serial_lte_modem AT#XFTP="put" SLM data mode and escaping data?
So I have to upload a bunch of files, some contain arbitrary data that might contain +,\r,\n,\ ext
So there are two different ways of using the FTP put command, one is in SLM data mode, the other is inline in quotes and I am having huge issues with both
**inline Mode?**
AT#XFTP="open","******username********","*******password*****","*******domain*******"
AT#XFTP="verbose","on"
AT#XFTP="binary"
AT#XFTP="put","test.txt","this is test content"
AT#XFTP="close"
**SLM Data Mode**
AT#XFTP="binary"
AT#XFTP="close"
We can talk about these two options:
Option1 is what I call inline mode:
if I try to include a  \" inside the first option, or a \r\n in the next the modem will just lock up for a long time. Is there any way to send a bunch of arbitrary binary data as long as I escape it somehow? since backslash doesn't seem to be working
Example that will fail:
AT#XFTP="binary"
AT#XFTP="put","test.txt","this is\" test content"
AT#XFTP="close"
Option2: Is what you guys call SLM data mode:
According to the documentation and from what I can see in the code, the only way the modem should exit SLM data mode is after a timeout, or by sending +++
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/serial_lte_modem/doc/slm_data_mode.html
But this doesn't happen, it only seems to exit SLM mode when I send a \r\n but there appears to be no way of escaping this?
Another problem is if I just pretend the first issue isnt a thing and remove all new lines from my data(which I really can't do, this is just for exploring the other problem I am having) and send +++ it shows up in the file that is uploaded to the server?
Example that will write part of a file and then get an error because it drops out of SLM too soon:
AT#XFTP="binary"
this is \r\ntest content+++
AT#XFTP="close"
If I try to use the +++ as intended from the documentation:
AT#XFTP="binary"
this is test content+++
AT#XFTP="close"
I end up with a file on the server including the +++:
This example will also fail if you do not send a \r\n at the end of the test content line even though the +++ is supposed to terminate it.
Few quite baffling things that do not follow normal conventions or even the documentation?
  • In Summery, I bought a cellular booster to rule out bad connection being the source of my problem, it was not my problem.
    So it comes down to 4 issues:
    •  1) SLM mode for MPUT doesn't seem to be exiting ever, its ignoring the exit string of "+++" even though i made sure it was "+++" in the conf file. Take a look at the last comment about the ESP32, same thing with MPUT
    • 2) With my signal strength at: RSRQ: -10.50db RSRP: -63.00db both:
    and
    AT#XHTTPCCON=1,"****DOMAIN****",80
    are very unreliable, I have tried many domains
    • 3) Another issue I have been having is with simple HTTP post:
    > AT#XHTTPCCON=1,"***DOMAIN***",80
    *** wait for "#XHTTPCCON: 1"
    > AT#XHTTPCCON?
    *** check for '#XHTTPCCON: 1,"***DOMAIN***"' to make sure connection active
    > AT#XHTTPCREQ="POST","/?filename=text.txt","Content-Type: text/plain\r\nContent-Length: 5\r\n",5
    *** wait for "#XHTTPCREQ: 1"
    > 12345
    But I always get this back:
    #XHTTPCRSP:0,1
    no 200, no 500, nothing at all. this happens on a lot of different domains.
    I am despite to get log files transferred to the server. This used to work.
    Edit: I got the ping function working and google.ca works most of the time but other domains like ours, stack overflow, speed test .net among others are a roll of the dice if it will ever get a response, even when using the direct IP address instead of the domain name
  • Hi Kyle,
    1) As I explained before, Document Running in data mode mentioned "FTP unique or single put operations are completed." will trigger data mode exists, so make sure you have all your content at one put action. Every time you send some data through FTP put/mput data mode, it will trigger a single put operation, when it is completed, the data mode exists. so "+++" is not necessary to be used here. It is also applied to HTTP commands.
    2) 3) Looks like they are the same issue, the FTP/HTTP server is not connected. Are you testing with LTE-M network? Did you experience the same symptoms with the nRF9160DK board?
    The current log information is outputted through RTT viewer, try to capture it after adding "CONFIG_SLM_LOG_LEVEL_DBG=y" and comment "#CONFIG_SLM_LOG_LEVEL_INF=y".
    Charlie
  • Hello Charlie,
    In regards to the last post on the other thread, I am running 1.3.1 MFW
    1) I know the documentation says its a 1 second timeout on this but in practice my modem seems to be staying in MPUT mode until hardware reset.
    2)3) Exact same issue on the DK hardware vs my own board. I think the simplest example will be to just turn the modem on and PDA connect, then ping google.ca and then a few other domains including nordicsemi.com
    2022-01-31 ping failure.log
    Thanks
    Kyle
    Edit: I should add, these logs were done on the DK hardware using MFW 1.3.1 and serial_lte_modem 1.8.0
  • Here is a log from the rare event when I actually get connected to the server, I am basically connecting with the LTE Link monitor... setting up my network and connecting to the FTP server then sending:
    this is test content\x0A\x0Dand more on another line
    and then the modem mostly just locks up for a LONNGG time and I need to reset it.
    # SEGGER J-Link RTT Viewer V7.58b Terminal Log File
    # Compiled: 15:03:12 on Nov 16 2021
    # Logging started @ 31 Jan 2022 15:53:31
    00> [00:02:45.917,480] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 46 54 50 3d  22 76 65 72 62 6f 73 65 |AT#XFTP= "verbose
    00>                                       22 2c 22 6f 6e 22                                |","on"
    00> [00:02:45.917,968] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:02:45.918,182] <dbg> slm_at_host: TX
    00>                                       0d 0a 56 65 72 62 6f 73  65 20 6d 6f 64 65 20 6f |..Verbos e mode o
    00>                                       6e 0d 0a                                         |n..
    00> [00:02:45.918,212] <dbg> slm_at_host: TX
    00>                                       0d 0a 4f 4b 0d 0a                                |..OK..
