HTTPS POST not working in SLM
(For some reason, I use "...' replace the original string)
Here is the log for using AT to do HTTPS POST:
2022-02-07T12:19:39.057Z DEBUG modem >> AT#XHTTPCCON=1,"...",443
2022-02-07T12:19:40.057Z ERROR Error: 'AT#XHTTPCCON=1,"...",443
' timed out
2022-02-07T12:19:40.591Z DEBUG modem << #XHTTPCCON: 1
2022-02-07T12:19:40.594Z DEBUG modem << OK
2022-02-07T12:19:46.614Z DEBUG modem >> AT#XHTTPCREQ="POST","...","Content-Type: application/json
2022-02-07T12:19:46.640Z DEBUG modem >> Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpZCI6eyJ1aWQiOjU3OCwiY29kZSI6ImVlNjNmZWI2LTA0YzMtNDM5Ni04OWI2LWExZDhjNzZhZDE0MSJ9LCJpc3MiOiJKSEhfVVNFUlMiLCJleHAiOjE2NDQyOTgwODAsInZlciI6MSwianRpIjoxODM4OX0.9uqBfMutUGyBaPIEwiP7AscgVMvUZwKSC9lqfAnDcEg
2022-02-07T12:19:46.674Z DEBUG modem >> Content-Length: 279
2022-02-07T12:19:46.707Z DEBUG modem >> ",279
2022-02-07T12:19:46.729Z DEBUG modem << OK
2022-02-07T12:19:46.731Z DEBUG modem << #XHTTPCREQ: 1
2022-02-07T12:19:56.042Z DEBUG modem >> {"meta":{...},"data":[...]}
2022-02-07T12:19:56.069Z DEBUG modem << ERROR
2022-02-07T12:19:56.072Z ERROR Error:{"meta":{...},"data":[...]}
failed
2022-02-07T12:19:56.092Z DEBUG modem << #XHTTPCREQ: 0
2022-02-07T12:19:56.111Z DEBUG modem << #XHTTPCREQ: -104
2022-02-07T12:19:56.113Z DEBUG modem << ERROR
2022-02-07T12:19:56.118Z DEBUG modem << #XDATAMODE: 0
2022-02-07T12:19:56.119Z DEBUG modem << #XHTTPCCON: 0
2022-02-07T12:20:05.708Z DEBUG modem << %CESQ: 27,1,3,0
Is this normal that the modem still return "OK" regardless of the 'timed out' .
What happen to the "XHTTPCREQ: -104" after payload send?
Thanks
  • Is it possible to run  LTE TraceCollector v2 preview with LTE Link Monitor?
    If not, how can I send the AT command to nRF9160.
    I still can not see any trace, and the filesize in side panel not growth.
    Here are steps for using trace collector:
    1. program
    nrf9160_dk_board_controller_fw.hex to nRF52 in nRF9160DK.
    2. program SLM (with
    CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y) to nRF91 in nRF9160DK.
    3. connect nrf9160 DK in TraceCollector, then start tracing with LIVE
    No trace shows in Wireshark...
    I try to use openssl to get the CA cert, but AT#XHTTPCCON still not connected after update the seg_tag.
    Just wonder what's the "Kubernetes Ingress Controller Fake Certificate" means in the following?
    openssl s_client -showcerts -connect gateway.dev.jawbonehealth.com:443
    CONNECTED(00000005)
    depth=0 O = Acme Co, CN = Kubernetes Ingress Controller Fake Certificate
    verify error:num=20:unable to get local issuer certificate
    verify return:1
    verify error:num=21:unable to verify the first certificate
    verify return:1
    Certificate chain
     0 s:/O=Acme Co/CN=Kubernetes Ingress Controller Fake Certificate
       i:/O=Acme Co/CN=Kubernetes Ingress Controller Fake Certificate
    -----BEGIN CERTIFICATE-----
    MIIDbzCCAlegAwIBAgIQfStz7642v8lUvvWCwhUJ/jANBgkqhkiG9w0BAQsFADBL
    Could it be that you're connecting locally to that server?
