how to transfer data from nRF52840DK to raspberry pi 4 without deploying bluetooth ble5 ?
hello
i want to send the data from my 5 of nRF52840DK to 1 of raspberry pi4  , i known the nRF52840dk has built-in bluetooth ble5 and raspberry pi 4 also integrate bluetooth ble5 as well
BUT i do not want to send data with the bluetooth channel ,**  i want to transfer or send data from 5 nRF52840dk to 1 raspberry pi 4  WITH CABLE ** via GPIO pin or UART or SPI , i do not  know much about those ,
 how to send data from 5 nrf52840dk to 1 raspberry pi 4 with cable connection ?
  • very thanks
    i have 2 questions below
    question 1 --->except  SPI ,  with the condition for the length of wire  /cable 120 cm , ---> are there other way to send data with lesser loss or without loss ( for example such as UART or I2C or other way ) ?
    question 2   as you said , the nRF52810DK  will act as slave , for programming , once sending the data by the slave configuration of MISO ,MOSI SCLK, MOSI, CS pin to send or communicate/exchange data with the raspberry pi4
    on the side of nRF52840DK , i will have to use segger embed studio with c/c++ for programming
    however, instead to program with python or c/c++ on the side of raspberry pi4 that needs to receive or communicate /exchange data from nRF52840Dk , so -->  Will i be able to use or deploy Nodejs  to program the raspberry pi4  in order to be able to read the data that has been sent from nRF52840DK with SPI communication ??  Nodejs - SPI link and  nodejs - SPI device * note; i am new for c/c++ or python because i am app/ web developer , i ask question 2 because it deploys different method / different programming language to communicate data each other instead of using the c/c++ as the side of nRF52840DK  , i want to know if i program the raspbeery pi 4 with nodejs as the nodejs - SPI documentation on this link Nodejs - SPI link and  nodejs - SPI device , then ---> the raspberry pi4 will be able to read the data that has been sent from nRF52840dk with the slave configuration of MISO ,MOSI SCLK, MOSI, CS pin from the nRF5284DK documentation and Sumair youtube video or not  ?
    please let me know  this question 2 as well
  • Hi
    1. In all these cabled instances it's recommended to keep the wires as short and simple as possible. Will you not be able to use wires shorter than what's recommended?
    2. Yes, no matter what language two devices using SPI are programmed in, the SPI peripheral won't care what language they both "speak" as it will just transfer data from one end to the other, and then each device handles that data so that it's readable on that side. One device being C/C++ and one being nodejs shouldn't have anything to say.
    Simon
  • 1. if in my case , need the length of cable 120 cm , how to figure out ? still deploying SPI or other way , please recommend me
    2. thanks , for the second answer , both board ( raspberry pi 4 and nRF52840dk . will be able to speak together with SPI  even though raspberry pi4 deploys nodejs and nRF52840dk deploys c/c++
  • Hi
    1. I would go ahead with SPI if I were you, but would keep this in mind, and make sure to do thorough testing to make sure it works as intended.
    2. Yes.
    Simon
