nRF Connect for Desktop Programmer V2.2.0 and Heart Rate Monitor Demo
I have connected a nRF5340 DK board which the Programmer can connect to. I then drag the two .hex files for the Heart Rate Monitor demo over to the File Memory Layout window, however the following commands are still grayed out:
  • Erase all
  • Erase & write
  • Save as file
  • Reset
  • Write
  • Read
What am I missing please?
2022-01-24T18:11:10.585Z INFO Application data folder: /Users/alwalker/Library/Application Support/nrfconnect/pc-nrfconnect-programmer
2022-01-24T18:11:10.768Z DEBUG iface: en0
2022-01-24T18:11:10.769Z DEBUG IP4:
2022-01-24T18:11:10.769Z DEBUG IP6:
2022-01-24T18:11:10.769Z DEBUG MAC: f4:5c:89:8a:4c:71
2022-01-24T18:11:10.770Z DEBUG Client Id: 5f1d8708c90a91adf6b1603fb7250edf40e5ca2f
2022-01-24T18:11:10.771Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
2022-01-24T18:11:10.858Z DEBUG App pc-nrfconnect-programmer v2.2.0 official
2022-01-24T18:11:10.859Z DEBUG App path: /Users/alwalker/.nrfconnect-apps/node_modules/pc-nrfconnect-programmer
2022-01-24T18:11:10.859Z DEBUG nRFConnect 3.9.3, required by the app is (^3.9.2)
2022-01-24T18:11:10.859Z DEBUG nRFConnect path: /Applications/nRF Connect for Desktop.app/Contents/Resources/app.asar
2022-01-24T18:11:10.859Z DEBUG HomeDir: /Users/alwalker
2022-01-24T18:11:10.859Z DEBUG TmpDir: /var/folders/gt/fzbprb7j48b7rm6dmdcdx2q00000gn/T/
2022-01-24T18:11:21.384Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
2022-01-24T18:11:21.384Z INFO JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Jul  2 2021 10:55:25
2022-01-24T18:11:21.384Z DEBUG Sending usage data...
2022-01-24T18:11:21.385Z DEBUG Category: pc-nrfconnect-programmer
2022-01-24T18:11:21.385Z DEBUG Action: Open jlink OB version
2022-01-24T18:11:21.385Z DEBUG Label: J-Link OB-nRF5340-NordicSemi compiled Jul  2 2021 10:55:25
2022-01-24T18:11:21.385Z DEBUG Usage data has not been sent. isSendingUsageData is set to false.
2022-01-24T18:11:21.385Z INFO Device family
2022-01-24T18:11:21.385Z DEBUG Sending usage data...
2022-01-24T18:11:21.385Z DEBUG Action: Open jlink device family
2022-01-24T18:11:21.385Z DEBUG Label: null
2022-01-24T18:11:21.385Z INFO Device version
2022-01-24T18:11:21.385Z DEBUG Action: Open jlink device version
2022-01-24T18:11:21.386Z DEBUG Usage data has not been sent. isSendingUsageData is set to false.
2022-01-24T18:11:21.386Z INFO Board version PCA10095
2022-01-24T18:11:21.386Z DEBUG Sending usage data...
2022-01-24T18:11:21.386Z DEBUG Category: pc-nrfconnect-programmer
2022-01-24T18:11:21.386Z DEBUG Action: Open jlink device board version
2022-01-24T18:11:21.386Z DEBUG Label: PCA10095
2022-01-24T18:11:21.387Z DEBUG Sending usage data...
2022-01-24T18:11:21.387Z DEBUG Category: pc-nrfconnect-programmer
2022-01-24T18:11:21.387Z DEBUG Action: Open device
2022-01-24T18:11:21.387Z DEBUG Label: jlink
2022-01-24T18:11:21.387Z DEBUG Usage data has not been sent. isSendingUsageData is set to false.