    00> [00:02:50.536,468] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 46 54 50 3d  22 62 69 6e 61 72 79 22 |AT#XFTP= "binary"
    00> [00:02:50.536,956] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:02:51.029,846] <dbg> slm_at_host: TX
    00>                                       32 30 30 20 54 59 50 45  20 69 73 20 6e 6f 77 20 |200 TYPE  is now
    00>                                       38 2d 62 69 74 20 62 69  6e 61 72 79 0d 0a       |8-bit bi nary..
    00> [00:02:51.029,907] <dbg> slm_at_host: TX
    00> [00:02:51.032,592] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:02:51.033,142] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 36  34 2c 33 2c 31 34 2c 32 |%CESQ: 6 4,3,14,2
    00>                                       0d 0a                                            |..
    00> [00:02:55.353,790] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:02:55.353,851] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 36  34 2c 33 2c 39 2c 31 0d |%CESQ: 6 4,3,9,1.
    00>                                       0a                                               |.
    00> [00:02:55.823,333] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 46 54 50 3d  22 63 64 22 2c 22 2f 74 |AT#XFTP= "cd","/t
    00>                                       65 73 74 2f 22                                   |est/"
    00> [00:02:55.823,822] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:02:56.034,149] <dbg> slm_at_host: TX
    00>                                       32 35 30 20 4f 4b 2e 20  43 75 72 72 65 6e 74 20 |250 OK.  Current
    00>                                       64 69 72 65 63 74 6f 72  79 20 69 73 20 2f 74 65 |director y is /te
    00>                                       73 74 0d 0a                                      |st..
    00> [00:02:56.034,210] <dbg> slm_at_host: TX
    00> [00:03:08.624,969] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 46 54 50 3d  22 70 75 74 22 2c 22 74 |AT#XFTP= "put","t
    00>                                       65 73 74 2e 74 78 74 22                          |est.txt"
    00> [00:03:08.625,457] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:03:08.625,640] <inf> slm_at_host: Enter datamode
    00> [00:03:10.044,677] <dbg> slm_at_host.uart_callback: RX_RDY 22
    00> [00:03:10.044,738] <inf> slm_at_host: Raw send 22
    00> [00:03:10.044,738] <dbg> slm_at_host: RX-DATAMODE
    00>                                       74 68 69 73 20 69 73 20  74 65 73 74 20 63 6f 6e |this is  test con
    00> [00:03:10.068,847] <dbg> slm_at_host.uart_callback: RX_RDY 26
    00> [00:03:10.262,817] <dbg> slm_at_host: TX
    00>                                       32 32 37 20 45 6e 74 65  72 69 6e 67 20 50 61 73 |227 Ente ring Pas
    00>                                       73 69 76 65 20 4d 6f 64  65 20 28 31 34 39 2c 35 |sive Mod e (149,5
    00>                                       36 2c 32 30 34 2c 34 39  2c 32 34 32 2c 39 33 29 |6,204,49 ,242,93)
    00>                                       0d 0a                                            |..
    00> [00:03:10.545,837] <dbg> slm_at_host: TX
    00>                                       31 35 30 20 41 63 63 65  70 74 65 64 20 64 61 74 |150 Acce pted dat
    00>                                       61 20 63 6f 6e 6e 65 63  74 69 6f 6e 0d 0a       |a connec tion..
    00> [00:03:10.570,800] <dbg> slm_at_host: TX
    00>                                       32 32 36 2d 31 38 38 37  20 4b 62 79 74 65 73 20 |226-1887  Kbytes
    00>                                       75 73 65 64 20 28 30 25  29 20 2d 20 61 75 74 68 |used (0% ) - auth
    00>                                       6f 72 69 7a 65 64 3a 20  32 30 34 38 30 30 30 20 |orized:  2048000
    00>                                       4b 62 0d 0a 32 32 36 2d  46 69 6c 65 20 73 75 63 |Kb..226- File suc
    00>                                       63 65 73 73 66 75 6c 6c  79 20 74 72 61 6e 73 66 |cessfull y transf
    00>                                       65 72 72 65 64 0d 0a 32  32 36 20 30 2e 30 31 32 |erred..2 26 0.012
    00>                                       20 73 65 63 6f 6e 64 73  20 28 6d 65 61 73 75 72 | seconds  (measur
    00>                                       65 64 20 68 65 72 65 29  2c 20 31 2e 37 37 20 4b |ed here) , 1.77 K
    00>                                       62 79 74 65 73 20 70 65  72 20 73 65 63 6f 6e 64 |bytes pe r second
    00>                                       0d 0a                                            |..
    00> [00:03:10.571,441] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:03:10.581,054] <dbg> slm_at_host: TX
    00>                                       0d 0a 23 58 44 41 54 41  4d 4f 44 45 3a 20 30 0d |..#XDATA MODE: 0.
    00>                                       0a                                               |.
    00> [00:03:10.583,618] <inf> slm_at_host: Exit datamode
    00> [00:03:10.583,648] <inf> slm_ftp: datamode send: 0
    (Connection lost)
    # Logging stopped @ 31 Jan 2022 15:55:28
    # Logging started @ 31 Jan 2022 15:56:23
    00>                                       41 54 2b 43 46 55 4e 3d  31                      |AT+CFUN= 1[00:00:41.413,452] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 45 53 51                             |AT+CESQ
    00> [00:00:41.413,970] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:41.420,104] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:41.420,166] <dbg> slm_at_host: TX
    00>                                       2b 43 45 53 51 3a 20 39  39 2c 39 39 2c 32 35 35 |+CESQ: 9 9,99,255
    00>                                       2c 32 35 35 2c 31 30 2c  36 34 0d 0a 4f 4b 0d 0a |,255,10, 64..OK..
    00> [00:00:42.398,345] <dbg> slm_at_host: RX
    00> [00:00:42.398,864] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:42.404,998] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:42.405,059] <dbg> slm_at_host: TX
    00> [00:00:43.408,416] <dbg> slm_at_host: RX
    00> [00:00:43.408,935] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:43.415,069] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:43.415,130] <dbg> slm_at_host: TX
    00> [00:00:44.410,400] <dbg> slm_at_host: RX
    00> [00:00:44.410,919] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:44.417,053] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:44.417,114] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 39 2c 36  34 0d 0a 4f 4b 0d 0a    |,255,9,6 4..OK..
