nrf connect app for desktop
I am using nrf52832 dev kit and soft device s132. I have use my board as peripheral
and i have another nrf52840 dev kit which i am using as a central connect it with my PC which has nrf connect app for desktop.
i have a code which is perfectly running on my nrf connect app on mobile but it is not running on nrf connect app for desktop.
pls help
  • i have saved logs in flash memory. When i connect i just enable notify , write 11 and get the data. i nrf app for desktop also i am doing the same.
  • Thank you for providing the videos, this makes the issue more clear.
    I will try to replicate this on my end as well.
    It looks to me like you attempt to enable CCCD before the CCCD characteristic is discovered, and that you also try to write to the characteristic before the discovery is complete.
    What happens if you wait until it is complete before writing to the characteristic?
    Please also answer:
    Karl Ylvisaker said:
    Could you also tell me if you are able to read and write the other services of the device, or if they all are inaccessible?
    Karl
  • I HAVE battery service, i am able to read it.
    when i even wait for CCCD to discover still i am not able to write in the characteristic for the second service for which i have to get notification data
    Thank you for clarifying this.
    It seems to me that you are attempting to enable the notification before the CCCD characteristic has been discovered.
    I am not able to reproduce this behavior on my end, unfortunately.
    Could you try to reinstall the Bluetooth Low Energy application in nRF Connect, and re-flash the nRF52840 DK that you are using on the central side, and see if this changes anything?
    I will ask internally if anyone else has seen the NRF_ERROR_BUSY error in the Bluetooth Low Energy application before.
    Karl