    Here's what I get when I run the exact same command:
    CONNECTED(00000003)
    depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
    verify return:1
    depth=1 C = US, O = Let's Encrypt, CN = R3
    verify return:1
    depth=0 CN = gateway.dev.jawbonehealth.com
    verify return:1
    Certificate chain
     0 s:CN = gateway.dev.jawbonehealth.com
       i:C = US, O = Let's Encrypt, CN = R3
    MIIFPzCCBCegAwIBAgISBO1MWjgNpXaRpyo3l6wOly7JMA0GCSqGSIb3DQEBCwUA
    MDIxCzAJBgNVBAYTAlVTMRYwFAYDVQQKEw1MZXQncyBFbmNyeXB0MQswCQYDVQQD
    EwJSMzAeFw0yMjAxMDMxNDE4MDRaFw0yMjA0MDMxNDE4MDNaMCgxJjAkBgNVBAMT
    HWdhdGV3YXkuZGV2Lmphd2JvbmVoZWFsdGguY29tMIIBIjANBgkqhkiG9w0BAQEF
    AAOCAQ8AMIIBCgKCAQEA0O4zwyRhnnhXJ2Lqnhw2ft/6h/cxG7e6e9pC9Dc1I2q7
    4pWwuMDv/FREC7oZSRjMwTpO6NV6mGflAqGe8qirECd+R4Mts5eiu9BbSnuaXq6R
    PLGyMVlnea0ERrVpIC/319h690plfqza2AhGtmkE1bUrfn4hJH8xH6FaTC7WDxw7
    vQbjpn17LbvxRk06aZuMmKJqrZKQwHhsOs7ZPUFF2pnVgmZSeRtVmhU02eNnBPIL
    bnoOeNW1FmTsnPx2ZxcKTtBsCKJ1kzVmqVlInzKMerFkl/0Nkncoig9qgcq2fE7V
    Mb8/Vi6nN0wZ5wfhdEoqrpuOu08wwXcp0xzTVsQXGwIDAQABo4ICVzCCAlMwDgYD
    VR0PAQH/BAQDAgWgMB0GA1UdJQQWMBQGCCsGAQUFBwMBBggrBgEFBQcDAjAMBgNV
    HRMBAf8EAjAAMB0GA1UdDgQWBBSiRJQ5P91QYAh5/389QkYvldycFTAfBgNVHSME
    GDAWgBQULrMXt1hWy65QCUDmH6+dixTCxjBVBggrBgEFBQcBAQRJMEcwIQYIKwYB
    BQUHMAGGFWh0dHA6Ly9yMy5vLmxlbmNyLm9yZzAiBggrBgEFBQcwAoYWaHR0cDov
    L3IzLmkubGVuY3Iub3JnLzAoBgNVHREEITAfgh1nYXRld2F5LmRldi5qYXdib25l
    aGVhbHRoLmNvbTBMBgNVHSAERTBDMAgGBmeBDAECATA3BgsrBgEEAYLfEwEBATAo
    MCYGCCsGAQUFBwIBFhpodHRwOi8vY3BzLmxldHNlbmNyeXB0Lm9yZzCCAQMGCisG
    AQQB1nkCBAIEgfQEgfEA7wB1AN+lXqtogk8fbK3uuF9OPlrqzaISpGpejjsSwCBE
    XCpzAAABfiCE2iQAAAQDAEYwRAIgIXeUAKAF1dmXa0pcp1GJPgoZ6JyeL+ZWJYiA
    ZUvoVEACID2z4Uz94ZlMk5B/B17d5pP3iCJJ84MgMWGhjjeBw1pBAHYARqVV63X6
    kSAwtaKJafTzfREsQXS+/Um4havy/HD+bUcAAAF+IITaSAAABAMARzBFAiAAtKfH
    /vkKX349mIa52rJ8kCysymCUM/hv+MQaFQW76QIhAOw7uHryLbu8QftkEISBXdvd
    PGEk/oy9gG6zfbRA8sw9MA0GCSqGSIb3DQEBCwUAA4IBAQAU2iCt5bnwIiZqMLZ3
    QUDI4bqsnHwrX0j5scYACwaS7mg3r4Sl9XJJLIlMqvvsNskbljK17KtNb++iT8KY
    d4M1hn4vHZQIpl8UvrvrABearikPms1SgVerS/ckPPE6XGha5anB6yrow7DFRAxe
    77d5od0sRW2q77/sPgqnbLtyFKMnw2SsrzGWaNCu7agccLo3+0FZMH8adN4TwXBp
    3rWy4TSRt1ilE57PHKhcsffr6GqV5skcrsqelIQIi9sPHEU4n+YUw/dUMuaj/mrs
    VW5ti8EeuVvxGGz3SsLLUjZa4abSFBfoYktlrT3b8tEopLXe0ZYiMokZv6MrJCkD
    e6Lu
    -----END CERTIFICATE-----
     1 s:C = US, O = Let's Encrypt, CN = R3
       i:C = US, O = Internet Security Research Group, CN = ISRG Root X1
    MIIFFjCCAv6gAwIBAgIRAJErCErPDBinU/bWLiWnX1owDQYJKoZIhvcNAQELBQAw