    00> [00:00:45.402,343] <dbg> slm_at_host: RX
    00> [00:00:45.402,862] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:45.408,996] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:45.409,057] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 37 2c 36  33 0d 0a 4f 4b 0d 0a    |,255,7,6 3..OK..
    00> [00:00:46.413,391] <dbg> slm_at_host: RX
    00> [00:00:46.413,909] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:46.420,043] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:46.420,104] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 38 2c 36  33 0d 0a 4f 4b 0d 0a    |,255,8,6 3..OK..
    00> [00:00:47.400,268] <dbg> slm_at_host: RX
    00> [00:00:47.400,787] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:47.406,921] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:47.406,951] <dbg> slm_at_host: TX
    00> [00:00:48.409,301] <dbg> slm_at_host: RX
    00> [00:00:48.409,820] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:48.415,954] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:48.416,015] <dbg> slm_at_host: TX
    00> [00:00:49.407,257] <dbg> slm_at_host: RX
    00> [00:00:49.407,775] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:49.413,909] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:49.413,970] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 38 2c 36  32 0d 0a 4f 4b 0d 0a    |,255,8,6 2..OK..
    00> [00:00:50.403,198] <dbg> slm_at_host: RX
    00> [00:00:50.403,717] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.409,851] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.409,912] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 37 2c 36  32 0d 0a 4f 4b 0d 0a    |,255,7,6 2..OK..
    00> [00:00:51.405,181] <dbg> slm_at_host: RX
    00> [00:00:51.405,700] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.411,834] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.411,895] <dbg> slm_at_host: TX
    00> [00:00:52.400,115] <dbg> slm_at_host: RX
    00> [00:00:52.400,634] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:52.406,768] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.406,799] <dbg> slm_at_host: TX
    00> [00:00:53.403,106] <dbg> slm_at_host: RX
    00> [00:00:53.403,625] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.409,759] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.409,820] <dbg> slm_at_host: TX
    00> [00:00:54.412,139] <dbg> slm_at_host: RX
    00> [00:00:54.412,658] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.418,792] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.418,853] <dbg> slm_at_host: TX
    00> [00:00:55.158,386] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:55.158,416] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 35  30 2c 32 2c 37 2c 31 0d |%CESQ: 5 0,2,7,1.
    00>                                       0a                                               |.
    00> [00:00:55.411,102] <dbg> slm_at_host: RX
    00> [00:00:55.411,621] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:55.417,755] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:55.417,785] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 37 2c 35  30 0d 0a 4f 4b 0d 0a    |,255,7,5 0..OK..
    00> [00:00:56.414,093] <dbg> slm_at_host: RX
    00> [00:00:56.414,611] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:56.414,825] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:56.414,886] <dbg> slm_at_host: TX
    00> [00:00:56.438,018] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:56.438,079] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 35  35 2c 32 2c 39 2c 31 0d |%CESQ: 5 5,2,9,1.
    00>                                       0a                                               |.
    00> [00:00:57.413,208] <dbg> slm_at_host: RX
    00> [00:00:57.413,726] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:57.419,860] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:57.419,891] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 39 2c 35  35 0d 0a 4f 4b 0d 0a    |,255,9,5 5..OK..
    00> [00:00:58.410,156] <dbg> slm_at_host: RX
    00> [00:00:58.410,675] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:58.416,809] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:58.416,870] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 39 2c 35  38 0d 0a 4f 4b 0d 0a    |,255,9,5 8..OK..
    00> [00:00:58.998,382] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:58.998,443] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 36  30 2c 33 2c 39 2c 31 0d |%CESQ: 6 0,3,9,1.
    00>                                       0a                                               |.
    00> [00:00:59.407,104] <dbg> slm_at_host: RX
    00> [00:00:59.407,623] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:59.413,757] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:59.413,787] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 39 2c 36  30 0d 0a 4f 4b 0d 0a    |,255,9,6 0..OK..
    00> [00:01:00.401,031] <dbg> slm_at_host: RX
    00> [00:01:00.401,550] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:00.407,684] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:00.407,745] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 38 2c 36  30 0d 0a 4f 4b 0d 0a    |,255,8,6 0..OK..
    00> [00:01:01.401,000] <dbg> slm_at_host: RX
    00> [00:01:01.401,489] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:01.407,623] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:01.407,653] <dbg> slm_at_host: TX
    00> [00:01:02.398,925] <dbg> slm_at_host: RX
    00> [00:01:02.399,444] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:02.405,578] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:02.405,639] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 37 2c 36  31 0d 0a 4f 4b 0d 0a    |,255,7,6 1..OK..
    00> [00:01:03.414,001] <dbg> slm_at_host: RX
    00> [00:01:03.414,520] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:03.420,654] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:03.420,684] <dbg> slm_at_host: TX
    00> [00:01:04.406,921] <dbg> slm_at_host: RX
    00> [00:01:04.407,440] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:04.413,574] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:04.413,635] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 39 2c 36  32 0d 0a 4f 4b 0d 0a    |,255,9,6 2..OK..
    00> [00:01:05.399,841] <dbg> slm_at_host: RX
    00> [00:01:05.400,360] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:05.406,494] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:05.406,555] <dbg> slm_at_host: TX
    00> [00:01:06.399,810] <dbg> slm_at_host: RX
    00> [00:01:06.400,299] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:06.406,433] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:06.406,463] <dbg> slm_at_host: TX
    00> [00:01:07.398,742] <dbg> slm_at_host: RX
    00> [00:01:07.399,261] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:07.405,395] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:07.405,456] <dbg> slm_at_host: TX
    00> [00:01:08.408,782] <dbg> slm_at_host: RX
    00> [00:01:08.409,301] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:08.415,435] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:08.415,496] <dbg> slm_at_host: TX
    00> [00:01:09.402,709] <dbg> slm_at_host: RX
    00> [00:01:09.403,228] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:09.409,393] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:09.409,454] <dbg> slm_at_host: TX
    00> [00:01:10.399,719] <dbg> slm_at_host: RX
    00> [00:01:10.400,238] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:10.406,372] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:10.406,402] <dbg> slm_at_host: TX
    00> [00:01:11.412,780] <dbg> slm_at_host: RX
    00> [00:01:11.413,299] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:11.419,433] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:11.419,494] <dbg> slm_at_host: TX
    00> [00:01:11.994,842] <dbg> slm_at_host: RX
    00> [00:01:11.995,330] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:11.995,483] <dbg> slm_at_host: TX
    00>                                       6e 0d 0a                                         |n..
