Dear ,
I use toolchain Manager to install the whole project.
Would you teach me how to solve this ?
Dear ,
Can you please run the nRF Connect: Generate support information from the Command Pallette in VS Code?
Creating solution peripheral_lbs.emProject D:/Arrow/Nordic/nRF5340/v1.9.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DBOARD_DIR=D:\Arrow\Nordic\nRF5340\v1.9.0\zephyr\boards\arm\nrf5340dk_nrf5340 -BD:\Arrow\Nordic\nRF5340\v1.9.0\nrf\samples\bluetooth\peripheral_lbs\build_nrf5340dk_nrf5340_cpuapp -SD:\Arrow\Nordic\nRF5340\v1.9.0\nrf\samples\bluetooth\peripheral_lbs -DNCS_TOOLCHAIN_VERSION=1.9.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=D:\Arrow\Nordic\nRF5340\v1.9.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py -- Application: D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs -- Zephyr version: 2.7.99 (D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr), build: v2.7.99-ncs1 -- Found Python3: D:/Arrow/Nordic/nRF5340/v1.9.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.12.0", minimum required is "0.7.1") -- Board: nrf5340dk_nrf5340_cpuapp -- Cache files will be written to: D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/.cache -- Found dtc: D:/Arrow/Nordic/nRF5340/v1.9.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (D:/Arrow/Nordic/nRF5340/v1.9.0/toolchain/opt) -- Found BOARD.dts: D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts -- Generated zephyr.dts: D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/dts.cmake Parsing D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/Kconfig Loaded configuration 'D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig' Merged configuration 'D:/Arrow/Nordic/nRF5340/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/prj.conf' -- Configuring incomplete, errors occurred! Including boilerplate (Zephyr base): D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/cmake/app/boilerplate.cmake -- Using NCS Toolchain 1.9.0 for building. (D:/Arrow/Nordic/nRF5340/v1.9.0/toolchain/cmake) warning: the hex symbol NRF_MODEM_LIB_SHMEM_CTRL_SIZE (defined at D:/Arrow/Nordic/nRF5340/v1.9.0/nrf\lib\nrf_modem_lib\Kconfig.modemlib:97) has a non-hex default NRF_MODEM_SHMEM_CTRL_SIZE (undefined) warning: HAS_NORDIC_DRIVERS (defined at modules\hal_nordic\Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF53X (defined at soc/arm/nordic_nrf\nrf53\Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y) warning: HAS_NRFX (defined at modules\hal_nordic\nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF53X (defined at soc/arm/nordic_nrf\nrf53\Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y) warning: NRFX_CLOCK (defined at modules\hal_nordic\nrfx/Kconfig:14) has direct dependencies HAS_HW_NRF_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y) warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules\hal_nordic\nrfx/Kconfig:18) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:36), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y) warning: NRFX_DPPI (defined at modules\hal_nordic\nrfx/Kconfig:26, drivers/serial/Kconfig.nrfx:385) has direct dependencies (HAS_HW_NRF_DPPIC && HAS_NRFX && 0) || (HAS_HW_NRF_DPPIC && (UART_0_NRF_HW_ASYNC || UART_1_NRF_HW_ASYNC || UART_2_NRF_HW_ASYNC || UART_3_NRF_HW_ASYNC) && UART_NRFX && SERIAL) with value n, but is currently being y-selected by the following symbols: - UART_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx:398), with value y, direct dependencies (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y), and select condition HAS_HW_NRF_DPPIC && (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y) warning: NRFX_GPIOTE (defined at modules\hal_nordic\nrfx/Kconfig:65) has direct dependencies HAS_HW_NRF_GPIOTE && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies SOC_FAMILY_NRF && GPIO (value: y), and select condition SOC_FAMILY_NRF && GPIO (value: y) warning: NRFX_IPC (defined at modules\hal_nordic\nrfx/Kconfig:81) has direct dependencies HAS_HW_NRF_IPC && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - IPM_NRFX (defined at D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/Kconfig:6, drivers/ipm/Kconfig:71), with value y, direct dependencies y (value: y), and select condition HAS_HW_NRF_IPC && IPM (value: y) warning: NRFX_NVMC (defined at modules\hal_nordic\nrfx/Kconfig:95) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - SOC_FLASH_NRF (defined at drivers/flash/Kconfig.nrf:10), with value y, direct dependencies SOC_FAMILY_NRF && !FLASH_NRF_FORCE_ALT && FLASH (value: y), and select condition SOC_FAMILY_NRF && !FLASH_NRF_FORCE_ALT && FLASH (value: y) error: Aborting due to Kconfig warnings CMake Error at D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/cmake/kconfig.cmake:272 (message): command failed with return code: 1 Call Stack (most recent call first): D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/cmake/app/boilerplate.cmake:544 (include) D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include) D:/Arrow/Nordic/nRF5340/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate) CMakeLists.txt:12 (find_package) error: cmake failed create_nordic_project.py failed (1)
Dear Øyvind,
I copied and pasted output for your reference.