    TzELMAkGA1UEBhMCVVMxKTAnBgNVBAoTIEludGVybmV0IFNlY3VyaXR5IFJlc2Vh
    cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwHhcNMjAwOTA0MDAwMDAw
    WhcNMjUwOTE1MTYwMDAwWjAyMQswCQYDVQQGEwJVUzEWMBQGA1UEChMNTGV0J3Mg
    RW5jcnlwdDELMAkGA1UEAxMCUjMwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEK
    AoIBAQC7AhUozPaglNMPEuyNVZLD+ILxmaZ6QoinXSaqtSu5xUyxr45r+XXIo9cP
    R5QUVTVXjJ6oojkZ9YI8QqlObvU7wy7bjcCwXPNZOOftz2nwWgsbvsCUJCWH+jdx
    sxPnHKzhm+/b5DtFUkWWqcFTzjTIUu61ru2P3mBw4qVUq7ZtDpelQDRrK9O8Zutm
    NHz6a4uPVymZ+DAXXbpyb/uBxa3Shlg9F8fnCbvxK/eG3MHacV3URuPMrSXBiLxg
    Z3Vms/EY96Jc5lP/Ooi2R6X/ExjqmAl3P51T+c8B5fWmcBcUr2Ok/5mzk53cU6cG
    /kiFHaFpriV1uxPMUgP17VGhi9sVAgMBAAGjggEIMIIBBDAOBgNVHQ8BAf8EBAMC
    AYYwHQYDVR0lBBYwFAYIKwYBBQUHAwIGCCsGAQUFBwMBMBIGA1UdEwEB/wQIMAYB
    Af8CAQAwHQYDVR0OBBYEFBQusxe3WFbLrlAJQOYfr52LFMLGMB8GA1UdIwQYMBaA
    FHm0WeZ7tuXkAXOACIjIGlj26ZtuMDIGCCsGAQUFBwEBBCYwJDAiBggrBgEFBQcw
    AoYWaHR0cDovL3gxLmkubGVuY3Iub3JnLzAnBgNVHR8EIDAeMBygGqAYhhZodHRw
    Oi8veDEuYy5sZW5jci5vcmcvMCIGA1UdIAQbMBkwCAYGZ4EMAQIBMA0GCysGAQQB
    gt8TAQEBMA0GCSqGSIb3DQEBCwUAA4ICAQCFyk5HPqP3hUSFvNVneLKYY611TR6W
    PTNlclQtgaDqw+34IL9fzLdwALduO/ZelN7kIJ+m74uyA+eitRY8kc607TkC53wl
    ikfmZW4/RvTZ8M6UK+5UzhK8jCdLuMGYL6KvzXGRSgi3yLgjewQtCPkIVz6D2QQz
    CkcheAmCJ8MqyJu5zlzyZMjAvnnAT45tRAxekrsu94sQ4egdRCnbWSDtY7kh+BIm
    lJNXoB1lBMEKIq4QDUOXoRgffuDghje1WrG9ML+Hbisq/yFOGwXD9RiX8F6sw6W4
    avAuvDszue5L3sz85K+EC4Y/wFVDNvZo4TYXao6Z0f+lQKc0t8DQYzk1OXVu8rp2
    yJMC6alLbBfODALZvYH7n7do1AZls4I9d1P4jnkDrQoxB3UqQ9hVl3LEKQ73xF1O
    yK5GhDDX8oVfGKF5u+decIsH4YaTw7mP3GFxJSqv3+0lUFJoi5Lc5da149p90Ids
    hCExroL1+7mryIkXPeFM5TgO9r0rvZaBFOvV2z0gp35Z0+L4WPlbuEjN/lxPFin+
    HlUjr8gRsI3qfJOQFy/9rKIJR0Y/8Omwt/8oTWgy1mdeHmmjk7j1nYsvC9JSQ6Zv
    MldlTTKB3zhThV1+XWYp6rjd5JW1zbVWEkLNxE7GJThEUG3szgBVGP7pSWTUTsqX
    nLRbwHOoq7hHwg==
     2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
       i:O = Digital Signature Trust Co., CN = DST Root CA X3
    MIIFYDCCBEigAwIBAgIQQAF3ITfU6UK47naqPGQKtzANBgkqhkiG9w0BAQsFADA/
    MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT
    DkRTVCBSb290IENBIFgzMB4XDTIxMDEyMDE5MTQwM1oXDTI0MDkzMDE4MTQwM1ow
    cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwggIiMA0GCSqGSIb3DQEB
    AQUAA4ICDwAwggIKAoICAQCt6CRz9BQ385ueK1coHIe+3LffOJCMbjzmV6B493XC
    ov71am72AE8o295ohmxEk7axY/0UEmu/H9LqMZshftEzPLpI9d1537O4/xLxIZpL
    wYqGcWlKZmZsj348cL+tKSIG8+TA5oCu4kuPt5l+lAOf00eXfJlII1PoOK5PCm+D
    LtFJV4yAdLbaL9A4jXsDcCEbdfIwPPqPrt3aY6vrFk/CjhFLfs8L6P+1dy70sntK
