flash/fds hardfault not traceable
I am currently struggling with a problem where Im trying to implement the internal fds module which always leads to hard faults as follows:
There is probably something wrong in my configuration but I can't pinpoint where. The example worked okay so there are no problems on my own PCB. Yet I need support to handle this exception and get the config right!
Best, Julius
  • Thanks for the answer!!
    I tried the same btw. FYI, I also used my sdk_config h file on the example and this didn't yield the behavior
  • Hi Edvin,
    I still havent figured this out (I didn't focus so much on it but want to get it done asap)
    Did you find out anything? how does the flash placement look? heap and stack sizes shouldn't interfere here I suppose?
    Best, Julius
  • Hello Julius,
    I have looked into it from time to time, but I can't figure out why it doesn't work.
    I have tried to look for differences in your project settings and sdk_config.h, but so far with no luck.
    I see that the project configurations in your project are quite different from what it is in our examples. Perhaps you have done everything yourself? Or did you start with an example from the SDK?
    One example of weird behaving settings is that your include directories shows up like this:
    But it actually include many more folders. Since this is a bit off, then perhaps there are plenty of other settings not showing correctly as well, for all I know.
    I also tested by adding your flash_tb_radar.c/h into the flash_fds example, and there it runs without any issues. (attached in case you want to test).
    flash_fds_test_cust.zip
    Do you happen to know why the include directories setting looks like that? Does it do that in your case as well?
    Is there an option to go with the attached sample, and add the rest of your project to that?
    BR,
    Edvin
  • yeah, I suppose most include directories are in my solution options not the ones for the project (i.e. they are inherited)
    I will try to do it this way round, although its clear that by this I might just run into different problems.
    What I wanted to know is if you know how the attachment of the fds_evt_handler works exactly. THats where my application seems to crash, it doesn't go into the handler in the event_send function.
  • I need to bother you with this again.
    I also tried using the storage example, it throws a hardfault at the same function (event_write) and since I thought this example doesn't use the softdevice I suppose there is something else wrong. I ran the example on my custom PCB -- this works. How could I find out if my flash segments are wrong? and how can I see if I take too much space on the flash? I need this to work and yeah I got some custom stuff in my project but there must be a way to find out what Im doing wrong.