Dear Øyvind,
Would you let me know how to generate support information from the Command Pallette in VS Code?
Dear Øyvind,
liujirong888 said:Would you let me know how to generate support information from the Command Pallette in VS Code?
This can be run in the command pallette of VS Code
Then type in the following in the command pallette
liujirong888 said:I copied and pasted output for your reference.
I'm not seeing these warnings on my side. Have you edited the project in any way? Specifically I don't understand the warning on NRF_MODEM_LIB_SHMEM_CTRL_SIZE, which is not used in this sample.
Here is the output from my SES, building untouched peripheral_lbs.
C:/NordicSemi/v1.9.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DBOARD_DIR=C:\NordicSemi\v1.9.0\zephyr\boards\arm\nrf5340dk_nrf5340 -BC:\NordicSemi\v1.9.0\nrf\samples\bluetooth\peripheral_lbs\build_nrf5340dk_nrf5340_cpuapp -SC:\NordicSemi\v1.9.0\nrf\samples\bluetooth\peripheral_lbs -DNCS_TOOLCHAIN_VERSION=1.9.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\NordicSemi\v1.9.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
-- Application: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs
-- Zephyr version: 2.7.99 (C:/NordicSemi/v1.9.0/zephyr), build: v2.7.99-ncs1
-- Found Python3: C:/NordicSemi/v1.9.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/NordicSemi/v1.9.0/zephyr/.cache
-- Found dtc: C:/NordicSemi/v1.9.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/NordicSemi/v1.9.0/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/dts.cmake
Parsing C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/Kconfig
Loaded configuration 'C:/NordicSemi/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/prj.conf'
Configuration saved to 'C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/.config'
Kconfig header saved to 'C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/NordicSemi/v1.9.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
loading initial cache file C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/child_image_preload.cmake
-- Application: C:/NordicSemi/v1.9.0/zephyr/samples/bluetooth/hci_rpmsg
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: C:/NordicSemi/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/dts.cmake
Parsing C:/NordicSemi/v1.9.0/zephyr/Kconfig
Loaded configuration 'C:/NordicSemi/v1.9.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration 'C:/NordicSemi/v1.9.0/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
Merged configuration 'C:/NordicSemi/v1.9.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/.config'
Kconfig header saved to 'C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- libmetal version: 1.1.0 (C:/NordicSemi/v1.9.0/zephyr/samples/bluetooth/hci_rpmsg)
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.1.0 (C:/NordicSemi/v1.9.0/modules/lib/open-amp/open-amp)
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg
-- libmetal version: 1.1.0 (C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs)
-- Configuring done
-- Generating done
Including boilerplate (Zephyr base): C:/NordicSemi/v1.9.0/zephyr/cmake/app/boilerplate.cmake
-- Using NCS Toolchain 1.9.0 for building. (C:/NordicSemi/v1.9.0/toolchain/cmake)
C:\NordicSemi\v1.9.0\toolchain\opt\bin\arm-none-eabi-gdb.exe: warning: Couldn't determine a path for the index cache directory.