    4EwSJQxwjQMpoOFTJOwT2e4ZvxCzSow/iaNhUd6shweU9GNx7C7ib1uYgeGJXDR5
    bHbvO5BieebbpJovJsXQEOEO3tkQjhb7t/eo98flAgeYjzYIlefiN5YNNnWe+w5y
    sR2bvAP5SQXYgd0FtCrWQemsAXaVCg/Y39W9Eh81LygXbNKYwagJZHduRze6zqxZ
    Xmidf3LWicUGQSk+WT7dJvUkyRGnWqNMQB9GoZm1pzpRboY7nn1ypxIFeFntPlF4
    FQsDj43QLwWyPntKHEtzBRL8xurgUBN8Q5N0s8p0544fAQjQMNRbcTa0B7rBMDBc
    SLeCO5imfWCKoqMpgsy6vYMEG6KDA0Gh1gXxG8K28Kh8hjtGqEgqiNx2mna/H2ql
    PRmP6zjzZN7IKw0KKP/32+IVQtQi0Cdd4Xn+GOdwiK1O5tmLOsbdJ1Fu/7xk9TND
    TwIDAQABo4IBRjCCAUIwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMCAQYw
    SwYIKwYBBQUHAQEEPzA9MDsGCCsGAQUFBzAChi9odHRwOi8vYXBwcy5pZGVudHJ1
    c3QuY29tL3Jvb3RzL2RzdHJvb3RjYXgzLnA3YzAfBgNVHSMEGDAWgBTEp7Gkeyxx
    +tvhS5B1/8QVYIWJEDBUBgNVHSAETTBLMAgGBmeBDAECATA/BgsrBgEEAYLfEwEB
    ATAwMC4GCCsGAQUFBwIBFiJodHRwOi8vY3BzLnJvb3QteDEubGV0c2VuY3J5cHQu
    b3JnMDwGA1UdHwQ1MDMwMaAvoC2GK2h0dHA6Ly9jcmwuaWRlbnRydXN0LmNvbS9E
    U1RST09UQ0FYM0NSTC5jcmwwHQYDVR0OBBYEFHm0WeZ7tuXkAXOACIjIGlj26Ztu
    MA0GCSqGSIb3DQEBCwUAA4IBAQAKcwBslm7/DlLQrt2M51oGrS+o44+/yQoDFVDC
    5WxCu2+b9LRPwkSICHXM6webFGJueN7sJ7o5XPWioW5WlHAQU7G75K/QosMrAdSW
    9MUgNTP52GE24HGNtLi1qoJFlcDyqSMo59ahy2cI2qBDLKobkx/J3vWraV0T9VuG
    WCLKTVXkcGdtwlfFRjlBz4pYg1htmf5X6DYO8A4jqv2Il9DjXA6USbW1FzXSLr9O
    he8Y4IWS6wY7bCkjCWDcRQJMEhg76fsO3txE+FiYruq9RUWhiF1myv4Q6W+CyBFC
    Dfvp7OOGAN6dEOM4+qR9sdjoSYKEBpsr6GtPAQw4dy753ec5
    Server certificate
    subject=CN = gateway.dev.jawbonehealth.com
    issuer=C = US, O = Let's Encrypt, CN = R3
    No client certificate CA names sent
    Peer signing digest: SHA256
    Peer signature type: RSA-PSS
    Server Temp Key: X25519, 253 bits
    SSL handshake has read 4603 bytes and written 401 bytes
    Verification: OK
    New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
    Server public key is 2048 bit
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Early data was not sent
    Verify return code: 0 (ok)
    Post-Handshake New Session Ticket arrived:
    SSL-Session:
        Protocol  : TLSv1.3
        Cipher    : TLS_AES_256_GCM_SHA384
        Session-ID: E3EE2D025F3D2BBBEFC906ECC4C8845B9F5F5A6E35169678823EB3B7E37CDF97
        Session-ID-ctx:
        Resumption PSK: 47FC953FC2901D28B1FCB680495CF9104C991004EC4FE53B99B7362141A8E7257448481B33BC16007F567CD971802F29
        PSK identity: None
        PSK identity hint: None
        SRP username: None
        TLS session ticket lifetime hint: 600 (seconds)
        TLS session ticket:
        0000 - d6 c4 8f 9a e7 b0 38 45-2a 44 9f 95 f5 41 da 18   ......8E*D...A..
