Nrf52 simple Baremetal timer function, CPU reset if interrupt enabled.
Trying to use the basic baremetal mode as my application is very simple and dont want to go through RTOS stuff.
I tried with Timer and RTC, both case if I enable the interrupt then the cpu gets rebooted.
Following is the code, not sure if it is the way I am building the code or some other parameter is messing things up.
This example if basically "..\..\sdk\nRF5_SDK_17.1.0_ddde560\examples\peripheral\timer"
I will try to upload the zip of the full project. Different peripheral works except the Interrupt part.
#include <stdio.h>
#include <nrf.h>
#define PIN_LED1 (17UL) // nrf52-dk
volatile bool bLED1Set= false;
// Start LFCLK (32kHz) crystal oscillator. If you don't have crystal on your board, choose RCOSC instead.
NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos;
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
// 32kHz timer period
NRF_RTC0->PRESCALER = 0;
// 30.5ms us compare value, generates EVENTS_COMPARE[0]
NRF_RTC0->CC[0] = 1000;
// Enable EVENTS_COMPARE[0] generation
NRF_RTC0->EVTENSET = RTC_EVTENSET_COMPARE0_Enabled << RTC_EVTENSET_COMPARE0_Pos;
// Enable IRQ on EVENTS_COMPARE[0]
NRF_RTC0->INTENSET = RTC_INTENSET_COMPARE0_Enabled << RTC_INTENSET_COMPARE0_Pos;
// Enable RTC IRQ and start the RTC
NVIC_EnableIRQ(RTC0_IRQn);
NRF_RTC0->TASKS_START = 1;
// Configure GPIO pin as output with standard drive strength.
NRF_GPIO->PIN_CNF[PIN_LED1] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos) |
(GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) |
(GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) |
(GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) |
(GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos);
while (1)
// __WFE();
if(bLED1Set){
NRF_GPIO->OUTCLR = (1UL << PIN_LED1);
bLED1Set = false;
}else{
NRF_GPIO->OUTSET = (1UL << PIN_LED1);
bLED1Set = true;
// This IRQ handler will trigger every 30.5 ms
void RTC0_IRQHandler(void)
volatile uint32_t dummy;
if (NRF_RTC0->EVENTS_COMPARE[0] == 1)
NRF_RTC0->EVENTS_COMPARE[0] = 0;
// Increment compare value with 30.5 ms from current time.
NRF_RTC0->CC[0] = NRF_RTC0->COUNTER + 1000;
// Read back event register so ensure we have cleared it before exiting IRQ handler.
dummy = NRF_RTC0->EVENTS_COMPARE[0];
dummy;
  • Hi
    Any project you build in Zephyr will have the Zephyr RTOS running underneath, and this affects how interrupts should be configured.
    Essentially interrupts in Zephyr can be set up like this:
    IRQ_DIRECT_CONNECT(RTC0_IRQn, 0, my_rtc0_irq_handler, 0);
    irq_enable(RTC0_IRQn);
    More information about the IRQ_CONNECT and IRQ_DIRECT_CONNECT macros can be found here.
    Best regards
    Torbjørn
