Unexpected address match on nRF5340
I use nRF5340DK (0.11.0) as HCI controller and noticed it can randomly (?) accept PDUs with access address other than configured. This basically makes it impossible to qualify since there are test cases that test behavior with invalid access address (e.g. LL/ENC/INI/BI-01-C) and there's apparently no way to check the received access address and verify it in sw. I checked known erratas and cannot see anything related. Also the same issue can be reproduced on both Apache NimBLE and Zephyr controllers. Any ideas whether this is just a configuration issue or hardware problem?
  • You can find all occurrences on in "Timing" view, they are marked by pulse on "rx" line (except for 1st one in each connection since that is for received advertising packet). Few timestamps:
    62.221 480 625
    71.517 923 625
    75.416 533 625
    75.616 387 500
    But there are many more there and starting from 231.963 199 000 nRF53 kept receiving every single PDU with invalid aa.
    The "Received Access Address" field is visible once you select "All fields" in "Details" view.
    Andrzej
  • Thank you for the detailed description, Andrzej.
    Looking at the instance around 62 seconds:
    I assume the nRF is the master/central in this case, right?
    I see that in the packet with timestamp 62.021278875 (highlighted in above screenshot), the master/central sends a packet, and the slave/peripheral replies with an incorrect  Access Address (AA) ending in 0x14 instead of 0x54.
    However, this packet is not accepted as a valid packet by the central, as you can see by the SN and NESN (Serial Number and Next Expected Serial Number added as separate columns), which are both 0, since this doesn't change in the next packet from the central, it means that it didn't pick up the previous packet. This is the central telling the peripheral to retransmit the previous packet. Do you agree with this?
    I am not saying you are wrong, but if this in fact is a bug, I need to understand what erronous behavior the nRF is doing Slight smile
    Edvin
  • That is correct, but the connection event you are referring to is also correct. You can see the problem e.g. in 3rd connection event, i.e. at 62.221 timestamp:
    - 1st PDU from central has SN=0
    - 2nd PDU from peripheral has invalid aa and is accepted - addr2end line is active during that PDU which means EVENT_ADDRESS and EVENT_END were triggered
    - 3rd PDU from central has SN=1 since LL thinks peripheral acked 1st PDU
    Andrzej
  • Let me run this by some from our softdevice controller team. I am not sure whether this check is done in HW or SW. I will get back to you.
    Edvin
  • Hello Andrzej,
    What NCS version are you using when doing these tests?