        0010 - b5 16 4f 00 8d 59 93 76-04 44 87 9d e2 31 bc cb   ..O..Y.v.D...1..
        Start Time: 1644484574
        Timeout   : 7200 (sec)
        Extended master secret: no
        Max Early Data: 0
    read R BLOCK
    SSL-Session:
        Protocol  : TLSv1.3
        Session-ID: 7EE212D109C7E6CDE3912EF11AAC41DBF8889390369EA0C188C8976430409E7F
        Session-ID-ctx:
        Resumption PSK: CD270E207A219AD3F6FBD8E5E02A16D4FDB6F5D348DB2CFCD1BF026D7852F6B7750F96FBF7259F5C14FBB06F6E182245
        PSK identity: None
        SRP username: None
        TLS session ticket:
        0000 - 55 8e b6 2f 6d 59 91 54-03 af 67 18 15 74 0c 98   U../mY.T..g..t..
        0010 - ae 85 d7 d4 ff dc a3 0f-b1 c1 08 87 23 ce ba fd   ............#...
        Max Early Data: 0
    read R BLOCK
    closed
    If you are having issues with SLM + modem tracing, you can try to use https_client instead and issue the ISRG root x1 instead of the default digicert.
    Håkon
  • Hi
    I just found the different openssl version may cause the different result, I can get the similar result with yours in another computer.
    So, looks like server return 3 CA certs, and, I can pick either one for CA certificate in sec_tag, right?
    If it is, would you mind to try in your side for AT#XHTTPCCON=1,"gateway.dev.jawbonehealth.com",443,sec_tag?
    I believe I already try those CA certs but still not connected.
    Thanks
  • For issue the ISRG root x1 instead of the default digicert, did yiu mean use https://letsencrypt.org/certs/isrgrootx1.pem as CA cert?
    Yes, I try but still same.
    You also mention "Could it be that you're connecting locally to that server?"
    Is that mean the local operator for LTE-M network may has conneting issue, just like firewall something else?
    Thanks
    With https_client, changed the hostname to match your wanted host.
    And issued the X1 root CA:
    this is the output:
    *** Booting Zephyr OS build v2.7.99-ncs1-rc1  ***
    HTTPS client sample started
    Certificate mismatch
    Provisioning certificate
    Waiting for network.. OK
    Connecting to gateway.dev.jawbonehealth.com
    Sent 79 bytes
    Received 267 bytes
    >        HTTP/1.1 401 Unauthorized
    Finished, closing socket.
    Similar with SLM (reused sec_tag 42, which has X1 CA):
    AT#XHTTPCCON=1,"gateway.dev.jawbonehealth.com",443,42
    #XHTTPCCON: 1
    OK
    AT#XHTTPCREQ="GET","/get?foo1=bar1&foo2=bar2",""
    OK
    #XHTTPCREQ: 0
    #XHTTPCRSP:0,1
    #XHTTPCRSP:0,1
    Håkon