    00> [00:01:11.995,544] <dbg> slm_at_host: TX
    00> [00:01:12.399,139] <dbg> slm_at_host: RX
    00> [00:01:12.399,658] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:12.405,792] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:12.405,853] <dbg> slm_at_host: TX
    00> [00:01:13.412,231] <dbg> slm_at_host: RX
    00> [00:01:13.412,750] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:13.418,884] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:13.418,914] <dbg> slm_at_host: TX
    00> [00:01:14.401,123] <dbg> slm_at_host: RX
    00> [00:01:14.401,641] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:14.407,775] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:01:14.407,836] <dbg> slm_at_host: TX
    00> [00:01:22.331,848] <dbg> slm_at_host: RX
    00> [00:01:22.332,336] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:22.332,519] <inf> slm_at_host: Enter datamode
    00> [00:01:23.603,515] <dbg> slm_at_host.uart_callback: RX_RDY 22
    00> [00:01:23.603,546] <inf> slm_at_host: Raw send 22
    00> [00:01:23.603,576] <dbg> slm_at_host: RX-DATAMODE
    00> [00:01:23.629,699] <dbg> slm_at_host.uart_callback: RX_RDY 26
    00> [00:01:23.750,122] <dbg> slm_at_host: TX
    00>                                       36 2c 32 30 34 2c 34 39  2c 32 34 38 2c 31 35 39 |6,204,49 ,248,159
    00>                                       29 0d 0a                                         |)..
    00> [00:01:24.290,130] <dbg> slm_at_host: TX
    00> [00:01:24.337,310] <dbg> slm_at_host: TX
    00>                                       65 72 72 65 64 0d 0a 32  32 36 20 30 2e 30 30 39 |erred..2 26 0.009
    00>                                       65 64 20 68 65 72 65 29  2c 20 32 2e 31 37 20 4b |ed here) , 2.17 K
    00>                                       0d 0a                                            |..
    00> [00:01:24.337,951] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:24.347,564] <dbg> slm_at_host: TX
    00>                                       0a                                               |.
    00> [00:01:24.350,158] <inf> slm_at_host: Exit datamode
    00> [00:01:24.350,158] <inf> slm_ftp: datamode send: 0
    (Connection lost)
    # Logging stopped @ 31 Jan 2022 15:57:13
    Here is a log of the connection/ping when it does manage to connect and the SLM failure following:
    # Logging started @ 31 Jan 2022 16:02:00
    00> [00:00:48.158,874] <dbg> slm_at_host: RX
    00>                                       41 54                                            |AT
    00> [00:00:48.159,362] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:48.165,405] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:48.165,435] <dbg> slm_at_host: TX
    00>                                       4f 4b 0d 0a                                      |OK..
    00> [00:00:49.096,282] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 46 55 4e 3f                          |AT+CFUN?
    00> [00:00:49.096,801] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:49.102,905] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:49.102,935] <dbg> slm_at_host: TX
    00>                                       2b 43 46 55 4e 3a 20 30  0d 0a 4f 4b 0d 0a       |+CFUN: 0 ..OK..
    00> [00:00:49.911,926] <dbg> slm_at_host: RX
    00> [00:00:49.912,445] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:49.948,303] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:49.948,333] <dbg> slm_at_host: TX
    00> [00:00:50.855,010] <dbg> slm_at_host: RX
    00> [00:00:50.855,529] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.855,590] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.855,621] <dbg> slm_at_host: TX
    00>                                       2b 43 46 55 4e 3a 20 31  0d 0a 4f 4b 0d 0a       |+CFUN: 1 ..OK..
    00> [00:00:50.876,068] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 53 4e 3d  31                      |AT+CGSN= 1
    00> [00:00:50.876,586] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.876,708] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.876,739] <dbg> slm_at_host: TX
    00>                                       2b 43 47 53 4e 3a 20 22  33 35 32 36 35 36 31 30 |+CGSN: " 35265610
    00>                                       36 31 31 34 30 36 32 22  0d 0a 4f 4b 0d 0a       |6114062" ..OK..
    00> [00:00:50.898,193] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 4d 49                             |AT+CGMI
    00> [00:00:50.898,712] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.900,848] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.900,909] <dbg> slm_at_host: TX
    00>                                       4e 6f 72 64 69 63 20 53  65 6d 69 63 6f 6e 64 75 |Nordic S emicondu
    00>                                       63 74 6f 72 20 41 53 41  0d 0a 4f 4b 0d 0a       |ctor ASA ..OK..
    00> [00:00:50.915,313] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 4d 4d                             |AT+CGMM
    00> [00:00:50.915,832] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.915,924] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.915,985] <dbg> slm_at_host: TX
    00>                                       6e 52 46 39 31 36 30 2d  53 49 43 41 0d 0a 4f 4b |nRF9160- SICA..OK
    00>                                       0d 0a                                            |..
    00> [00:00:50.926,361] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 4d 52                             |AT+CGMR
    00> [00:00:50.926,879] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.926,940] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.926,971] <dbg> slm_at_host: TX
    00>                                       6d 66 77 5f 6e 72 66 39  31 36 30 5f 31 2e 33 2e |mfw_nrf9 160_1.3.
    00>                                       31 0d 0a 4f 4b 0d 0a                             |1..OK..
    00> [00:00:50.943,389] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 45 4d 4f 44  45 3f                   |AT+CEMOD E?
    00> [00:00:50.943,908] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.944,305] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.944,366] <dbg> slm_at_host: TX
    00>                                       2b 43 45 4d 4f 44 45 3a  20 32 0d 0a 4f 4b 0d 0a |+CEMODE:  2..OK..
