Unable to start debugging in VS Code when not executed as admin
Hi community,
I was changing the IDE from SES to VS Code and got everything running fine except debugging.
If i execute VS Code as administrator debugging works as supposed.
Starting debugging in VS Code as user will emit the following error message:
Well, J-Link is properly installed and the registry key seems to be properly defined, too:
Since i don't know how VS Code and OS registry work in this case, i cannot detect the error.
Please help me out here!
Thanks in advance, best greets
AleBeBu
  • AleBeBu said:
    I could't find this paths in the first two outputs i sent you.
    I was referring to the windows path in the support information, line 154, under environment:
    Path": "c:\\ncs\\v1.9.0\\toolchain\\mingw64\\bin;c:\\ncs\\v1.9.0\\toolchain\\mingw64\\libexec\\git-core;c:\\ncs\\v1.9.0\\toolchain\\opt\\bin;c:\\ncs\\v1.9.0\\toolchain\\opt\\bin\\Scripts;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Python\\Scripts\\;C:\\Program Files\\Python\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\PuTTY\\;C:\\ProgramData\\Oracle\\Java\\javapath;C:\\Program Files\\PowerShell\\7\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\SEGGER\\JLink;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Users\\la00181912\\AppData\\Local\\Microsoft\\WindowsApps",
    AleBeBu said:
    Thanks for your efforts on helping me!
    That's what we're here for. Note that you often not alone in having these kind of issues, and that it's good for our team to find a solution for this. Unfortunately, they have not found any solutions yet.
    The only work-around at the moment is to run the environment as admin.
  • Another suggestion from our team is to rund the following command in e.g. PowerShell or Command Prompt:
    reg query HKEY_LOCAL_MACHINE\Software\SEGGER\J-Link
    Do this for both admin and non-admin, if possible.
    Also, can you try to completely remove JLink from your computer, then reboot and reinstall as standard user?
  • admin cmd:
    C:\WINDOWS\system32>reg query HKEY_LOCAL_MACHINE\Software\SEGGER\J-Link
        InstallPath    REG_SZ    C:\Program Files (x86)\SEGGER\JLink
        CurrentVersion    REG_DWORD    0x129a9
    non-admin cmd:
    C:\Users\wn00181912>reg query HKEY_LOCAL_MACHINE\Software\SEGGER\J-Link
    FEHLER: Die Registrierungsbearbeitung wurde vom Administrator deaktiviert.
    sorry for german, says:
    ERROR: Registration processing has been disabled by the administrator.
  • Standard user installation of JLink didn't fix the issue either.
  • You might need to talk to your IT department. Modifying the registry is one thing, but if you are not able to read it, that might be the root cause to the issue here.