2022-01-24T18:11:53.159Z INFO Parsing HEX file:  /Users/alwalker/Desktop/Peripheral_Heart_Rate_nRF5340_DK/peripheral_hr.hex
2022-01-24T18:11:53.173Z INFO File was last modified at  02/12/2020, 09:36:50
2022-01-24T18:11:53.224Z INFO Update files regions according to NRFDL_DEVICE_CORE_APPLICATION core
2022-01-24T18:11:53.224Z INFO Parse memory regions for file
2022-01-24T18:11:53.241Z INFO Parsing HEX file:  /Users/alwalker/Desktop/Peripheral_Heart_Rate_nRF5340_DK/hci_open_amp.hex
2022-01-24T18:11:53.241Z INFO File was last modified at  02/12/2020, 09:36:52
2022-01-24T18:11:53.326Z INFO Update files regions according to NRFDL_DEVICE_CORE_APPLICATION core
2022-01-24T18:11:53.326Z INFO Parse memory regions for file
2022-01-24T18:11:53.326Z INFO Update files regions according to NRFDL_DEVICE_CORE_NETWORK core
# nRFConnect System Report - 2022-01-25T07-26-56.445Z
- System: Apple Inc. MacBookPro12,1
- BIOS: Apple Inc. 428.60.3.0.0
- CPU: 1 x IntelRegistered CoreTm i7-5557U 3.1 GHz 4 cores (2 physical)
- Memory: 425.4 MB free of 16 GB total
- Filesystem: /dev/disk1s5 (APFS) 931.6 GB 2.2% used
- OS: Mac OS X (10.15.7) darwin x64
- Versions
- kernel: 19.6.0
- git: 2.24.3
- node: 14.16.0
- python: 2.7.16
- python3: 3.8.2
- nrfjprog: 10.15.1
- jlink: 7.58b
- Connected devices:
- 001050072527 PCA10095: /dev/tty.usbmodem0010500725271, /dev/tty.usbmodem0010500725273
- Current device:
- name: nRF5340 DK
- serialNumber: 001050072527
- cores: 2
- website: www.nordicsemi.com/.../nRF5340-DK
  • Hello Einar,
    I've raised another ticket for the issues I've encountered with following the introductory videos:
    https://devzone.nordicsemi.com/f/nordic-q-a/84319/nrf-connect-for-vs-code-youtube-videos-having-problems-with-include-paths-and-kconfig-in-mac-os
    Al
  • Hello!
    There is a new update to the programmer app available that I believe should fix the issue related to the nRF53.
    Could you try downloading the new update and see if it fixes your issue?
    Einar
  • Thanks Einar, that's a lot more successful.
    I have two nRF5340 DK modules, labelled 1 and 2. This was the order that I originally tried them with Programmer.
    The following was performed with Programmer official V2.3.1
    Module 2 was tried first.
    An Erase and then a Write was done with the two .hex files
    Reset button pressed.
    On nRF Toolbox on my iPad, I selected Heart Rate and then Connect
    On the first connection the nRF5340 DK appeared as N/A which I selected. On subsequent connections it appears correctly as Zephyr Heartrate Monitor.
    The Heart rate cycled between 90 BPM and 159 BPM in 1 BPM increments. Initially the graph line does not appear on the X-Y graph display, but does after perhaps 30 seconds and continues to do so.
    The battery shows a numerical percentage value which does not change, variously 54%, 40% and 84% for each of the connection sessions. Note that the onboard Li-ion battery is not in-circuit with the shipping tab insulator still in place.
    nRF Connect for Desktop was restarted and Module 1 was connected.
    On the first connection the nRF5340 DK appeared as Nordic_HR which I selected. On subsequent connections it appears correctly as Zephyr Heartrate Monitor.
    The battery shows a numerical percentage value which does not change, showing 65%, 65% and 62% for each of the connection sessions. Note that the onboard Li-ion battery is not in-circuit with the shipping tab insulator still in place.
    Is this all the expected behaviour please?
  • yes that sounds like expected behavior, glad to hear the update fixed your issue.
  • Thank you very much Einar, I think we can close this case now.
