sample fat_fs
I'm trying the  sample fat_fs  on the nRF5340 DK
1) It does build, but there is awarning
CMake Warning at D:\nRfConnect\v1.8.0\zephyr\CMakeLists.txt:722 (message):
No SOURCES given to Zephyr library: drivers__disk
2) looked with the debugger: in the main() it reaches the  LOG_ERR("Storage init ERROR!");
void main(void)
if (disk_access_init(disk_pdrv) != 0) {
Could you please comment on the above 2 points ?
What steps should i make to have a SD-card running,  is using sample fat_fs the way to go ?
Best Regards,
Theo
  • When i switch off the power of the board, and then connect the CS of the card to the GND,  and power up the board, the the sc-card gives a response !!    When after that i deconnect the cs from the GND and push reset then it does not respond(errors). as te be expected. When i then connect the CS to the ground again and give the board a reset, then it does not respond(Errors).
    So only after putting the board power OFF, then on (with the CS   to GND) then the sd-card response.
    So where is the cs-gpios going to ??
  • Hi Simon,
    I would like to let you know:  i have now managed to write some data to the SD-card and read it back.
    using disk_access_write(),  disk_access_read()
    I will add a seperate gpio-pin to be used as CS for the SdCard.
    ==>  but actualy the question:  cs-gpios going to ??   would be nice to know..,  how, that could/should be resolved.  (But now at least im not blocked by this issue)
    To have writing a file onto the SD-CARD, that a PC will understand needs some more then
    disk_access_write(),  disk_access_read()  Correct?
    What do i need to look into to have data to be written onto the SD-card? , such that the PC doe understand.
    Thanks  Simon for the help.
    I'm looking forward to your reply
    Best Regards,
    Theo
  • Ah, I'm really sorry for not seeing this earlier. Try using another pin than P0.17 for CS. If you take a look at nRF5340 DK Hardware --> External memory you can see that P0.17 is connected to SCLK of the nRF5340DK onboard flash (to use it, you must cut SB11 and short SB21). Try to use another pin like P1.12 for CS.
    If you turn the nRF5340 DK upside down, you can see the GPIOs that are occupied by onboard functionality.
    Simon
  • Hi Simon,
    Thanks..
    I did change the pin number before.., but just checked again,
    this time (i tried manny more pins before),   i used cs-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
    But the P0.10 pin is just not active its floating.
    And in the (Visual Studio Code) under DeviceTree/Gpio  neither &gpio0, nor &gpio0 is showing any signal that could reate to  cs-gpios.
    Best Regards,
    Theo
  • Hi Simon,
    Got It now :-)
    I was looking how to control GPIO pins in general, and came across this tiket:
    https://devzone.nordicsemi.com/f/nordic-q-a/67320/unsupported-pin-error-when-using-pins-on-port-1-of-the-nrf52840dongle/275624#275624
    Now i added in the fat_fs sample:  main.c file
    gpio0dev = device_get_binding("GPIO_0");
    And behold... the    cs-gpios  on P0.10  is now working !!
    But still ... in the (Visual Studio Code) under DeviceTree/Gpio  neither &gpio0, nor &gpio0 is showing any signal that could relate to  cs-gpios
    Thanks Simon for all the help.
    Remains this (new)question:
    What do i need to look into,  to have data to be written onto the SD-card? , such that the PC does understand.
    Best Regards,
    Theo