=== child image hci_rpmsg - CPUNET begin ===
CMake Warning (dev) at C:/NordicSemi/v1.9.0/nrf/samples/bluetooth/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/hci_rpmsg/child_image_preload.cmake:11 (set):
Syntax error in cmake code at
when parsing string
Invalid escape sequence \N
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: arm
-- Machine: arm
-- C_FLAGS : -Wall -Wextra
=== child image hci_rpmsg - CPUNET end ===
-- Build type:
-- Machine: arm
-- Machine: arm
CMake Warning at C:/NordicSemi/v1.9.0/zephyr/CMakeLists.txt:1687 (message):
Loading solution peripheral_lbs.emProject
Loading solution build.emProject
Mapping project information
Mapping project zephyr/merged.hex
Mapping project C:/NordicSemi/v1.9.0/zephyr/include/dt-bindings/gpio/gpio.h
Mapping project C:/NordicSemi/v1.9.0/zephyr/include/dt-bindings/i2c/i2c.h
Mapping project C:/NordicSemi/v1.9.0/zephyr/include/dt-bindings/pinctrl/nrf-pinctrl.h
Mapping project C:/NordicSemi/v1.9.0/zephyr/misc/empty_file.c
Mapping project CMakeFiles/merged_domains_hex
Mapping project CMakeFiles/merged_hex
Mapping project all
Mapping project app/libapp.a
Mapping project cmake_object_order_depends_target_..__nrf__drivers__hw_cc310
Mapping project cmake_object_order_depends_target_..__nrf__lib__dk_buttons_and_leds
Mapping project cmake_object_order_depends_target_..__nrf__lib__fatal_error
Mapping project cmake_object_order_depends_target_app
Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32
Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m
Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__cmse
Mapping project cmake_object_order_depends_target_arch__arm__core__aarch32__mpu
Mapping project cmake_object_order_depends_target_arch__common
Mapping project cmake_object_order_depends_target_boards__arm__nrf5340dk_nrf5340
Mapping project cmake_object_order_depends_target_drivers__bluetooth
Mapping project cmake_object_order_depends_target_drivers__clock_control
Mapping project cmake_object_order_depends_target_drivers__console
Mapping project cmake_object_order_depends_target_drivers__flash
Mapping project cmake_object_order_depends_target_drivers__gpio
Mapping project cmake_object_order_depends_target_drivers__ipm
Mapping project cmake_object_order_depends_target_drivers__serial
Mapping project cmake_object_order_depends_target_drivers__timer
Mapping project cmake_object_order_depends_target_isr_tables
Mapping project cmake_object_order_depends_target_kernel
Mapping project cmake_object_order_depends_target_lib__libc__minimal
Mapping project cmake_object_order_depends_target_lib__posix
Mapping project cmake_object_order_depends_target_metal
Mapping project cmake_object_order_depends_target_modules__hal_nordic__nrfx
Mapping project cmake_object_order_depends_target_offsets
Mapping project cmake_object_order_depends_target_open_amp
Mapping project cmake_object_order_depends_target_soc__arm__common__cortex_m
Mapping project cmake_object_order_depends_target_subsys__bluetooth__common
Mapping project cmake_object_order_depends_target_subsys__bluetooth__host
Mapping project cmake_object_order_depends_target_subsys__net
Mapping project cmake_object_order_depends_target_zephyr
Mapping project cmake_object_order_depends_target_zephyr_final
Mapping project cmake_object_order_depends_target_zephyr_pre0
Mapping project cmake_object_order_depends_target_zephyr_pre1
Mapping project hci_rpmsg/zephyr/merged_CPUNET.hex
Mapping project hci_rpmsg/zephyr/zephyr.elf
Mapping project hci_rpmsg/zephyr/zephyr.hex
Mapping project merged_domains_hex
Mapping project merged_hex
Mapping project modules/CANopenNode/all
Mapping project modules/TraceRecorder/all
Mapping project modules/cddl-gen/all
Mapping project modules/civetweb/all
Mapping project modules/cjson/all
Mapping project modules/cmsis/CMSIS/Core/all
Mapping project modules/cmsis/CMSIS/all
Mapping project modules/cmsis/all
Mapping project modules/connectedhomeip/all
Mapping project modules/fatfs/all
Mapping project modules/hal_nordic/all
Mapping project modules/hal_nordic/nrfx/all
Mapping project modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
Mapping project modules/libmetal/all
Mapping project modules/libmetal/libmetal/all
Mapping project modules/libmetal/libmetal/lib/all
