/generated/offsets.h
    [123/398] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [124/398] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [125/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
    [126/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [127/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [128/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [129/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
    [130/398] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [131/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [132/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
    [133/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
    [134/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
    [135/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [136/398] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [137/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [138/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_virtual.c.obj
    [139/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
    [140/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [141/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [142/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [143/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [144/398] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_vtable.cpp.obj
    [145/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [146/398] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_new.cpp.obj
    [147/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [148/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_rtt.c.obj
    [149/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_work_q.c.obj
    [150/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [151/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
    [152/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [153/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [154/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
    [155/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
    [156/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [157/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_transfer.c.obj
    [158/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [159/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
    [160/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [161/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [162/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_descriptor.c.obj
    [163/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
    [164/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
    [165/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/hwinfo/hwinfo_nrf.c.obj
    [166/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [167/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/__aeabi_atexit.c.obj
    [168/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [169/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/hwinfo/hwinfo_weak_impl.c.obj
    [170/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
    [171/398] Generating linker_zephyr_prebuilt.cmd
    [172/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/class/cdc_acm.c.obj
    [173/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [174/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
    [175/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj
    [176/398] Building C object zephyr/CMakeFiles/zephyr.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [177/398] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_device.c.obj
    [178/398] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [179/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [180/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [181/398] Building C object zephyr/CMakeFiles/zephyr.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [182/398] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
    [183/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [184/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [185/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [186/398] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [187/398] Building C object CMakeFiles/app.dir/src/main.c.obj
    [188/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [189/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [190/398] Building C object modules/nrf/drivers/mpsl/temp_nrf5/CMakeFiles/..__nrf__drivers__mpsl__temp_nrf5.dir/temp_nrf5_mpsl.c.obj
    [191/398] Linking CXX static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
    [192/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [193/398] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [194/398] Building C object CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj
    [195/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [196/398] Linking CXX static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [197/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [198/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [199/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [200/398] Linking CXX static library modules\nrf\drivers\mpsl\temp_nrf5\lib..__nrf__drivers__mpsl__temp_nrf5.a
    [201/398] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [202/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [203/398] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [204/398] Linking CXX static library modules\nrf\drivers\mpsl\flash_sync\lib..__nrf__drivers__mpsl__flash_sync.a
    [205/398] Linking CXX static library app\libapp.a
    [206/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [207/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [208/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [209/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [210/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [211/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [212/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [213/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [214/398] Linking CXX static library zephyr\arch\common\libisr_tables.a
    [215/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [216/398] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [217/398] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [218/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [219/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [220/398] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/usb/device/usb_dc_nrfx.c.obj
    [221/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [222/398] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [223/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [224/398] Linking CXX static library zephyr\arch\common\libarch__common.a
    [225/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [226/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [227/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [228/398] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [229/398] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [230/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [231/398] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [232/398] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [233/398] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [234/398] Linking CXX static library zephyr\libzephyr.a
    [235/398] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [236/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [237/398] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [238/398] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [239/398] Linking CXX static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [240/398] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [241/398] Linking CXX static library zephyr\lib\posix\liblib__posix.a
    [242/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [243/398] Linking CXX static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [244/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [245/398] Linking CXX static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [246/398] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [247/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
    [248/398] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [249/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_stats.c.obj
    [250/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [251/398] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread_utils.c.obj
    [252/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6_nbr.c.obj
    [253/398] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread.c.obj
    [254/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv6.c.obj
    [255/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/nbr.c.obj
    [256/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_mgmt.c.obj
    [257/398] Linking CXX static library zephyr\subsys\net\libsubsys__net.a
    [258/398] Building C object zephyr/subsys/net/lib/conn_mgr/CMakeFiles/subsys__net__lib__conn_mgr.dir/events_handler.c.obj
    [259/398] Building C object zephyr/subsys/net/lib/conn_mgr/CMakeFiles/subsys__net__lib__conn_mgr.dir/conn_mgr.c.obj
    [260/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj
    [261/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6.c.obj
    [262/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
    [263/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/alarm.c.obj
    [264/398] Linking CXX static library zephyr\subsys\net\l2\openthread\libsubsys__net__ip__l2__openthread.a
    [265/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/misc.c.obj
    [266/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
    [267/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/entropy.c.obj
    [268/398] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/__/__/misc/empty_file.c.obj
