Unable to find bootable image - MCUBoot
I try to integrate mcuboot and BT DFU into my application. I'm using SDK 1.8.0 and DK board nrf52832.
My problem is, that i got this message "Unable to find bootable image" by mcuboot (investigated via debugger, unfortunatelly  i'm not able to enable logs in that build).
So probably there is problem with partitions or maybe signature of the app.
This is my mcuboot.conf:
CONFIG_MULTITHREADING=y
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
And this is pm_static.yml:
app:
  address: 0xc200
  region: flash_primary
mcuboot:
  address: 0x0
mcuboot_pad:
  address: 0xc000
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x3E000
scratch_storage:
  address: 0x70000
settings_storage:
  address: 0x7a000
And also flash configuration from my .dts:
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x32000>;
		slot1_partition: partition@3e000 {
			label = "image-1";
			reg = <0x0003E000 0x32000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x00070000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 0x00006000>;
I'm building and flashing using the simplest way:
west build -b <board_name>
west flash (merged.hex is being flashed)
Before some changes (not important here) everything was working fine, and i was even able to upload images through bluetooth with positive answer. But after few rebuilds it stopped working (probably it was pure luck - this is why i suspect that something may be wrong with partition table).
  • Hi Simon,
    For your information, I'm building in a Ubuntu (18.04) environment and using West version 0.10.1:
        $ west --version
        West version: v0.10.1
    I can't really find something in the output when I build (prestine or not), but I saw that in the build/ncs/mcuboot/zephyr/.config it differs between the two builds (prestine build or not):
    (The 'build' directory contains a prestine build (i.e. after "rm -rf build"), and no_build is a renamed build-directory after a second build, i.e. after "touch" and build again)
        $ diff build/ncs/mcuboot/zephyr/.config no_build/ncs/mcuboot/zephyr/.config
        265,266c265,266
        < # CONFIG_PARTITION_MANAGER_ENABLED is not set
        < # CONFIG_FLASH_MAP_CUSTOM is not set
        > CONFIG_PARTITION_MANAGER_ENABLED=y
        > CONFIG_FLASH_MAP_CUSTOM=y
    Ie. these two configs are not set in the prestine build, but in the second build they are set - that is the only difference in the .config file between the two builds.
    Edit!
    I found another difference in the file build/ncs/mcuboot/zephyr/dev_handles.c.
    In the prestine build (after rm -rf) the last entry looks like this:
    /* 10 : /soc/spi@40023000/mx25u1633f@0:
    * - /soc/gpio@50000000
    * - /soc/gpio@50000300
    * - /soc/spi@40023000
    const device_handle_t __aligned(2) __attribute__((__section__(".__device_handles_pass2")))
    __devicehdl_DT_N_S_soc_S_spi_40023000_S_mx25u1633f_0[] = { 5, 6, 9, DEVICE_HANDLE_ENDS, DEVICE_HANDLE_ENDS, DEVICE_HANDLE_ENDS };
    In the second build, it has changed to:
    __devicehdl_DT_N_S_soc_S_spi_40023000_S_mx25u1633f_0[] = { 6, 5, 9, DEVICE_HANDLE_ENDS, DEVICE_HANDLE_ENDS, DEVICE_HANDLE_ENDS };
    Again, no other difference in this file ...
    Cheers,
    Thomas
  • Dymek117
    Dymek117 said:
    My mcuboot.conf is on the same level that prj.conf.
    Dymek117 said:
    Also, small difference about mcuboot is in our cmake files, i set overlay config for mcuboot, like here:
    list(APPEND mcuboot_OVERLAY_CONFIG "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf")
    I tried to modify my sample according to the above, check it out here:
    hello_world_with_mcuboot_v2.zip
    Then did a pristine build using NCS v1.8.0:
    west build -b nrf52dk_nrf52832 -d build_v12_pristine -p
    and it worked fine:
    *** Booting Zephyr OS build v2.7.0-ncs1  ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    I: Jumping to the first image slot
    ÿ*** Booting Zephyr OS build v2.7.0-ncs1  ***
    Hello World! nrf52dk_nrf52832
    I tested this with both west v0.12.0 and v0.10.1
    Can you upload the project you're using as a zipped file and provide a detailed step-by-step guide on how to reproduce the issue. Could you let me know what west version you're using as well as the OS? You're using NCS v1.8.0, right?
  • Simon, basing on your post with step-by-step described build process I fixed this issue.
    Final solution was to create /child_image/ directory and place mcuboot.conf inside this dir.
    Then, no additional instructions for this file is needed in cmakelist, it is included by default.
    I have no idea why id does matter, but after this small change pristine build is booting fine.
    I'm using SDK 1.8.0 on Windows 10. My west version v0.12.0.
  • Okay, I'm happy it got resolved!
    Let me try to look into the issue you encounter Online Thomas Fänge
        265,266c265,266
    I'm using this application hello_world_with_mcuboot_v2.zip
    I've installed west v0.10.1 to another location. and downgraded NCS to v1.7.0, as it seems that's what you're using.
    This is the content of the sample folder to start with:
    CMakeLists.txt  README.rst  mcuboot.conf  pm_static.yml  prj.conf  sample.yaml  src
    First I check the west version
    C:/msys64/mingw64/bin/west --version
    Then I do a pristine build:
    C:/msys64/mingw64/bin/west build -b nrf52dk_nrf52832 -d build_v10_pristine -p
    Then I created the build folder you refer to as "no_build "
    C:/msys64/mingw64/bin/west build -b nrf52dk_nrf52832 -d build_v10_no_build
    touch CMakeLists.txt
    Eventually I did a diff between the generated mcuboot folders
    diff build_v10_pristine/mcuboot/zephyr/.config build_v10_no_build/mcuboot/zephyr/.config
    But I got no result, which means they have the same content
    I have not yet installed Dual Boot Linux Ubuntu on my new computer, but I will do it soon and test this on Ubuntu as well.
    However, could you try the following:
    • Update to NCS v1.8.0 and the associated west v0.12.0?
      • If you install it through the Toolchain Manager, all the correct tools will be installed automatically
    • Check how you include the mcuboot config folder. Try to add it to child_image/mcuboot.conf
    Simon
  • Hi Simon!
    Thanks for your response!
    Sorry - I had mixed up my files! It didn't help with creating a child_image etc, it still only works for me after the second build ... :(
    I can also confirm that if I create a "child_image/mcuboot.conf"-file:
      xxx/src/ncs/child_image$ ll
      -rw-r--r-- 1 sefangeth domain_users 1307 feb 14 14:40 mcuboot.conf
    then it works!
    The configuration for mcuboot we have is normally placed in an overlay file, pointed to from the CMakeFile.txt:
      list(APPEND mcuboot_OVERLAY_CONFIG "$ENV{VSLN_NCS_ROOT}/vt2-overlays/vt2-mcuboot-overlay.conf")
    So, it seems as if the overlay-file is not used when compiling for the first time (i.e. after deleting the build directory). In the example above - the mcuboot.conf is identical to the vt2-mcuboot-overlay.conf.
    Can that be explained - or is the child_image approach to be preferred?
    Thomas