Mapping project modules/libmetal/libmetal/lib/compiler/all
Mapping project modules/libmetal/libmetal/lib/compiler/armcc/all
Mapping project modules/libmetal/libmetal/lib/compiler/gcc/all
Mapping project modules/libmetal/libmetal/lib/compiler/iar/all
Mapping project modules/libmetal/libmetal/lib/libmetal.a
Mapping project modules/libmetal/libmetal/lib/processor/all
Mapping project modules/libmetal/libmetal/lib/processor/arm/all
Mapping project modules/libmetal/libmetal/lib/system/all
Mapping project modules/libmetal/libmetal/lib/system/zephyr/all
Mapping project modules/libmetal/libmetal/lib/system/zephyr/arm/all
Mapping project modules/littlefs/all
Mapping project modules/loramac-node/all
Mapping project modules/lvgl/all
Mapping project modules/lz4/all
Mapping project modules/mbedtls/all
Mapping project modules/mcuboot/all
Mapping project modules/mcuboot/boot/bootutil/zephyr/all
Mapping project modules/memfault-firmware-sdk/all
Mapping project modules/mipi-sys-t/all
Mapping project modules/nanopb/all
Mapping project modules/nrf/all
Mapping project modules/nrf/drivers/all
Mapping project modules/nrf/drivers/entropy/all
Mapping project modules/nrf/drivers/flash/all
Mapping project modules/nrf/drivers/gps/all
Mapping project modules/nrf/drivers/hw_cc310/all
Mapping project modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
Mapping project modules/nrf/drivers/serial/all
Mapping project modules/nrf/ext/all
Mapping project modules/nrf/lib/all
Mapping project modules/nrf/lib/bin/all
Mapping project modules/nrf/lib/dk_buttons_and_leds/all
Mapping project modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a
Mapping project modules/nrf/lib/fatal_error/all
Mapping project modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
Mapping project modules/nrf/lib/flash_patch/all
Mapping project modules/nrf/modules/all
Mapping project modules/nrf/samples/CMakeFiles/hci_rpmsg_subimage
Mapping project modules/nrf/samples/CMakeFiles/hci_rpmsg_subimage-complete
Mapping project modules/nrf/samples/all
Mapping project modules/nrf/samples/hci_rpmsg_subimage
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-configure
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-done
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-download
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-install
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-mkdir
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-patch
Mapping project modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-update
Mapping project modules/nrf/subsys/all
Mapping project modules/nrf/subsys/bluetooth/all
Mapping project modules/nrf/subsys/bluetooth/services/all
Mapping project modules/nrf/subsys/debug/all
Mapping project modules/nrf/subsys/dfu/all
Mapping project modules/nrf/subsys/net/all
Mapping project modules/nrf/subsys/net/lib/all
Mapping project modules/nrf/subsys/partition_manager/all
Mapping project modules/nrf/tests/all
Mapping project modules/nrf_hw_models/all
Mapping project modules/nrfxlib/all
Mapping project modules/nrfxlib/nrf_802154/all
Mapping project modules/nrfxlib/nrfxlib/all
Mapping project modules/nrfxlib/nrfxlib/crypto/all
Mapping project modules/nrfxlib/nrfxlib/softdevice_controller/all
Mapping project modules/open-amp/all
Mapping project modules/open-amp/open-amp/all
Mapping project modules/open-amp/open-amp/lib/all
Mapping project modules/open-amp/open-amp/lib/libopen_amp.a
Mapping project modules/open-amp/open-amp/lib/remoteproc/all
Mapping project modules/open-amp/open-amp/lib/rpmsg/all
Mapping project modules/open-amp/open-amp/lib/virtio/all
Mapping project modules/openthread/all
Mapping project modules/segger/all
Mapping project modules/st/all
Mapping project modules/tinycbor/all
Mapping project modules/tinycrypt/all
Mapping project modules/tinycrypt/lib/all
Mapping project modules/trusted-firmware-m/all
Mapping project modules/zscilib/all
Mapping project zephyr/CMakeFiles/driver_validation_h_target
Mapping project zephyr/CMakeFiles/kobj_types_h_target
Mapping project zephyr/CMakeFiles/linker_zephyr_final_script_target
Mapping project zephyr/CMakeFiles/linker_zephyr_pre0_script
Mapping project zephyr/CMakeFiles/linker_zephyr_prebuilt_script_target
Mapping project zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
