Uart: wrong offset after buffer overflow
Hi, hello_world_UART_rx_test.zip
I am trying to use the UART on my nRF9160DK board.
In my program I have 2 uarts in use. uart0 is used for printk output and uart1 is used to receive data in async mode.
I have both connected to the vcom ports on the dev kit (the "usb" port) and have 2 instances of tera term open on windows; one for the printk output, one for the chars i want to send.
Now the problem:
when sending single chars, everything is ok, but if I send a sequence of chars, that would overflow the buffer i have given the uart_rx_enable() or the uart_rx_buf_rsp() function ( eg pasting "abcdef" into the "uart1" terminal when there are already a few bytes in the buffer), I get the free and the request buffer events. after that, I get another rx event.
lets say the buffer is pretty full and I send "abcdef". Then "abc" still fits into the first buffer, I get the rx event for 3 bytes of data. everything ok. free event and request buffer event follow, new buffer is given. Then I immediately get the rx event with the new buffer. in the new buffer is "def", and I get offset=0 (which is ok), but len=1 (which is NOT ok) from the evt parameter in the callback function -> I am not getting notified for the 'e' and 'f' !!
When I send a single new char now, it gets placed after the "def", so on an offset of 3, but in the evt parameter it says offset of 1 (because it ignored the 'e' and 'f' before).
I am surely using the functionality wrong. please take a look at the attached FW, because can't figure out what I am doing wrong from documentation alone.
Thank you!
  • My sincere apologies for not responding to this earlier. I will provide an answer to you by end of today.
    Sorry for the inconvenience.
  • *** Booting Zephyr OS build v2.7.99-ncs1  ***
    MAIN START!
    uart rx buf req
    evt len = 2, evt offs = 0, actual data in 0
    12
    evt len = 14, evt offs = 2, actual data in 2
    3456789012345
    freeing buffer
    uart rx buf req
    evt len = 2, evt offs = 0, actual data in 2
    12
    3456789012345
    freeing buffer
    uart rx buf req
    evt len = 1, evt offs = 0, actual data in 256
    1
    evt len = 15, evt offs = 1, actual data in 256
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    evt len = 2, evt offs = 0, actual data in 256
    12
    evt len = 14, evt offs = 2, actual data in 256
    3456789012345
    freeing buffer
    uart rx buf req
    evt len = 1, evt offs = 0, actual data in 0
    evt len = 1, evt offs = 1, actual data in 1
    1
    evt len = 14, evt offs = 2, actual data in 3
    23456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    1
    23456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    123456789012345
    freeing buffer
    uart rx buf req
    There is clearly something going on.
    Looks like the root cause is the function memcpy copies the whole buffer. There is definitely something off.
    memcpy(au8Main_DummyBuf, evt->data.rx.buf, MAIN_UART_BUF_LEN);
    Still trying to look more into the root cause.
    -Øyvind
    thanks for the feedback so far.
    the memcpy you mentioned is honestly just for the visualization.
    when you debug into the rx event and look at evt->data.rx.buf in memory, you can see, that in the case of the overflow, new bytes are added to a different offset than evt->data.rx.offset reports
    I mainly copied the evt->data.rx.buf to au8Main_DummyBuf to easily watch it in a debugger watch window.
    Were you able to replicate the issue of new chars arriving into evt->data.rx.buf on a different offset as evt->data.rx.offset ? If not I will make a video or something to help replicate the case
  • I made a video anyway to help reproduce the behaviour.
    I am once again asking for a status update, as I need to inform my team as well.
