Hi, I'm using the example libuartes of nrf5 sdk ver16. This example worked (receive data from computer(Hercules) and send it to back)
I have some customize that is when nRF received data from computer, it will send any data I want back to the computer.
Eg: my computer send "hello" and nrf after receive"hello" it will send to back "nice to meet you".
But after I send some line "hello" from my computer and receive"nice to meet you" => nRF reset. I think TX (save in somewhere I don't know overflowed)
NRF_LIBUARTE_ASYNC_DEFINE(libuarte1, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 100, 3);
NRF_LIBUARTE_ASYNC_DEFINE(libuarte2, 1, 2, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 100, 3);
static uint8_t text[] = "nrf reset =============\r\n";
static uint8_t textAT1_Uart1[] = "nice to meet you\r\n";
static uint8_t textReceived[100];
static volatile bool m_loopback_phase;
typedef struct
uint8_t *p_data;
uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
//Function to send via UART1
void send_UART_1(char *sdata, int len)
ret_code_t ret;
ret = nrf_libuarte_async_tx(&libuarte1, sdata, len);
APP_ERROR_CHECK(ret);
void uart_event_handler(void *context, nrf_libuarte_async_evt_t *p_evt)
nrf_libuarte_async_t *p_libuarte = (nrf_libuarte_async_t *)context;
ret_code_t ret;
switch (p_evt->type)
case NRF_LIBUARTE_ASYNC_EVT_ERROR:
case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
sprintf(textReceived, "%s", p_evt->data.rxtx.p_data);
// send_UART_1(textAT1_Uart1, sizeof(textAT1_Uart1));
// ret = nrf_libuarte_async_tx(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
ret = nrf_libuarte_async_tx(p_libuarte, textAT1_Uart1, sizeof(textAT1_Uart1));
if (ret == NRF_ERROR_BUSY)
buffer_t buf = {
.p_data = p_evt->data.rxtx.p_data,
.length = p_evt->data.rxtx.length,
ret = nrf_queue_push(&m_buf_queue, &buf);
bsp_board_led_invert(1);
m_loopback_phase = true;
case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
if (m_loopback_phase)
nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
if (!nrf_queue_is_empty(&m_buf_queue))
buffer_t buf;
ret = nrf_queue_pop(&m_buf_queue, &buf);
UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
bsp_board_led_invert(2);
ret_code_t ret = nrf_drv_clock_init();
ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
nrf_libuarte_async_config_t nrf_libuarte_async_config1 = {
.tx_pin = TX_PIN_NUMBER1,
.rx_pin = RX_PIN_NUMBER1,
.baudrate = NRF_UARTE_BAUDRATE_115200,
.parity = NRF_UARTE_PARITY_EXCLUDED,
.hwfc = NRF_UARTE_HWFC_DISABLED,
.timeout_us = 100,
.int_prio = APP_IRQ_PRIORITY_LOW};
nrf_libuarte_async_config_t nrf_libuarte_async_config2 = {
.tx_pin = TX_PIN_NUMBER2,
.rx_pin = RX_PIN_NUMBER2,
.timeout_us = 100,
err_code = nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler, (void *)&libuarte1);
err_code = nrf_libuarte_async_init(&libuarte2, &nrf_libuarte_async_config2, uart_event_handler, (void *)&libuarte2);
nrf_libuarte_async_enable(&libuarte1);
nrf_libuarte_async_enable(&libuarte2);
send_UART_1(text, sizeof(text));
while (true)
NRF_LOG_FLUSH();
here is my code just edit line 37 into 38. But my code not work smoothy like the example. Please give me some hints. I really appreciate about that.
Best Regart,
Tam