    00> [00:00:50.965,820] <dbg> slm_at_host: RX
    00>                                       41 54 25 58 43 42 41 4e  44 3d 3f                |AT%XCBAN D=?
    00> [00:00:50.966,339] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.966,552] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.966,613] <dbg> slm_at_host: TX
    00>                                       25 58 43 42 41 4e 44 3a  20 28 31 2c 32 2c 33 2c |%XCBAND:  (1,2,3,
    00>                                       34 2c 35 2c 38 2c 31 32  2c 31 33 2c 31 38 2c 31 |4,5,8,12 ,13,18,1
    00>                                       39 2c 32 30 2c 32 35 2c  32 36 2c 32 38 2c 36 36 |9,20,25, 26,28,66
    00>                                       29 0d 0a 4f 4b 0d 0a                             |)..OK..
    00> [00:00:50.991,088] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4d 45 45 3f                          |AT+CMEE?
    00> [00:00:50.991,607] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:50.991,638] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:50.991,699] <dbg> slm_at_host: TX
    00>                                       2b 43 4d 45 45 3a 20 30  0d 0a 4f 4b 0d 0a       |+CMEE: 0 ..OK..
    00> [00:00:51.007,110] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4d 45 45 3d  31                      |AT+CMEE= 1
    00> [00:00:51.007,629] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.007,690] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.007,751] <dbg> slm_at_host: TX
    00> [00:00:51.022,155] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4e 45 43 3f                          |AT+CNEC?
    00> [00:00:51.022,644] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.022,735] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.022,796] <dbg> slm_at_host: TX
    00>                                       2b 43 4e 45 43 3a 20 30  0d 0a 4f 4b 0d 0a       |+CNEC: 0 ..OK..
    00> [00:00:51.040,222] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4e 45 43 3d  32 34                   |AT+CNEC= 24
    00> [00:00:51.040,740] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.040,832] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.040,863] <dbg> slm_at_host: TX
    00> [00:00:51.051,239] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 45 52 45  50 3f                   |AT+CGERE P?
    00> [00:00:51.051,757] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.051,849] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.051,910] <dbg> slm_at_host: TX
    00>                                       2b 43 47 45 52 45 50 3a  20 30 2c 30 0d 0a 4f 4b |+CGEREP:  0,0..OK
    00>                                       0d 0a                                            |..
    00> [00:00:51.065,277] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 44 43 4f  4e 54 3f                |AT+CGDCO NT?
    00> [00:00:51.065,795] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.065,917] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.065,948] <dbg> slm_at_host: TX
    00>                                       2b 43 47 44 43 4f 4e 54  3a 20 30 2c 22 22 2c 22 |+CGDCONT : 0,"","
    00>                                       22 2c 22 22 2c 30 2c 30  0d 0a 4f 4b 0d 0a       |","",0,0 ..OK..
    00> [00:00:51.089,416] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 41 43 54  3f                      |AT+CGACT ?
    00> [00:00:51.089,935] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.090,026] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.090,057] <dbg> slm_at_host: TX
    00>                                       2b 43 47 41 43 54 3a 20  30 2c 30 0d 0a 4f 4b 0d |+CGACT:  0,0..OK.
    00>                                       0a                                               |.
    00> [00:00:51.107,482] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 47 45 52 45  50 3d 31                |AT+CGERE P=1
    00> [00:00:51.108,001] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.108,093] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.108,123] <dbg> slm_at_host: TX
    00> [00:00:51.120,513] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 49 4e 44 3d  31 2c 31 2c 31          |AT+CIND= 1,1,1
    00> [00:00:51.121,032] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.121,368] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.121,429] <dbg> slm_at_host: TX
    00> [00:00:51.135,833] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 45 52 45 47  3d 35                   |AT+CEREG =5
    00> [00:00:51.136,352] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.136,474] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.136,505] <dbg> slm_at_host: TX
    00> [00:00:51.149,902] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 45 52 45 47  3f                      |AT+CEREG ?
    00> [00:00:51.150,421] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.150,604] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.150,665] <dbg> slm_at_host: TX
    00>                                       2b 43 45 52 45 47 3a 20  35 2c 32 2c 22 32 42 31 |+CEREG:  5,2,"2B1
    00>                                       43 22 2c 22 30 31 41 46  45 41 30 43 22 2c 37 0d |C","01AF EA0C",7.
    00>                                       0a 4f 4b 0d 0a                                   |.OK..
    00> [00:00:51.173,126] <dbg> slm_at_host: RX
    00>                                       41 54 25 43 45 53 51 3d  31                      |AT%CESQ= 1
    00> [00:00:51.173,645] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.173,736] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.173,767] <dbg> slm_at_host: TX
    00> [00:00:51.174,438] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.174,499] <dbg> slm_at_host: TX
    00>                                       25 43 45 53 51 3a 20 36  34 2c 33 2c 31 31 2c 31 |%CESQ: 6 4,3,11,1
    00>                                       0d 0a                                            |..
    00> [00:00:51.190,185] <dbg> slm_at_host: RX
    00> [00:00:51.190,704] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.190,826] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.190,887] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 31 31 2c  36 34 0d 0a 4f 4b 0d 0a |,255,11, 64..OK..
    00> [00:00:51.207,305] <dbg> slm_at_host: RX
    00>                                       41 54 25 58 53 49 4d 3d  31                      |AT%XSIM= 1
    00> [00:00:51.207,824] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.207,916] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.207,946] <dbg> slm_at_host: TX
    00> [00:00:51.221,343] <dbg> slm_at_host: RX
    00>                                       41 54 25 58 53 49 4d 3f                          |AT%XSIM?
    00> [00:00:51.221,862] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.221,954] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.221,984] <dbg> slm_at_host: TX
    00>                                       25 58 53 49 4d 3a 20 31  0d 0a 4f 4b 0d 0a       |%XSIM: 1 ..OK..
    00> [00:00:51.247,467] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 50 49 4e 3f                          |AT+CPIN?
    00> [00:00:51.247,985] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.248,046] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.248,107] <dbg> slm_at_host: TX
    00>                                       2b 43 50 49 4e 3a 20 52  45 41 44 59 0d 0a 4f 4b |+CPIN: R EADY..OK
    00>                                       0d 0a                                            |..
