GPIOTE handler triggered for all registered GPIO's, when only one of them changes state
Hello, i have six buttons on my custom board, these buttons are inited with following code:
(there are pull up resistors present, hence NRF_GPIO_PIN_NOPULL is used)
SEGGER_RTT_printf(0, "buttons init.\n");
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
in_config.pull = NRF_GPIO_PIN_NOPULL;
err_code = nrf_drv_gpiote_in_init(PIN_BTN1, &in_config, button_handler);
err_code = nrf_drv_gpiote_in_init(PIN_BTN2, &in_config, button_handler);
err_code = nrf_drv_gpiote_in_init(PIN_BTN3, &in_config, button_handler);
err_code = nrf_drv_gpiote_in_init(PIN_BTN4, &in_config, button_handler);
err_code = nrf_drv_gpiote_in_init(PIN_BTN5, &in_config, button_handler);
err_code = nrf_drv_gpiote_in_init(PIN_BTN6, &in_config, button_handler);
nrf_drv_gpiote_in_event_enable(PIN_BTN1, true);
nrf_drv_gpiote_in_event_enable(PIN_BTN2, true);
nrf_drv_gpiote_in_event_enable(PIN_BTN3, true);
nrf_drv_gpiote_in_event_enable(PIN_BTN4, true);
nrf_drv_gpiote_in_event_enable(PIN_BTN5, true);
nrf_drv_gpiote_in_event_enable(PIN_BTN6, true);
Problem is, that if i press any button when system is freshly booted and ready, after previous NVIC_SystemReset() , button_handler is triggered for all of the buttons at the same time.
My button_handler routine prints a debug message when it's triggered by button press, and if i press any of six buttons (when system is freshly booted), i get six subsequent messages for all of the buttons (all GPIO lines registered for GPIOTE IN events):
button_handler triggered: 10.
button_handler triggered: 15.
button_handler triggered: 17.
button_handler triggered: 36.
button_handler triggered: 9.
button_handler triggered: 38.
This looks like a hardware issue, but it happens only once, after system is booted. Then, after this first button press, all buttons work normally, without issues (one button press - one GPIOTE IN event triggered). Again, once, after reboot, when any of six buttons present on board is pressed - six GPIOTE events are triggered for all GPIO lines used for buttons. Then buttons work as expected.
All GPIO's have separate pull up resistors, nothing is common hardware wise.
  • You can reset latch register by writing 1 to the bits that are set (i.e. read the register and write back what you read).
    Have you checked if the LATCH bits are set before the GPIO/buttons are configured after wake from System OFF, i.e. at the very beginning of main()?
    nrf_gpio_cfg_input() writed all configs to the register in one operation, including both INPUT and SENSE, so it does not implement the workaround from the errata as far as I can see.