Mapping project zephyr/CMakeFiles/offsets_h
Mapping project zephyr/CMakeFiles/parse_syscalls_target
Mapping project zephyr/CMakeFiles/syscall_list_h_target
Mapping project zephyr/all
Mapping project zephyr/arch/all
Mapping project zephyr/arch/arch/arm/all
Mapping project zephyr/arch/arch/arm/core/aarch32/all
Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/all
Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/all
Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
Mapping project zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
Mapping project zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
Mapping project zephyr/arch/arch/arm/core/aarch32/mpu/all
Mapping project zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
Mapping project zephyr/arch/common/all
Mapping project zephyr/arch/common/libarch__common.a
Mapping project zephyr/arch/common/libisr_tables.a
Mapping project zephyr/boards/all
Mapping project zephyr/boards/boards/arm/nrf5340dk_nrf5340_cpuapp/all
Mapping project zephyr/boards/boards/arm/nrf5340dk_nrf5340_cpuapp/libboards__arm__nrf5340dk_nrf5340.a
Mapping project zephyr/cmake/flash/all
Mapping project zephyr/cmake/reports/all
Mapping project zephyr/cmake/usage/all
Mapping project zephyr/dev_handles.c
Mapping project zephyr/driver_validation_h_target
Mapping project zephyr/drivers/all
Mapping project zephyr/drivers/bluetooth/all
Mapping project zephyr/drivers/bluetooth/hci/all
Mapping project zephyr/drivers/bluetooth/libdrivers__bluetooth.a
Mapping project zephyr/drivers/clock_control/all
Mapping project zephyr/drivers/clock_control/libdrivers__clock_control.a
Mapping project zephyr/drivers/console/all
Mapping project zephyr/drivers/console/libdrivers__console.a
Mapping project zephyr/drivers/disk/all
Mapping project zephyr/drivers/flash/all
Mapping project zephyr/drivers/flash/libdrivers__flash.a
Mapping project zephyr/drivers/gpio/all
Mapping project zephyr/drivers/gpio/libdrivers__gpio.a
Mapping project zephyr/drivers/interrupt_controller/all
Mapping project zephyr/drivers/ipm/all
Mapping project zephyr/drivers/ipm/libdrivers__ipm.a
Mapping project zephyr/drivers/misc/all
Mapping project zephyr/drivers/pcie/all
Mapping project zephyr/drivers/serial/all
Mapping project zephyr/drivers/serial/libdrivers__serial.a
Mapping project zephyr/drivers/timer/all
Mapping project zephyr/drivers/timer/libdrivers__timer.a
Mapping project zephyr/drivers/usb/all
Mapping project zephyr/include/generated/autoconf.h
Mapping project zephyr/include/generated/driver-validation.h
Mapping project zephyr/include/generated/kobj-types-enum.h
Mapping project zephyr/include/generated/offsets.h
Mapping project zephyr/include/generated/otype-to-size.h
Mapping project zephyr/include/generated/otype-to-str.h
Mapping project zephyr/include/generated/syscall_dispatch.c
Mapping project zephyr/include/generated/syscall_list.h
Mapping project zephyr/isrList.bin
Mapping project zephyr/isr_tables.c
Mapping project zephyr/kernel/all
Mapping project zephyr/kernel/libkernel.a
Mapping project zephyr/kobj_types_h_target
Mapping project zephyr/lib/all
Mapping project zephyr/lib/gui/all
Mapping project zephyr/lib/libc/all
Mapping project zephyr/lib/libc/minimal/all
Mapping project zephyr/lib/libc/minimal/liblib__libc__minimal.a
Mapping project zephyr/lib/open-amp/all
Mapping project zephyr/lib/os/all
Mapping project zephyr/lib/posix/all
Mapping project zephyr/lib/posix/liblib__posix.a
Mapping project zephyr/lib/util/all
Mapping project zephyr/libzephyr.a
Mapping project zephyr/linker.cmd
Mapping project zephyr/linker_zephyr_final_script_target
Mapping project zephyr/linker_zephyr_pre0.cmd
Mapping project zephyr/linker_zephyr_pre0_script
Mapping project zephyr/linker_zephyr_pre1.cmd
Mapping project zephyr/linker_zephyr_prebuilt_script_target
Mapping project zephyr/merged_domains.hex
Mapping project zephyr/misc/generated/struct_tags.json
Mapping project zephyr/misc/generated/syscalls.json
Mapping project zephyr/offsets
Mapping project zephyr/offsets_h
Mapping project zephyr/parse_syscalls_target
Mapping project zephyr/soc/arm/all
Mapping project zephyr/soc/arm/common/cortex_m/all
Mapping project zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
Mapping project zephyr/soc/arm/nordic_nrf/all
