BLE Master-Slave mode can avoid colision?
            We have 3 nRF52840 to establish a net. one for master device, One for Master device, One for HUB(Msater-Slave) device, and One for Slave device. The data flow is Slave device--> HUB(Master-Slave) device -->Master device.
             So there is two BLE link: one for the master device and the HUB device. One for the HUB device and the Slave device. For the HUB device , The most important design is to avoid the link colision. I think if the HUB connect the master first,  then connect slave, nRF52840 can arrange the anchor proper to avoid link colision. because if HUB connect the Master device, The master deivce deside the anchor point and notify the HUB the anchor point by connect req PDU. when the HUB decide the anchor pointer for slave connection, It can arrange it proper to avoid colision.
              So when the HUB connect the master device, It will disconnect the Slave device and rescan for the slave device for connect.
              But it fullfilled in the nRF52840 SDK, It just a guess, I can't confirm it.
              Can Noridc engeneer confirm it, Or tell me the how the WInoff and winsize are caculated in the SDK?
  • zhangkui said:
    We have tested that the data throughput of multifold is less than one master connect two slaves. Maybe the reason is we set both connect interval and event length 7.5ms.
    What parameters did you use in your other tests, and what throughput did you achieve in both tests?
    Karl
  • All three device set connect interval  7.5ms  and  event length 7.5ms.
    The data flow is  slave device-->multirole device-->master device.
    The data throughput is  15kbps
    RSSI is about  -75dbm.
    If data throughput is 30kbps , it will drop data.
    Thank you for confirming.
    What throughput did you achieve on the central and two peripheral test, for comparison?
    Could you elaborate on why you need to have the multirole-intermidiate device, by the way?
    Could you elaborate on what you mean when you say that data is dropped? No data is lost on the BLE link, so this must be happening in the application logic.
    For the record, 15 kbps is considered a very low throughput
    , so I suspect that there is an issue with the application somewhere.
    Karl
  • We transmit a wave for example the ECG wave data.. we can see gaps of the wave. 30kbps is also a very low throughput.  But the noise is big and the RSSI is -75 dim.
    We test a multirole connect two slave.  The data flow is slave-->multirole-->slave They can achieve 30kbps. No wave gap. And the RSSI is also -75dim.
    Yes, 30 kbps is also a very low throughput indeed.
    Does these gaps indicate that no data was received in time for it to be rendered? Or does it indicate that certain timestamps / parts of the sequence was never received?
    In case of the former it sounds like an issue strictly about throughput, in case of the latter we will also need to look into how your application is handling the data up until transmission.
    Which MTU size are you using in your application? If you are operating in an environment with a lot of noise where packets frequently gets corrupted it will help to divide the transfers into multiple packets instead, to reduce the chance of corruption due to noise.
    Karl