    00> [00:00:51.267,578] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 50 49 4e 52  3d 22 53 49 4d 20 50 49 |AT+CPINR ="SIM PI
    00>                                       4e 22                                            |N"
    00> [00:00:51.268,066] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.282,867] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.282,928] <dbg> slm_at_host: TX
    00>                                       2b 43 50 49 4e 52 3a 20  22 53 49 4d 20 50 49 4e |+CPINR:  "SIM PIN
    00>                                       22 2c 33 0d 0a 4f 4b 0d  0a                      |",3..OK. .
    00> [00:00:51.298,339] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 49 4d 49                             |AT+CIMI
    00> [00:00:51.298,858] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:51.299,041] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:51.299,102] <dbg> slm_at_host: TX
    00>                                       33 30 32 37 36 30 30 30  30 38 37 33 35 35 33 0d |30276000 0873553.
    00> [00:00:52.826,812] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.826,843] <dbg> slm_at_host: TX
    00>                                       2b 43 47 45 56 3a 20 4d  45 20 50 44 4e 20 41 43 |+CGEV: M E PDN AC
    00>                                       54 20 30 0d 0a                                   |T 0..
    00> [00:00:52.827,209] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.829,132] <dbg> slm_at_host: TX
    00>                                       2b 43 45 52 45 47 3a 20  31 2c 22 32 42 31 43 22 |+CEREG:  1,"2B1C"
    00>                                       2c 22 30 31 41 46 45 41  30 43 22 2c 37 2c 2c 2c |,"01AFEA 0C",7,,,
    00>                                       22 31 31 31 30 30 30 30  30 22 2c 22 31 31 31 30 |"1110000 0","1110
    00>                                       30 30 30 30 22 0d 0a                             |0000"..
    00> [00:00:52.829,345] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.834,197] <dbg> slm_at_host: TX
    00>                                       2b 43 49 4e 44 3a 20 22  73 65 72 76 69 63 65 22 |+CIND: " service"
    00>                                       2c 31 0d 0a                                      |,1..
    00> [00:00:52.843,261] <dbg> slm_at_host: RX
    00> [00:00:52.843,780] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:52.843,963] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.843,994] <dbg> slm_at_host: TX
    00>                                       2b 43 47 44 43 4f 4e 54  3a 20 30 2c 22 49 50 22 |+CGDCONT : 0,"IP"
    00>                                       2c 22 6d 32 6d 2e 74 65  6c 75 73 2e 69 6f 74 22 |,"m2m.te lus.iot"
    00>                                       2c 22 31 30 2e 32 30 35  2e 32 31 31 2e 31 34 31 |,"10.205 .211.141
    00>                                       22 2c 30 2c 30 0d 0a 4f  4b 0d 0a                |",0,0..O K..
    00> [00:00:52.868,469] <dbg> slm_at_host: RX
    00> [00:00:52.868,988] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:52.869,079] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:52.869,140] <dbg> slm_at_host: TX
    00>                                       2b 43 47 41 43 54 3a 20  30 2c 31 0d 0a 4f 4b 0d |+CGACT:  0,1..OK.
    00>                                       0a                                               |.
    00> [00:00:53.665,039] <dbg> slm_at_host: RX
    00> [00:00:53.665,557] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.671,661] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.671,691] <dbg> slm_at_host: TX
    00> [00:00:53.693,145] <dbg> slm_at_host: RX
    00> [00:00:53.693,664] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.699,829] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.699,859] <dbg> slm_at_host: TX
    00> [00:00:53.717,285] <dbg> slm_at_host: RX
    00> [00:00:53.717,803] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.723,907] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.723,937] <dbg> slm_at_host: TX
    00> [00:00:53.736,328] <dbg> slm_at_host: RX
    00> [00:00:53.736,846] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.743,011] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.743,041] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.755,432] <dbg> slm_at_host: RX
    00> [00:00:53.755,950] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.762,054] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.762,084] <dbg> slm_at_host: TX
    00> [00:00:53.780,517] <dbg> slm_at_host: RX
    00> [00:00:53.781,036] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.787,170] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.787,200] <dbg> slm_at_host: TX
    00> [00:00:53.800,598] <dbg> slm_at_host: RX
    00> [00:00:53.801,116] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.807,373] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.807,434] <dbg> slm_at_host: TX
    00> [00:00:53.828,887] <dbg> slm_at_host: RX
    00> [00:00:53.829,406] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.835,479] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.835,540] <dbg> slm_at_host: TX
    00>                                       2b 43 4d 45 45 3a 20 31  0d 0a 4f 4b 0d 0a       |+CMEE: 1 ..OK..
    00> [00:00:53.850,921] <dbg> slm_at_host: RX
    00> [00:00:53.851,440] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.855,468] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.855,499] <dbg> slm_at_host: TX
    00>                                       2b 43 4e 45 43 3a 20 32  34 0d 0a 4f 4b 0d 0a    |+CNEC: 2 4..OK..
    00> [00:00:53.867,889] <dbg> slm_at_host: RX
    00> [00:00:53.868,408] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.874,542] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.874,572] <dbg> slm_at_host: TX
    00>                                       2b 43 47 45 52 45 50 3a  20 31 2c 30 0d 0a 4f 4b |+CGEREP:  1,0..OK
    00>                                       0d 0a                                            |..
    00> [00:00:53.888,977] <dbg> slm_at_host: RX
    00> [00:00:53.889,495] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.894,531] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.894,592] <dbg> slm_at_host: TX
    00> [00:00:53.908,996] <dbg> slm_at_host: RX
    00> [00:00:53.909,515] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.909,606] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.909,637] <dbg> slm_at_host: TX
    00> [00:00:53.923,034] <dbg> slm_at_host: RX
    00> [00:00:53.923,553] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.923,828] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.923,889] <dbg> slm_at_host: TX
    00>                                       2b 43 45 52 45 47 3a 20  35 2c 31 2c 22 32 42 31 |+CEREG:  5,1,"2B1
    00>                                       43 22 2c 22 30 31 41 46  45 41 30 43 22 2c 37 2c |C","01AF EA0C",7,
    00>                                       2c 2c 22 31 31 31 30 30  30 30 30 22 2c 22 31 31 |,,"11100 000","11
    00>                                       31 30 30 30 30 30 22 0d  0a 4f 4b 0d 0a          |100000". .OK..
