dfu via ota
Hi all,
I'am doing DFU via OTA
The device will be in bootloader mode ?
my current application has a thread running when i'am initiating DFU via OTA in nrf_connect app,
the DFU process will start and complete but thread will be running simultaneously how can i stop my current application
from running while DFU via OTA process is going on
Regards
Tushar
  • Hi Einar Thorsrud,
    I'am actually running a thread so when i get callback dfu_started_cb() i suspend the thread, but when i disconnect the ble while dfu process is going on i want a callback saying dfu process is stopped, so that i can resume the thread,how can i get it
    Regards
    Tushar
  • Hi Tushar,
    I see. I do not believe there are any events for that out of the box. Perhaps you could check for an event indicating BLE disconnected (by specifying a callback for that with the call to bt_conn_cb_register()). If you first got an event from img_mgmt about DFU started, and then get a disconnect you will know that it has ended for some reason (at least provided you only have one BLE connection at a time).
    We discussed previously about MCu Mgr Eroor:NO_MEMORY when i get this error ,dfu_stopped_cb() callback gets invoked.
    I solved the enabling of thread when ble disconnect by your above suggestion
    when i start dfu process it dfu_started_cb() gets invoked ,but when i cancel dfu process and start it again it resumes from the previous position and i dont get dfu_started_cb() callback.
    Does it mean that only once the callback will be given ?
    Regards
    Tushar
  • Hi Tushar,
    Yes, I do not see any other callbacks that can be used from img_mgmnt. If you need more I suspect you need to modify it to call another callback in other situations or regularily whenever data is received or something else, depending on what fits your use case.
    Thank you for your assitance
    Regards
    Tushar
