How to port the Zigbee Network Coordinator sample from the nRF52840DK to the nRF52840 dongle
I'm trying to implement the Zigbee coordinator sample on the nRF52840 dongle.  Although I've received a little bit of guidance on how to adapt the nRF52840DK implementation from my local Nordic rep, neither he nor I are enjoying any success.  Surely there must be others that have done this before, no?  Once I get this sample working, I would like to add the CLI shell to the same sample.  Can anyone provide some desperately-needed assistance?  I am building my code using nRF Connect SDK v1.8.0 in VS Code on a Windows 10 machine and have successfully built and tested the very same sample on the DK board without issue.
  • Hi Jody,
    I decided to test this myself. All the changes I made can be seen in the file zigbee_shell.diff, but I have also written it out here:
    First I created a nrf52840dongle_nrf52840.conf file for configurations specific to nrf52840 Dongle:
    CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=51
    CONFIG_SHELL_BACKEND_SERIAL=y
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PRODUCT="Zigbee Network Coordinator"
    CONFIG_USB_DEVICE_MANUFACTURER="Nordic Semiconductor ASA"
    CONFIG_USB_DEVICE_VID=0x1915
    CONFIG_USB_DEVICE_PID=0x0100
    CONFIG_UART_LINE_CTRL=y
    I added the following to CMakeLists.txt so that the nrf52840dongle_nrf52840.conf file would be added to the configurations when nrf52840dongle_nrf52840 is chosen as board:
    set(CONF_FILE "prj.conf")
    if (EXISTS boards/${BOARD}.conf)
      list(APPEND CONF_FILE boards/${BOARD}.conf)
    endif()
    In nrf52840dongle_nrf52840.overlay I added the USB device controller by adding zephyr,shell-uart = &cdc_acm_uart0 and &zephyr_udc0:
    	chosen {
    		zephyr,entropy = &rng;
    		zephyr,shell-uart = &cdc_acm_uart0;
    	buttons {
    		compatible = "gpio-keys";
    		rst_button0: rst_button_0 {
    			gpios = <&gpio0 19 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Reset button";
    	aliases {
    		rst0 = &rst_button0;
    &zephyr_udc0 {
    	cdc_acm_uart0: cdc_acm_uart0 {
    		compatible = "zephyr,cdc-acm-uart";
    		label = "CDC_ACM_0";
    Removed the following configurations from prj.conf:
    CONFIG_SERIAL=y
    # Make sure printk is not printing to the UART console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    Then added the configurations for Zigbee Shell in the same file:
    # Shell
    CONFIG_SHELL=y
    CONFIG_ZIGBEE_SHELL=y
    Lastly, I enabled the USB device in main.c by including the file usb/usb_device.h, and calling usb_enable(NULL); right before configure_gpio();
    I have not tested this extensively, so there might be some issues, but I was able to issue Zigbee Shell commands to the Dongle successfully using this. I am uploading the sample here for you as well.
    diff --git a/zigbee/network_coordinator_dongle/CMakeLists.txt b/zigbee/network_coordinator_dongle/CMakeLists.txt
    index 2e6c804..5a0c733 100644
    --- a/zigbee/network_coordinator_dongle/CMakeLists.txt
    +++ b/zigbee/network_coordinator_dongle/CMakeLists.txt
    @@ -6,6 +6,12 @@
     cmake_minimum_required(VERSION 3.20.0)
    +set(CONF_FILE "prj.conf")
    +if (EXISTS boards/${BOARD}.conf)
    +  list(APPEND CONF_FILE boards/${BOARD}.conf)
    +endif()
     find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
     project("Zigbee coordinator")
    diff --git a/zigbee/network_coordinator_dongle/boards/nrf52840dongle_nrf52840.overlay b/zigbee/network_coordinator_dongle/boards/nrf52840dongle_nrf52840.overlay
    index b5f36b9..0f48d4b 100644
    --- a/zigbee/network_coordinator_dongle/boards/nrf52840dongle_nrf52840.overlay
    +++ b/zigbee/network_coordinator_dongle/boards/nrf52840dongle_nrf52840.overlay
    @@ -4,9 +4,12 @@
     	chosen {
    +		zephyr,shell-uart = &cdc_acm_uart0;
     	buttons {
    @@ -21,3 +24,10 @@
    +&zephyr_udc0 {
    +	cdc_acm_uart0: cdc_acm_uart0 {
    +		compatible = "zephyr,cdc-acm-uart";
    +		label = "CDC_ACM_0";
    diff --git a/zigbee/network_coordinator_dongle/prj.conf b/zigbee/network_coordinator_dongle/prj.conf
    index 42155ec..109e624 100644
    --- a/zigbee/network_coordinator_dongle/prj.conf
    +++ b/zigbee/network_coordinator_dongle/prj.conf
    @@ -7,13 +7,8 @@
     CONFIG_NCS_SAMPLES_DEFAULTS=y
    -CONFIG_SERIAL=y
     CONFIG_GPIO=y
    -# Make sure printk is not printing to the UART console
    -CONFIG_CONSOLE=y
    -CONFIG_UART_CONSOLE=y
     CONFIG_HEAP_MEM_POOL_SIZE=2048
     CONFIG_MAIN_THREAD_PRIORITY=7
    @@ -21,6 +16,10 @@ CONFIG_ZIGBEE=y
     CONFIG_ZIGBEE_APP_UTILS=y
     CONFIG_ZIGBEE_ROLE_COORDINATOR=y
    +# Shell
    +CONFIG_SHELL=y
    +CONFIG_ZIGBEE_SHELL=y
     # Enable DK LED and Buttons library
     CONFIG_DK_LIBRARY=y
    diff --git a/zigbee/network_coordinator_dongle/src/main.c b/zigbee/network_coordinator_dongle/src/main.c
    index 3023f83..d45a9bc 100644
    --- a/zigbee/network_coordinator_dongle/src/main.c
    +++ b/zigbee/network_coordinator_dongle/src/main.c
    @@ -10,6 +10,7 @@
     #include <zephyr.h>
     #include <device.h>
    +#include <usb/usb_device.h>
     #include <logging/log.h>
     #include <dk_buttons_and_leds.h>
    @@ -310,6 +311,9 @@ void main(void)
     	LOG_INF("Starting ZBOSS Coordinator example");
    +	/* Enable USB */
    +	usb_enable(NULL);
     	/* Initialize */
     	configure_gpio();
    network_coordinator_shell_dongle.zip
    Marte
  • Hi, Marte:
    Fantastic!  I need to get a few more hours of sleep, but I will verify your solution later today.
    You rock!
    Many thanks & best regards,
    Jody
  • Hi, Marte:
    I just verified your solution and it is PERFECT!  Thank you so much for your superb assistance.  Clap tone2Clap tone2Clap tone2Thumbsup tone2
    Jody
  • Hi Jody,
    Great to hear that it is working on your end as well! I am happy to help Slight smile
    Marte