Mapping project zephyr/soc/arm/nordic_nrf/common/all
Mapping project zephyr/soc/arm/nordic_nrf/nrf53/all
Mapping project zephyr/subsys/all
Mapping project zephyr/subsys/bluetooth/all
Mapping project zephyr/subsys/bluetooth/common/all
Mapping project zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
Mapping project zephyr/subsys/bluetooth/host/all
Mapping project zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
Mapping project zephyr/subsys/bluetooth/services/all
Mapping project zephyr/subsys/canbus/all
Mapping project zephyr/subsys/debug/all
Mapping project zephyr/subsys/fb/all
Mapping project zephyr/subsys/fs/all
Mapping project zephyr/subsys/fs/nvs/all
Mapping project zephyr/subsys/ipc/all
Mapping project zephyr/subsys/ipc/rpmsg_service/all
Mapping project zephyr/subsys/logging/all
Mapping project zephyr/subsys/mgmt/all
Mapping project zephyr/subsys/modbus/all
Mapping project zephyr/subsys/net/all
Mapping project zephyr/subsys/net/lib/all
Mapping project zephyr/subsys/net/lib/utils/all
Mapping project zephyr/subsys/net/libsubsys__net.a
Mapping project zephyr/subsys/pm/all
Mapping project zephyr/subsys/pm/policy/all
Mapping project zephyr/subsys/portability/all
Mapping project zephyr/subsys/random/all
Mapping project zephyr/subsys/settings/all
Mapping project zephyr/subsys/settings/src/all
Mapping project zephyr/subsys/stats/all
Mapping project zephyr/subsys/storage/all
Mapping project zephyr/subsys/storage/flash_map/all
Mapping project zephyr/subsys/task_wdt/all
Mapping project zephyr/subsys/testsuite/all
Mapping project zephyr/subsys/tracing/all
Mapping project zephyr/syscall_list_h_target
Mapping project zephyr/zephyr.elf
Mapping project zephyr/zephyr.hex
Mapping project zephyr/zephyr_generated_headers
Mapping project zephyr/zephyr_pre0.elf
Mapping project zephyr/zephyr_pre1.elf
Preparing solution ‘peripheral_lbs’
Preparing project ‘zephyr/merged.hex’
Preparing solution ‘build’
Preparing project ‘all’
Preparing project ‘app/libapp.a’
Preparing project ‘modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a’
Preparing project ‘modules/libmetal/libmetal/lib/libmetal.a’
Preparing project ‘modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a’
Preparing project ‘modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a’
Preparing project ‘modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a’
Preparing project ‘modules/open-amp/open-amp/lib/libopen_amp.a’
Preparing project ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’
Preparing project ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a’
Preparing project ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a’
Preparing project ‘zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a’
Preparing project ‘zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a’
Preparing project ‘zephyr/arch/common/libarch__common.a’
Preparing project ‘zephyr/arch/common/libisr_tables.a’
Preparing project ‘zephyr/boards/boards/arm/nrf5340dk_nrf5340_cpuapp/libboards__arm__nrf5340dk_nrf5340.a’
Preparing project ‘zephyr/drivers/bluetooth/libdrivers__bluetooth.a’
Preparing project ‘zephyr/drivers/clock_control/libdrivers__clock_control.a’
Preparing project ‘zephyr/drivers/console/libdrivers__console.a’
Preparing project ‘zephyr/drivers/flash/libdrivers__flash.a’
Preparing project ‘zephyr/drivers/gpio/libdrivers__gpio.a’
Preparing project ‘zephyr/drivers/ipm/libdrivers__ipm.a’
Preparing project ‘zephyr/drivers/serial/libdrivers__serial.a’
Preparing project ‘zephyr/drivers/timer/libdrivers__timer.a’
Preparing project ‘zephyr/kernel/libkernel.a’
Preparing project ‘zephyr/lib/libc/minimal/liblib__libc__minimal.a’
Preparing project ‘zephyr/lib/posix/liblib__posix.a’
Preparing project ‘zephyr/libzephyr.a’
Preparing project ‘zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a’
Preparing project ‘zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a’
Preparing project ‘zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a’
Preparing project ‘zephyr/subsys/net/libsubsys__net.a’
Preparing project ‘zephyr/zephyr.elf’
Preparing project ‘zephyr/zephyr_pre0.elf’
Preparing project ‘zephyr/zephyr_pre1.elf’
Restoring state from previous session
Preparing to load data
Loading session data from file
SEGGER Embedded Studio is ready to us