    [269/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/spi.c.obj
    [270/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/memory.c.obj
    [271/398] Linking CXX static library zephyr\subsys\net\lib\conn_mgr\libsubsys__net__lib__conn_mgr.a
    [272/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/settings.c.obj
    [273/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/platform.c.obj
    [274/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/diag.c.obj
    [275/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
    [276/398] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [277/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/logging.c.obj
    [278/398] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [279/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/uart.c.obj
    [280/398] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [281/398] Linking CXX static library zephyr\subsys\random\libsubsys__random.a
    [282/398] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [283/398] Building C object zephyr/subsys/net/lib/openthread/platform/CMakeFiles/openthread_platform.dir/radio.c.obj
    [284/398] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
    [285/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_crit_sect.c.obj
    [286/398] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [287/398] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [288/398] Linking CXX static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
    [289/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/radio/platform/nrf_802154_random_zephyr.c.obj
    [290/398] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [291/398] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [292/398] Building C object modules/nrf/subsys/ieee802154/CMakeFiles/..__nrf__subsys__ieee802154.dir/nrf_802154_configurator.c.obj
    [293/398] Linking CXX static library zephyr\drivers\entropy\libdrivers__entropy.a
    [294/398] Linking CXX static library zephyr\subsys\net\lib\openthread\platform\libopenthread_platform.a
    [295/398] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/mpsl_fem.c.obj
    [296/398] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [297/398] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [298/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_irq_zephyr.c.obj
    [299/398] Linking CXX static library zephyr\drivers\flash\libdrivers__flash.a
    [300/398] Linking CXX static library zephyr\drivers\gpio\libdrivers__gpio.a
    [301/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_clock_zephyr.c.obj
    [302/398] Linking CXX static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [303/398] Linking CXX static library zephyr\drivers\serial\libdrivers__serial.a
    [304/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/nrf_802154/sl/platform/hp_timer/nrf_802154_hp_timer.c.obj
    [305/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_zephyr.c.obj
    [306/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_temperature_zephyr.c.obj
    [307/398] Linking CXX static library modules\nrf\subsys\ieee802154\lib..__nrf__subsys__ieee802154.a
    [308/398] Linking CXX static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
    [309/398] Linking CXX static library modules\nrf\subsys\mpsl\fem\lib..__nrf__subsys__mpsl__fem.a
    [310/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [311/398] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/D_/IoT/nRFConnectSDK/v1.7.1/nrfxlib/nrf_802154/sl/platform/lp_timer/nrf_802154_lp_timer.c.obj
    [312/398] Linking CXX static library zephyr\subsys\net\ip\libsubsys__net__ip.a
    [313/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [314/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_systick.c.obj
    [315/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [316/398] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [317/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [318/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/mbedtls/mbedtls_heap.c.obj
    [319/398] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/mbedtls/replacements/memory_buffer_alloc.c.obj
    [320/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug_assert.c.obj
    [321/398] Linking CXX static library modules\hal_nordic\nrf_802154\libnrf-802154-platform.a
    [322/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_critical_section.c.obj
    [323/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [324/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core_hooks.c.obj
    [325/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_aes_ccm.c.obj
    [326/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154.c.obj
    [327/398] Linking CXX static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    [328/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug.c.obj
    [329/398] Building C object modules/segger/CMakeFiles/modules__segger.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [330/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rssi.c.obj
    [331/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_pib.c.obj
    [332/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_peripherals_alloc.c.obj
    [333/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_queue.c.obj
    [334/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rx_buffer.c.obj
    [335/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_encrypt.c.obj
    [336/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_stats.c.obj
    [337/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_dppi.c.obj
    [338/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [339/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_swi.c.obj
    [340/398] Linking CXX static library modules\segger\libmodules__segger.a
    [341/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_ppi.c.obj
    [342/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ie_writer.c.obj
    [343/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_work_buffer.c.obj
    [344/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_filter.c.obj
    [345/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core.c.obj
    [346/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_writer.c.obj
    [347/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_frame_parser.c.obj
    [348/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_csma_ca.c.obj
    [349/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_generator.c.obj
    [350/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_delayed_trx.c.obj
    [351/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_pib_ram.c.obj
    [352/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_data.c.obj
    [353/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_priority_drop_swi.c.obj
    [354/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_precise_ack_timeout.c.obj
    [355/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ifs.c.obj
    [356/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx.c.obj
    [357/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_notification_swi.c.obj
    [358/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_imm_ack_generator.c.obj
    [359/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [360/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_enh_ack_generator.c.obj
    [361/398] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_request_swi.c.obj
    [362/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [363/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [364/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [365/398] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/IoT/nRFConnectSDK/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
    [366/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [367/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [368/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [369/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [370/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [371/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [372/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [373/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [374/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [375/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [376/398] Linking CXX static library modules\nrfxlib\nrf_802154\nrf_802154\driver\libnrf-802154-driver.a
    [377/398] Linking CXX static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [378/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [379/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [380/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [381/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [382/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [383/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [384/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [385/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [386/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [387/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [388/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [389/398] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [390/398] Linking CXX static library zephyr\kernel\libkernel.a
    [391/398] Linking CXX executable zephyr\zephyr_prebuilt.elf
    [392/398] Generating linker.cmd
    [393/398] Generating isr_tables.c, isrList.bin
    [394/398] Generating dev_handles.c
    [395/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [396/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [397/398] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [398/398] Linking CXX executable zephyr\zephyr.elf
               FLASH:      216520 B         1 MB     20.65%
                SRAM:       80488 B       256 KB     30.70%
            IDT_LIST:          0 GB         2 KB      0.00%
    Terminal will be reused by tasks, press any key to close it.
