nRF5340 and nRF9160 general questions
Good day,
I would like to confirm the following points regarding the nRF9160 and nRF5340:
nRF9160
1. The modem firmware binary is programmed through the SWD and not a UART port?
2. The Application core is also programmed using the SWD interface?
3. Does it ship from the factory with a bootloader?
nRF5340
1. The application core and network processor are programmed through the SWD interface and can be simultaneously debugged by creating two debug sessions?
2. The network core only supports a single UART instance, while the application core can support up to 4 UART instances?
3. What interface is used to load the bootloader (SWD and/or UART) and also are there specific GPIO pins that need to be used if the bootloader is uploaded using UART.
4. Does it ship from the factory with a bootloader?
  • Hi Frikkie,
    Your questions are quite messy, I am not sure where to get started to answer your questions. I will just list them according to my understanding and give you some advice:
    1) Development Environment
    Frikkie Badenhorst said:
    nrf9160 does not have enough memory so we need an external app processor
    Sounds like you should choose an external flash instead of another processer.
    we decided to use IAR as compiler without Zephyr.
    Is there any special reason you do not use nRF Connect SDK(based on Zephyr)? I have never met a customer who does not use the official nRF Connect SDK for their development. You would hardly get support if you use a rarely used development solution. All the documents I referred to by far are all targeted to NCS documents.
    2) MCUboot
    What exactly is meant by for secure concerns?
    The secure concerns mean if you use the default key to sign your image, other developers can easily replace your application firmware with their firmware and do whatever they want with your device.
    Is MCUBoot only capable of booting into non-secure regions?
    Not sure if I understand you, for nRF5340, MCU starts from the secure domain, so mcuboot as a bootloader has to be in the secure domain.
    3)  secure and non-secure domains
    our understanding sets the entire chip to non-secure. Is this indeed the case?
    You need bootloader+ SPM(configure peripherals used in the non-secure domain) in the secure domain and running your application on the secure domain.
    Features of nRF91 Series — nRF Connect SDK 1.9.1 documentation (nordicsemi.com)
    Using a custom Secure Partition Manager with your application - Software - nRF Connect SDK guides - Nordic DevZone (nordicsemi.com)
    Secure Partition Manager — nRF Connect SDK 1.9.1 documentation (nordicsemi.com)
    Please turn back to nRF Connect SDK, and try to read and learn the document.
    Charlie
    Most questions are answered and looks like we will be able to use MCUBoot. Some more remarks/questions:
    1)
    We need both processors as we will also be using the 2.4GHz radio and NFC on the nrf5340
    2)
    Yes. We already have our application running on multiple other devices using a different OS (not thread based). From our investigations the SDK forces you to use Zephyr, hence our entire application will have to be redesigned. We also found the tools (and Zephyr) not to be very user friendly and quite cumbersome. From previous discussions with Nordic, we understand that modem and radio libraries are OS-independant, so we should be able to use it still. IAR is also miles ahead of GCC as a compiler, and unfortunately it seems as if the SDK is GCC only.
    3) At startup, we are trying to access non-secure peripherals, for example NRF_UARTE0_NS. We however get an exception when trying to access it (we can only access NRF_UARTE0_S).
    Should we not be able to access non-secure peripherals when running in the secure domain?
  • Hi Frikkie,
    1)2) Understood.
    3) Since you do not use NCS, so you cannot use the secure and non-secure domains management solutions like SPM or TFM.
    This should not be an issue, as nRF9160 PS section 6.15.4 mentions:
    Secure code can access both secure peripherals and non-secure peripherals.
    Hard to say where the issue might happen since you are using your own solution. Maybe referring to the steps from the SPM source code could give you some hints.
    Charlie
  • Hi Charlie. Me again.
    I would like some clarification regarding the Coexistence interface of the nRF9160.
    "COEX0 – Input to the LTE modem from the external device. When active high, indicates that the
    external device transceiver is turned on. When internal GPS is used, COEX0 can be used as active-high
    control for the external LNA component."
    I feel this is a bit ambiguous since it seems like COEX0 is used as output from the LTE modem when the internal GPS is used, however, this is never explicitly stated.
    Additionally, I would assume that this pin needs to be reconfigured as an output when the internal GPS is used. Does this happen automatically internal, or is additional configuration required?
    Kind regards.
    Franco
  • Hi Franco,
    Please just create a new ticket for this topic.
    You will get help from our nRF9160 HW expert.
    Charlie