    00> [00:00:53.943,298] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4f 50 53 3d  33 2c 32                |AT+COPS= 3,2
    00> [00:00:53.943,817] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.943,908] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.943,939] <dbg> slm_at_host: TX
    00> [00:00:53.958,343] <dbg> slm_at_host: RX
    00>                                       41 54 2b 43 4f 50 53 3f                          |AT+COPS?
    00> [00:00:53.958,862] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.958,953] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.959,014] <dbg> slm_at_host: TX
    00>                                       2b 43 4f 50 53 3a 20 30  2c 32 2c 22 33 30 32 32 |+COPS: 0 ,2,"3022
    00>                                       32 30 22 2c 37 0d 0a 4f  4b 0d 0a                |20",7..O K..
    00> [00:00:53.983,489] <dbg> slm_at_host: RX
    00>                                       41 54 25 58 43 42 41 4e  44                      |AT%XCBAN D
    00> [00:00:53.984,008] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:53.984,130] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:53.984,161] <dbg> slm_at_host: TX
    00>                                       25 58 43 42 41 4e 44 3a  20 31 32 0d 0a 4f 4b 0d |%XCBAND:  12..OK.
    00>                                       0a                                               |.
    00> [00:00:54.000,579] <dbg> slm_at_host: RX
    00> [00:00:54.001,098] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.007,324] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.007,385] <dbg> slm_at_host: TX
    00> [00:00:54.029,846] <dbg> slm_at_host: RX
    00> [00:00:54.030,364] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.036,499] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.036,560] <dbg> slm_at_host: TX
    00>                                       0a                                               |.
    00> [00:00:54.060,028] <dbg> slm_at_host: RX
    00> [00:00:54.060,546] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.066,680] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.066,711] <dbg> slm_at_host: TX
    00> [00:00:54.076,080] <dbg> slm_at_host: RX
    00> [00:00:54.076,599] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.076,904] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.076,934] <dbg> slm_at_host: TX
    00>                                       2c 32 35 35 2c 31 30 2c  36 33 0d 0a 4f 4b 0d 0a |,255,10, 63..OK..
    00> [00:00:54.096,374] <dbg> slm_at_host: RX
    00> [00:00:54.096,893] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.096,954] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.097,015] <dbg> slm_at_host: TX
    00> [00:00:54.111,419] <dbg> slm_at_host: RX
    00> [00:00:54.111,938] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.116,973] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.117,034] <dbg> slm_at_host: TX
    00> [00:00:54.130,432] <dbg> slm_at_host: RX
    00> [00:00:54.130,950] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.137,023] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.137,054] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.157,531] <dbg> slm_at_host: RX
    00>                                       4e 22                                            |N"
    00> [00:00:54.158,020] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.169,677] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.169,738] <dbg> slm_at_host: TX
    00> [00:00:54.192,199] <dbg> slm_at_host: RX
    00> [00:00:54.192,687] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:00:54.198,822] <dbg> slm_at_host: TX
    00>                                       0d 0a                                            |..
    00> [00:00:54.198,852] <dbg> slm_at_host: TX
    00> [00:01:04.305,236] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 50 49 4e 47  3d 22 63 61 70 74 75 73 |AT#XPING ="captus
    00>                                       2e 63 61 22 2c 34 35 2c  35 30 30 30 2c 35 2c 31 |.ca",45, 5000,5,1
    00>                                       30 30 30                                         |000
    00> [00:01:04.305,725] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:04.672,210] <inf> slm_icmp: Ping target's IPv4 address
    00> [00:01:04.673,461] <dbg> slm_at_host: TX
    00> [00:01:04.674,011] <dbg> slm_icmp.send_ping_wait_reply: Use PDN: 0
    00> [00:01:05.020,355] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  30 2e 33 34 36 20 73 65 |#XPING:  0.346 se
    00>                                       63 6f 6e 64 73 0d 0a                             |conds..
    00> [00:01:06.027,160] <dbg> slm_icmp.send_ping_wait_reply: Use PDN: 0
    00> [00:01:06.360,473] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  30 2e 33 32 37 20 73 65 |#XPING:  0.327 se
    00> [00:01:07.361,267] <dbg> slm_icmp.send_ping_wait_reply: Use PDN: 0
    00> [00:01:07.724,517] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  30 2e 33 36 33 20 73 65 |#XPING:  0.363 se
    00> [00:01:08.731,353] <dbg> slm_icmp.send_ping_wait_reply: Use PDN: 0
    00> [00:01:09.078,613] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  30 2e 33 34 31 20 73 65 |#XPING:  0.341 se
    00> [00:01:10.085,449] <dbg> slm_icmp.send_ping_wait_reply: Use PDN: 0
    00> [00:01:10.318,603] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  30 2e 32 32 36 20 73 65 |#XPING:  0.226 se
    00> [00:01:11.318,939] <inf> slm_icmp: Packets: Sent = 5, Received = 5, Lost = 0 (0% loss)
    00> [00:01:11.319,000] <dbg> slm_at_host: TX
    00>                                       23 58 50 49 4e 47 3a 20  61 76 65 72 61 67 65 20 |#XPING:  average
    00>                                       30 2e 33 32 31 20 73 65  63 6f 6e 64 73 0d 0a    |0.321 se conds..
