nrf5340DK debugger restarts, port disconnected
nrfjprog restarts nrf5340DK debugger
We are running a container environment in Ubuntu 20.04 on WSL2 and the USB ports are frwarded using usbipd
When trying to flash (or just reset) the nrf5340DK after connecting and disconnecting a terminal emulator program
the debugger chip seems to be restarting and the port is lost to the container.
This means we have to connect the ports again and restart the container, making it impossible to run automatic tests for instance
Steps to recreate:
1. Build the zephyr/samples/hello_world sample for nrf5340dk_nrf5340_cpuapp
2. flash the board with nrfjprog
3. Open a terminal emulator program (putty and picocom tested)
4. Reset the board to se the printout
5. Exit the terminal emulator program
6. Try to flash: the following error occurs:
ERROR: Unable to connect to a debugger.
ERROR: [SeggerBackend] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.'
ERROR: [SeggerBackend] - JLinkARM.dll Open returned error 'Failed to open DLL'
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
The we need to connect the port again in WSL and the restart the container to get it working again.
The question is, why do we end up in this state after using the emulator and is it possible to flash without resetting the debugger?
See attached log files
Environment:
nrfjprog: 10.15.2
jLink: DLL version V7.62a, compiled Feb 23 2022 17:02:35
Firmware: J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49
Hardware: PCA10095 2.0.0
Log from when it fails:
[2022-Feb-25 16:04:53] [ info] --------------------------------------------------------------------------------
[2022-Feb-25 16:04:53] [ info] nrfjprog --program build/zephyr/hello_zephyr.hex --recover --verify -f NRF53 --log
[2022-Feb-25 16:04:53] [ info] nrfjprog version 10.15.2 external
[2022-Feb-25 16:04:53] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Feb-25 16:04:53] [ info] Library loaded, loading member functions.
[2022-Feb-25 16:04:53] [ info] Member functions succesfully loaded.
[2022-Feb-25 16:04:53] [debug] [ Client] - open
[2022-Feb-25 16:04:53] [debug] [ Client] - start
[2022-Feb-25 16:04:53] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 0fb58d33-9d91-434f-81c7-7d68de21c7a9.
[2022-Feb-25 16:04:53] [trace] [ Client] - Command open executed for 2 milliseconds with result 0
[2022-Feb-25 16:04:53] [debug] [ Client] - enum_emu_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Feb-25 16:04:53] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Feb-25 16:04:53] [debug] [  nRF53] - open
[2022-Feb-25 16:04:53] [debug] [  nRF53] - just_check_family
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - open_dll
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Feb-25 16:04:53] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.
[2022-Feb-25 16:04:53] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Feb-25 16:04:53] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - dll_version
[2022-Feb-25 16:04:53] [ info] [SeggerBackend] - Segger dll version 7.62.a loaded.
[2022-Feb-25 16:04:53] [trace] [ Worker] - Command open executed for 1 milliseconds with result 0
[2022-Feb-25 16:04:53] [debug] [  nRF53] - enum_emu_con_info
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Feb-25 16:04:53] [trace] [ Client] - Command enum_emu_con_info executed for 32 milliseconds with result 0
[2022-Feb-25 16:04:53] [debug] [ Client] - connect_to_emu_with_snr
[2022-Feb-25 16:04:53] [trace] [ Worker] - Command enum_emu_con_info executed for 32 milliseconds with result 0
[2022-Feb-25 16:04:53] [debug] [  nRF53] - connect_to_emu_with_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Feb-25 16:04:53] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Feb-25 16:05:01] [trace] [ Client] - Command connect_to_emu_with_snr executed for 8177 milliseconds with result -102
[2022-Feb-25 16:05:01] [trace] [  JLink] -    ***** Error:
[2022-Feb-25 16:05:01] [trace] [  JLink] - Cannot connect to J-Link.
[2022-Feb-25 16:05:01] [trace] [  JLink] - - 8061.153ms returns "Cannot connect to J-Link."
[2022-Feb-25 16:05:01] [trace] [  JLink] - JLINK_HasError()
[2022-Feb-25 16:05:01] [error] [SeggerBackend] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.'
[2022-Feb-25 16:05:01] [trace] [  JLink] - JLINK_OpenEx(...)
[2022-Feb-25 16:05:01] [trace] [  JLink] - - 0.053ms returns "Failed to open DLL"
[2022-Feb-25 16:05:01] [error] [SeggerBackend] - JLinkARM.dll Open returned error 'Failed to open DLL'
[2022-Feb-25 16:05:01] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Feb-25 16:05:01] [trace] [  JLink] - JLINK_IsOpen()
[2022-Feb-25 16:05:01] [trace] [  JLink] - - 0.003ms returns 0x00
[2022-Feb-25 16:05:01] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 8177 milliseconds with result -102
[2022-Feb-25 16:05:01] [debug] [  nRF53] - close
[2022-Feb-25 16:05:01] [trace] [  JLink] - - 0.006ms returns 0x00
[2022-Feb-25 16:05:01] [debug] [SeggerBackend] - close
[2022-Feb-25 16:05:01] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Feb-25 16:05:01] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Feb-25 16:05:01] [debug] [  nRF53] - nRF family DLL closed
[2022-Feb-25 16:05:01] [trace] [ Client] - Command close executed for 10 milliseconds with result 0
[2022-Feb-25 16:05:01] [debug] [ Client] - terminate
[2022-Feb-25 16:05:01] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Feb-25 16:05:01] [trace] [ Worker] - Command close executed for 10 milliseconds with result 0
[2022-Feb-25 16:05:01] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Feb-25 16:05:01] [trace] [ Worker] - Executed 5 commands for 8220 milliseconds
[2022-Feb-25 16:05:01] [debug] [ Client] - Child process terminated with result 0
[2022-Feb-25 16:05:01] [debug] [ Client] - Worker process exited with code: 0
[2022-Feb-25 16:05:01] [trace] [ Client] - Executed 5 commands for 8221 milliseconds
Log from when it works:
8156.nrfjprog_nrf5340_OK.txt
investigation.zip
