LTE-M consuming way to much power to transmit 100 bytes UDP every 15 seconds, please help me understand why.
I'm using the UDP sample from SDK 1.8.0 with the following modifications:
  • No PSM
  • No eDRX
  • Send 100 bytes every 15 seconds
This is on the nrf9160-DK board.
I suspect I can improve power consumption by disabling RRC idle mode, but I cannot find any documentation on how to do this.
I am unsure of the actual cDRX timing parameters as what seems like DRX events are sporadic.
Here are some power profile images and a modem trace if that's helpful.
The above image shows large period of almost continuous activity after the TX event for ~5 seconds and then iDRX activity until the next TX event.
This is the activity while RRC connected.
I am seeing an average of 10mA, with 22mA during the connection period. I was expecting the average current consumption to be 2.5 - 4mA.
7723.trace-2022-02-14T21-46-37.030Z.bin
  • Want to add that RAI with LTE-M is a release 14 feature. Not sure how widely it is available but some networks do, and for activation a custom command needs to be used.
    %REL14FEAT
    But combining TCP and RAI is not recommended.
    When using TCP then you will never know if you are getting TCP re-transmits or not, so you will never know if the last packet you sent was the last one or a re-transmit.
    Jonathan
  • Hi EDLT, many thanks for the reply.
    Interesting, I had experimented with REL14FEAT but without success. I actually had no luck getting NRF_SO_RAI_NO_DATA to work on NB-IoT and ended up using NRF_SO_RAI_LAST with an extra send to get a release. Maybe on LTE-M I need to go back to trying NRF_SO_RAI_NO_DATA as you do.
    It could also be my use of the NRF_ versions with nrf_socket that is the difference. Or just that my network doesn't support it... I'll see what I can do.
    Thanks again, and thanks Jonathan.
    Jake
