how to modify a custom board after creation
Hello, Support
I am new to Nordic and try to follow the tutorial video here https://www.nordicsemi.com/Products/Development-tools/nRF-Connect-for-VS-Code/Tutorials
Just created a board and build, but later I need to add a few things to my board - like LED or a button. is there a way I modify the board already created and rebuild? or do I have to create a new one?
I am using VS and SDK version of v1.9.0.
Regards!
Ping
  • Hello, Priyanka
    Thanks for reply, I am only trying the blinky sample, try to do it on a custom board - the Fanstel one, I copied the gpio-leds and aliases part into the device tree file *.dts when I created the board, and build seems fine, but it doesn't run. When I debug it, the device_get_binding() function returns 0,   what else do I need to do in order to run that on my custom board please. I created the board under myMroject folder. And use VS Code for IDE.
    Regards! I am sorry to bother you, I am new to Zephyr and Nordic.
    Ping
    No problem at all Slight smile. This could be because you have not created a device struct. Details regarding this has also been covered in the Tutorial that I have linked earlier. You could take a look at the Board Porting Guide and also at the Device Driver Model.
    -Priyanka
  • Thanks, where shall I create a device struct please? is it the .yaml file I need to create? could you please give an example? it is just for the blinky example, hope that is not complicated. I am sorry, it is seem snot easy as i use VS code IDE, not directly form command line.
    Regards!
    Ping
  • Hi, Priyanka
    I followed the guide and copy, paste and modified a board under Zephyr tree to be my Fanstel one, and LEDs and Buttons are now working. This is much easier than create a custom board outside Zephyr tree as the video tutorial  does, but it doesn't have an complete example to run through, so a bit misleading as the later part might be hard.
    Now my question is , may I manually copy the custom board I put under Zephyr tree to be somewhere else outside the tree and will it be still recognised by VS Code? I want to leave the Zephyr tree alone.
    Regards!
    Ping
    I believe this is possible. Did you refer to this video tutorial? It shows how the custom development works in VS Code too.
    -Priyanka
