pstorage problem when turning power off
I'm currently using the pstorage functions to be able to store permenant data when turning off the power, it works good with me while writing or reading but when I turn off the power, the data is erased from the memory, I think it may be it's a volatile memory, but on its documentation it's said that it write data to flash memory and the flash memory is a non-volatile memory.
thanks in advance
	static void example_pstorage_init()
		uint32_t err_code;
		pstorage_module_param_t p_example_param;
		// Setup pstorage with 5blocks of 16byte in each.
		p_example_param.block_size  = 0x10; // recommended to be >= 4 byte
		p_example_param.block_count = 10;
		p_example_param.cb          = example_cb_handler;
	  err_code = pstorage_init();
	  //APP_ERROR_CHECK(err_code);
		err_code = pstorage_register (&p_example_param, &m_p_example_id);
			if (err_code == NRF_SUCCESS)
					pattern_ID_4();
					flash_init();
			pg_size = NRF_FICR->CODEPAGESIZE;
			pg_num  = NRF_FICR->CODESIZE - 1;
			address = (uint32_t *)(pg_size * pg_num);
			Dt_store = * address;
			// Initialize
			leds_init();
			timers_init();
			gpiote_init();
			ble_stack_init();
			scheduler_init();
			gap_params_init();
			services_init();
			advertising_init();
			conn_params_init();
			sensor_simulator_init();
			sec_params_init();
		//	if(Dt_store != 0x0001)
					example_pstorage_init();
			// Start execution
			advertising_start();
			LPCOMP_init();
			// Enter main loop
			for (;;)
					app_sched_execute();
					power_manage();
	void edit_speed_ID(uint8_t speed)
			static uint8_t value __attribute__((aligned(8)));
		uint32_t err_code;
	    value = speed;
		err_code = pstorage_block_identifier_get(&m_p_example_id, dummy_block, &p_block_id);
					pattern_ID_4();
			nrf_delay_ms(1000);
		err_code = pstorage_store(&p_block_id, &value, dummy_size, dummy_offset);
					pattern_ID_4();
			nrf_delay_ms(1000);