    00> [00:01:11.319,061] <inf> slm_icmp: Approximate round trip times in milli-seconds:
    00>     Minimum = 226ms, Maximum = 363ms, Average = 320ms
    00> [00:01:18.808,013] <dbg> slm_at_host: RX
    00>                                       41 54 23 58 46 54 50 3d  22 6f 70 65 6e 22 2c 22 |AT#XFTP= "open","
    00>                                       <Removed login information for security>
    00> [00:01:18.808,502] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:19.846,099] <dbg> slm_at_host: TX
    00>                                       32 32 30 2d 2d 2d 2d 2d  2d 2d 2d 2d 2d 20 57 65 |220----- ----- We
    00>                                       6c 63 6f 6d 65 20 74 6f  20 50 75 72 65 2d 46 54 |lcome to  Pure-FT
    00>                                       50 64 20 5b 70 72 69 76  73 65 70 5d 20 5b 54 4c |Pd [priv sep] [TL
    00>                                       53 5d 20 2d 2d 2d 2d 2d  2d 2d 2d 2d 2d 0d 0a 32 |S] ----- -----..2
    00>                                       32 30 2d 59 6f 75 20 61  72 65 20 75 73 65 72 20 |20-You a re user
    00>                                       6e 75 6d 62 65 72 20 34  20 6f 66 20 35 30 20 61 |number 4  of 50 a
    00>                                       6c 6c 6f 77 65 64 2e 0d  0a 32 32 30 2d 4c 6f 63 |llowed.. .220-Loc
    00>                                       61 6c 20 74 69 6d 65 20  69 73 20 6e 6f 77 20 31 |al time  is now 1
    00>                                       36 3a 30 32 2e 20 53 65  72 76 65 72 20 70 6f 72 |6:02. Se rver por
    00>                                       74 3a 20 32 31 2e 0d 0a  32 32 30 2d 54 68 69 73 |t: 21... 220-This
    00>                                       20 69 73 20 61 20 70 72  69 76 61 74 65 20 73 79 | is a pr ivate sy
    00>                                       73 74 65 6d 20 2d 20 4e  6f 20 61 6e 6f 6e 79 6d |stem - N o anonym
    00>                                       6f 75 73 20 6c 6f 67 69  6e 0d 0a 32 32 30 2d 49 |ous logi n..220-I
    00>                                       50 76 36 20 63 6f 6e 6e  65 63 74 69 6f 6e 73 20 |Pv6 conn ections
    00>                                       61 72 65 20 61 6c 73 6f  20 77 65 6c 63 6f 6d 65 |are also  welcome
    00>                                       20 6f 6e 20 74 68 69 73  20 73 65 72 76 65 72 2e | on this  server.
    00>                                       0d 0a 32 32 30 20 59 6f  75 20 77 69 6c 6c 20 62 |..220 Yo u will b
    00>                                       65 20 64 69 73 63 6f 6e  6e 65 63 74 65 64 20 61 |e discon nected a
    00>                                       66 74 65 72 20 31 35 20  6d 69 6e 75 74 65 73 20 |fter 15  minutes
    00>                                       6f 66 20 69 6e 61 63 74  69 76 69 74 79 2e 0d 0a |of inact ivity...
    00> [00:01:20.026,855] <dbg> slm_at_host: TX
    00>                                       35 30 34 20 55 6e 6b 6e  6f 77 6e 20 63 6f 6d 6d |504 Unkn own comm
    00>                                       61 6e 64 0d 0a                                   |and..
    00> [00:01:20.154,876] <dbg> slm_at_host: TX
    00>                                       74 75 73 2e 63 61 20 4f  4b 2e 20 50 61 73 73 77 |tus.ca O K. Passw
    00>                                       6f 72 64 20 72 65 71 75  69 72 65 64 0d 0a       |ord requ ired..
    00> [00:01:22.761,077] <dbg> slm_at_host: TX
    00>                                       32 33 30 2d 4f 4b 2e 20  43 75 72 72 65 6e 74 20 |230-OK.  Current
    00>                                       72 65 73 74 72 69 63 74  65 64 20 64 69 72 65 63 |restrict ed direc
    00>                                       74 6f 72 79 20 69 73 20  2f 0d 0a 32 33 30 20 31 |tory is  /..230 1
    00>                                       38 38 37 20 4b 62 79 74  65 73 20 75 73 65 64 20 |887 Kbyt es used
    00>                                       28 30 25 29 20 2d 20 61  75 74 68 6f 72 69 7a 65 |(0%) - a uthorize
    00>                                       64 3a 20 32 30 34 38 30  30 30 20 4b 62 0d 0a    |d: 20480 00 Kb..
    00> [00:01:22.761,169] <dbg> slm_at_host: TX
    00> [00:01:28.571,350] <dbg> slm_at_host: RX
    00> [00:01:28.571,838] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:28.893,310] <dbg> slm_at_host: TX
    00> [00:01:28.893,371] <dbg> slm_at_host: TX
    00> [00:01:41.001,739] <dbg> slm_at_host: RX
    00> [00:01:41.002,227] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:41.002,410] <inf> slm_at_host: Enter datamode
    00> [00:01:42.204,925] <dbg> slm_at_host.uart_callback: RX_RDY 22
    00> [00:01:42.204,986] <inf> slm_at_host: Raw send 22
    00> [00:01:42.204,986] <dbg> slm_at_host: RX-DATAMODE
    00> [00:01:42.222,045] <dbg> slm_at_host.uart_callback: RX_RDY 26
    00> [00:01:42.505,126] <dbg> slm_at_host: TX
    00>                                       36 2c 32 30 34 2c 34 39  2c 32 30 39 2c 38 31 29 |6,204,49 ,209,81)
    00>                                       0d 0a                                            |..
    00> [00:01:42.944,885] <dbg> slm_at_host: TX
    00> [00:01:42.982,940] <dbg> slm_at_host: TX
    00>                                       65 72 72 65 64 0d 0a 32  32 36 20 30 2e 30 31 30 |erred..2 26 0.010
    00>                                       65 64 20 68 65 72 65 29  2c 20 32 2e 30 34 20 4b |ed here) , 2.04 K
    00>                                       0d 0a                                            |..
    00> [00:01:42.983,581] <dbg> slm_at_host.uart_callback: RX_DISABLED
    00> [00:01:42.993,194] <dbg> slm_at_host: TX
    00>                                       0a                                               |.
    00> [00:01:42.995,788] <inf> slm_at_host: Exit datamode
    00> [00:01:42.995,788] <inf> slm_ftp: datamode send: 0
    # Logging stopped @ 31 Jan 2022 16:03:12
